See <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/1590/>
[...truncated 96 lines...]
[INFO] GeoServer Release Module
[INFO] Building GeoServer
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/target>
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-5643] problem with legend decoration and input parameter
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 25.08.2013 @ 15:54:51 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 27-Aug-2013 04:39
[INFO] [GitCommitIdMojo] build.build.time = 27.08.2013 @ 04:39:20 UTC
[INFO] [GitCommitIdMojo] build.branch = 1b1cbfa0104f7121372500837d91813533ab9ef5
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 1b1cbfa
[INFO] [GitCommitIdMojo] build.commit.id = 1b1cbfa0104f7121372500837d91813533ab9ef5
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-5643] problem with legend decoration and input parameter
[INFO] [site:attach-descriptor {execution: default-attach-descriptor}]
[INFO] snapshot org.geotools:gt-api:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-api:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:library:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:library:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:modules:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:modules:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:geotools:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:geotools:11-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/geotools/11-SNAPSHOT/geotools-11-SNAPSHOT.pom
[INFO] snapshot org.geotools:gt-referencing:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-referencing:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-referencing:11-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-referencing:11-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-metadata:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-metadata:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-metadata:11-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-metadata:11-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-opengis:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-opengis:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-opengis:11-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-opengis:11-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-main:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-main:11-SNAPSHOT: checking for updates from osgeo
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/target/geoserver-2.5-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] [GitCommitIdMojo] build.build.time = 27.08.2013 @ 04:39:28 UTC
[INFO] [GitCommitIdMojo] build.build.time = 27.08.2013 @ 04:39:29 UTC
[INFO] [dependency:copy-dependencies {execution: copy-dependencies}]
[INFO] Copying gt-api-11-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/target/dependency/gt-api-11-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.5.0-beta.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/target/dependency/gwc-core-1.5.0-beta.jar>
[WARNING] DEPRECATED [tasks]: Use target instead
[INFO] [antrun:run {execution: read-manifest}]
[WARNING] Parameter tasks is deprecated, use target instead
[INFO] Executing tasks
main:
[copy] Copying 1 file to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/target>
[INFO] Executed tasks
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/pom.xml> to /usr/share/jetty/.m2/repository/org/geoserver/geoserver/2.5-SNAPSHOT/geoserver-2.5-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/target/geoserver-2.5-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/geoserver/2.5-SNAPSHOT/geoserver-2.5-SNAPSHOT-tests.jar
[INFO] Building Core Platform Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/platform/target>
[INFO] [GitCommitIdMojo] build.build.time = 27.08.2013 @ 04:39:37 UTC
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/platform/src/main/resources>
[INFO] Compiling 23 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/platform/target/classes>
[INFO] Copying 3 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/platform/src/test/resources>
[INFO] Compiling 6 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/platform/target/test-classes>
[INFO] Tests are skipped.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/platform/target/platform-2.5-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/platform/target/platform-2.5-SNAPSHOT-tests.jar>
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/platform/target/platform-2.5-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/platform/target/platform-2.5-SNAPSHOT-test-sources.jar>
[INFO] Copying gt-api-11-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/platform/target/dependency/gt-api-11-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.5.0-beta.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/platform/target/dependency/gwc-core-1.5.0-beta.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/platform/target/platform-2.5-SNAPSHOT.jar> to /usr/share/jetty/.m2/repository/org/geoserver/platform/2.5-SNAPSHOT/platform-2.5-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/platform/target/platform-2.5-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/platform/2.5-SNAPSHOT/platform-2.5-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/platform/target/platform-2.5-SNAPSHOT-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/platform/2.5-SNAPSHOT/platform-2.5-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/platform/target/platform-2.5-SNAPSHOT-test-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/platform/2.5-SNAPSHOT/platform-2.5-SNAPSHOT-test-sources.jar
[INFO] Building Open Web Service Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/ows/target>
[INFO] [GitCommitIdMojo] build.build.time = 27.08.2013 @ 04:39:46 UTC
[INFO] Copying 9 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/ows/src/main/resources>
[INFO] snapshot org.geotools.ogc:net.opengis.ows:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.ows:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:ogc:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:ogc:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.ogc:org.w3.xlink:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:org.w3.xlink:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.ogc:org.w3.xlink:11-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.ogc:org.w3.xlink:11-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.xsd:gt-xsd-ows:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-ows:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:xsd:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:xsd:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:extension:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:extension:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-filter:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-filter:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-filter:11-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-filter:11-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-coverage:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-coverage:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-coverage:11-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-coverage:11-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.xsd:gt-xsd-core:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-core:11-SNAPSHOT: checking for updates from osgeo
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/master/geoserver-master-2013-08-27-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
