See <http://hudson.opengeo.org/hudson/job/geoserver-master-online/1145/>
[...truncated 18703 lines...]
20 Mar 04:21:04 ERROR [geoserver.ows] -
org.vfny.geoserver.wcs.WcsException: This request is trying to generate too much data, the limit is 1KB but the actual amount of bytes to be written in the output is 127.62KB
at org.vfny.geoserver.util.WCSUtils.checkOutputLimits(WCSUtils.java:320)
at org.geoserver.wcs.DefaultWebCoverageService111.getCoverage(DefaultWebCoverageService111.java:530)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:318)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:32)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
at $Proxy26.getCoverage(Unknown Source)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:774)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:272)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.geoserver.test.GeoServerSystemTestSupport$2.service(GeoServerSystemTestSupport.java:1355)
at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1374)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1309)
at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:921)
at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:904)
at org.geoserver.test.GeoServerSystemTestSupport.get(GeoServerSystemTestSupport.java:889)
at org.geoserver.test.GeoServerSystemTestSupport.getAsDOM(GeoServerSystemTestSupport.java:1186)
at org.geoserver.test.GeoServerSystemTestSupport.getAsDOM(GeoServerSystemTestSupport.java:1150)
at org.geoserver.wcs.GetCoverageTest.testOutputLimits(GetCoverageTest.java:355)
Tests run: 19, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.939 sec
Running org.geoserver.wcs.ResourceAccessManagerWCSTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.748 sec
Running org.geoserver.wcs.WCSDisabledTest
20 Mar 04:21:08 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: org.geoserver.platform.ServiceException: Service WCS is disabled
at org.geoserver.ows.DisabledServiceCheck.serviceDispatched(DisabledServiceCheck.java:62)
at org.geoserver.ows.Dispatcher.fireServiceDispatchedCallback(Dispatcher.java:527)
at org.geoserver.ows.Dispatcher.service(Dispatcher.java:522)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:250)
at org.geoserver.wcs.WCSDisabledTest.testDisabledServiceResponse(WCSDisabledTest.java:21)
Caused by: org.geoserver.platform.ServiceException: Service WCS is disabled
at org.geoserver.ows.DisabledServiceCheck.serviceDispatched(DisabledServiceCheck.java:57)
... 56 more
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.891 sec
Running org.geoserver.wcs.kvp.BoundingBoxKvpParserTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.027 sec
Running org.geoserver.wcs.kvp.GetCoverageReaderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.595 sec
Running org.geoserver.wcs.kvp.RangeSubsetKvpParserTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.012 sec
Running org.geoserver.wcs.xml.DescribeCoverageXmlParserTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.084 sec
Running org.geoserver.wcs.xml.GetCapabilitiesXmlParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.165 sec
Running org.geoserver.wcs.xml.GetCoverageXmlParserTest
class [Ljava.lang.Double;: [Ljava.lang.Double;@1cf4353
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.376 sec
Results :
Tests run: 85, Failures: 0, Errors: 0, Skipped: 0
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/wcs1_1/target/wcs1_1-2.4-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/wcs1_1/target/wcs1_1-2.4-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] [javacc:jjtree {execution: jjtree}]
[INFO] Nothing to process - all grammars in <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/wcs1_1/src/main/java/org/geoserver/wcs/kvp/rangesubset> are up to date.
[INFO] [javacc:javacc {execution: javacc}]
[INFO] Nothing to process - all grammars in <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/wcs1_1/target/generated-sources/jjtree> are up to date.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/wcs1_1/target/wcs1_1-2.4-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/wcs1_1/target/wcs1_1-2.4-SNAPSHOT-test-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/wcs1_1/target/wcs1_1-2.4-SNAPSHOT.jar> to /usr/share/jetty/.m2/repository/org/geoserver/wcs1_1/2.4-SNAPSHOT/wcs1_1-2.4-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/wcs1_1/target/wcs1_1-2.4-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/wcs1_1/2.4-SNAPSHOT/wcs1_1-2.4-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/wcs1_1/target/wcs1_1-2.4-SNAPSHOT-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/wcs1_1/2.4-SNAPSHOT/wcs1_1-2.4-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/wcs1_1/target/wcs1_1-2.4-SNAPSHOT-test-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/wcs1_1/2.4-SNAPSHOT/wcs1_1-2.4-SNAPSHOT-test-sources.jar
[INFO] Building Web Map Service KML output formats
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/kml/target>
[INFO] [GitCommitIdMojo] Running on '/var/lib/hudson/jobs/geoserver-master/workspace/.git' repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Adding placemark decorator for time
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 19.03.2013 @ 18:43:01 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 20-Mar-2013 04:08
[INFO] [GitCommitIdMojo] build.build.time = 20.03.2013 @ 04:21:12 UTC
[INFO] [GitCommitIdMojo] build.branch = 4739d7cb44ddad5a09516f1875cf4e25b6ce454e
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 4739d7c
[INFO] [GitCommitIdMojo] build.commit.id = 4739d7cb44ddad5a09516f1875cf4e25b6ce454e
[INFO] [GitCommitIdMojo] build.commit.message.full = Adding placemark decorator for time
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/kml/src/main/resources>
[INFO] Compiling 29 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/kml/target/classes>
[ERROR] COMPILATION ERROR :
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/kml/src/main/java/org/geoserver/kml/KMLMapTransformer.java>:\[985,36\] cannot find symbol
symbol : class FeatureTimeTemplate
location: class org.geoserver.kml.KMLMapTransformer.KMLMapTranslatorSupport
[INFO] 1 error
[ERROR] BUILD FAILURE
[INFO] Compilation failure
[INFO] Total time: 12 minutes 44 seconds
[INFO] Finished at: Wed Mar 20 04:21:17 UTC 2013
[INFO] Final Memory: 67M/296M
