[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-master-nightly #1603
See <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/1603/&gt;
[...truncated 2768 lines...]
  Class clazz = geoscript.process.Process.convertGeoScriptToGeoToolsClass(param.getType());
geoscript cannot be resolved
3. ERROR in <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/src/main/java/org/geoserver/script/groovy/GroovyWpsHook.java&gt; (at line 93)
  return geoscript.geom.Geometry.wrap((com.vividsolutions.jts.geom.Geometry) value);
4. ERROR in <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/src/main/java/org/geoserver/script/groovy/GroovyWpsHook.java&gt; (at line 96)
  return new geoscript.geom.Bounds((org.geotools.geometry.jts.ReferencedEnvelope) value);
geoscript cannot be resolved to a type
5. ERROR in <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/src/main/java/org/geoserver/script/groovy/GroovyWpsHook.java&gt; (at line 99)
  return new geoscript.layer.Layer((org.geotools.feature.FeatureCollection) value);
6. ERROR in <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/src/main/java/org/geoserver/script/groovy/GroovyWpsHook.java&gt; (at line 112)
  if (value instanceof geoscript.geom.Geometry) {
7. ERROR in <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/src/main/java/org/geoserver/script/groovy/GroovyWpsHook.java&gt; (at line 114)
  return ((geoscript.geom.Geometry) value).getG();
Geometry cannot be resolved to a type
8. ERROR in <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/src/main/java/org/geoserver/script/groovy/GroovyWpsHook.java&gt; (at line 114)
9. ERROR in <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/src/main/java/org/geoserver/script/groovy/GroovyWpsHook.java&gt; (at line 116)
  else if (value instanceof geoscript.geom.Bounds) {
10. ERROR in <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/src/main/java/org/geoserver/script/groovy/GroovyWpsHook.java&gt; (at line 118)
  return ((geoscript.geom.Bounds) value).getEnv();
Bounds cannot be resolved to a type
11. ERROR in <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/src/main/java/org/geoserver/script/groovy/GroovyWpsHook.java&gt; (at line 118)
12. ERROR in <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/src/main/java/org/geoserver/script/groovy/GroovyWpsHook.java&gt; (at line 120)
  else if (value instanceof geoscript.layer.Layer) {
13. ERROR in <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/src/main/java/org/geoserver/script/groovy/GroovyWpsHook.java&gt; (at line 122)
  return ((geoscript.layer.Layer) value).getFs().getFeatures();
Layer cannot be resolved to a type
14. ERROR in <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/src/main/java/org/geoserver/script/groovy/GroovyWpsHook.java&gt; (at line 122)
15. ERROR in <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/src/main/java/org/geoserver/script/groovy/GroovyWpsHook.java&gt; (at line 124)
  else if (value instanceof geoscript.layer.Cursor) {
16. ERROR in <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/src/main/java/org/geoserver/script/groovy/GroovyWpsHook.java&gt; (at line 126)
  return ((geoscript.layer.Cursor) value).getCol();
Cursor cannot be resolved to a type
17. ERROR in <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/src/main/java/org/geoserver/script/groovy/GroovyWpsHook.java&gt; (at line 126)
18. ERROR in <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/src/main/java/org/geoserver/script/groovy/GroovyFunctionHook.java&gt; (at line 30)
  newArgs.add(geoscript.geom.Geometry.wrap((com.vividsolutions.jts.geom.Geometry) arg));
19. ERROR in <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/src/main/java/org/geoserver/script/groovy/GroovyFunctionHook.java&gt; (at line 40)
  if (result instanceof geoscript.geom.Geometry) {
20. ERROR in <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/src/main/java/org/geoserver/script/groovy/GroovyFunctionHook.java&gt; (at line 41)
  return ((geoscript.geom.Geometry)result).getG();
21. ERROR in <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/src/main/groovy/geoserver/catalog/Store.groovy&gt; (at line 3)
  import geoscript.workspace.Workspace as GeoScriptWorkspace
Groovy:unable to resolve class geoscript.workspace.Workspace
22. ERROR in <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/src/main/groovy/geoserver/catalog/Layer.groovy&gt; (at line 3)
  import geoscript.layer.Layer as GeoScriptLayer
Groovy:unable to resolve class geoscript.layer.Layer
22 problems (22 errors)
[INFO] 1 error
[INFO] -------------------------------------------------------------
[ERROR] BUILD FAILURE
[INFO] Compilation failure
Failure executing groovy-eclipse compiler:
org.codehaus.groovy.control.messages.SyntaxErrorMessage@anonymised.com
<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/src/main/groovy/geoserver/catalog/Store.groovy&gt;: 3 Groovy:unable to resolve class geoscript.workspace.Workspace
<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/src/main/groovy/geoserver/catalog/Layer.groovy&gt;: 3 Groovy:unable to resolve class geoscript.layer.Layer
invalid Class-Path header in manifest of jar file: /usr/share/jetty/.m2/repository/org/restlet/org.restlet/1.0.8/org.restlet-1.0.8.jar
invalid Class-Path header in manifest of jar file: /usr/share/jetty/.m2/repository/com/noelios/restlet/com.noelios.restlet.ext.servlet/1.0.8/com.noelios.restlet.ext.servlet-1.0.8.jar
invalid Class-Path header in manifest of jar file: /usr/share/jetty/.m2/repository/com/noelios/restlet/com.noelios.restlet/1.0.8/com.noelios.restlet-1.0.8.jar
1. ERROR in <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/src/main/java/org/geoserver/script/groovy/GroovyWpsHook.java&gt; (at line 64)
2. ERROR in <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/src/main/java/org/geoserver/script/groovy/GroovyWpsHook.java&gt; (at line 79)
[INFO] Total time: 4 minutes 30 seconds
[INFO] Finished at: Mon Sep 09 04:05:06 UTC 2013
[INFO] Final Memory: 109M/426M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/master/geoserver-master-2013-09-09-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
See <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/1604/&gt;
