See <http://hudson.opengeo.org/hudson/job/geoserver-master-online/1158/>
[...truncated 21571 lines...]
testGetFeatureInfo(org.geoserver.gwc.layer.GeoServerTileLayerTest) Time elapsed: 2 sec <<< ERROR!
java.lang.UnsupportedOperationException
at java.util.AbstractList.add(AbstractList.java:131)
at java.util.AbstractList.add(AbstractList.java:91)
at java.util.AbstractCollection.addAll(AbstractCollection.java:305)
at org.geoserver.gwc.layer.TileLayerInfoUtil.updateStringParameterFilter(TileLayerInfoUtil.java:167)
at org.geoserver.gwc.layer.TileLayerInfoUtil.setCachedStyles(TileLayerInfoUtil.java:140)
at org.geoserver.gwc.layer.TileLayerInfoUtil.checkAutomaticStyles(TileLayerInfoUtil.java:118)
at org.geoserver.gwc.layer.TileLayerInfoUtil.loadOrCreate(TileLayerInfoUtil.java:71)
at org.geoserver.gwc.layer.GeoServerTileLayer.<init>(GeoServerTileLayer.java:118)
at org.geoserver.gwc.layer.GeoServerTileLayerTest.testGetFeatureInfo(GeoServerTileLayerTest.java:413)
Running org.geoserver.gwc.layer.LegacyTileLayerInfoLoaderTest
Tests run: 5, Failures: 0, Errors: 2, Skipped: 0, Time elapsed: 0.001 sec <<< FAILURE!
testLoadLayerInfoExtraStyles(org.geoserver.gwc.layer.LegacyTileLayerInfoLoaderTest) Time elapsed: 0 sec <<< ERROR!
at org.geoserver.gwc.layer.LegacyTileLayerInfoLoaderTest.testLoadLayerInfoExtraStyles(LegacyTileLayerInfoLoaderTest.java:56)
testLoadLayerInfoAutoCacheStyles(org.geoserver.gwc.layer.LegacyTileLayerInfoLoaderTest) Time elapsed: 0 sec <<< ERROR!
at org.geoserver.gwc.layer.LegacyTileLayerInfoLoader.load(LegacyTileLayerInfoLoader.java:78)
at org.geoserver.gwc.layer.LegacyTileLayerInfoLoaderTest.testLoadLayerInfoAutoCacheStyles(LegacyTileLayerInfoLoaderTest.java:89)
Running org.geoserver.gwc.layer.TileLayerInfoUtilTest
Tests run: 6, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.001 sec <<< FAILURE!
testCreateLayerInfoAutoCacheStyles(org.geoserver.gwc.layer.TileLayerInfoUtilTest) Time elapsed: 0 sec <<< ERROR!
at org.geoserver.gwc.layer.TileLayerInfoUtilTest.testCreateLayerInfoAutoCacheStyles(TileLayerInfoUtilTest.java:83)
Running org.geoserver.gwc.wms.CachingExtendedCapabilitiesProviderTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.299 sec
Results :
Tests in error:
testAutoConfigureLayers(org.geoserver.gwc.GWCTest)
testTruncateByBounds(org.geoserver.gwc.GWCTest)
testModifyTileLayer(org.geoserver.gwc.GWCTest)
testModifyGridsetNoNeedToTruncate(org.geoserver.gwc.GWCTest)
testIsServiceEnabled(org.geoserver.gwc.GWCTest)
testTruncateByLayerAndStyle(org.geoserver.gwc.GWCTest)
testModifyGridsetPreconditions(org.geoserver.gwc.GWCTest)
testNullsInDimensionAndTimeParameters(org.geoserver.gwc.GWCTest)
testTruncateLayerFully(org.geoserver.gwc.GWCTest)
testRemoveTileLayers(org.geoserver.gwc.GWCTest)
testLayerRemoved(org.geoserver.gwc.GWCTest)
testLayerRenamed(org.geoserver.gwc.GWCTest)
testDispatchGetMapWithMatchingParameterFilters(org.geoserver.gwc.GWCTest)
testLayerAdded(org.geoserver.gwc.GWCTest)
testDispatchGetMapDoesntMatchTileCache(org.geoserver.gwc.GWCTest)
testReloadAndLayerRemovedExternally(org.geoserver.gwc.GWCTest)
testModifyGridsetTruncates(org.geoserver.gwc.GWCTest)
testRemoveAllLayerGridsetsDisablesLayer(org.geoserver.gwc.GWCTest)
testDeleteCacheByGridSetId(org.geoserver.gwc.GWCTest)
testDestroy(org.geoserver.gwc.GWCTest)
testDispatchGetMapNonMatchingParameterFilter(org.geoserver.gwc.GWCTest)
testAddGridset(org.geoserver.gwc.GWCTest)
testDispatchGetMapMultipleCrsMatchingGridSubsets(org.geoserver.gwc.GWCTest)
testReload(org.geoserver.gwc.GWCTest)
testIsInternalGridset(org.geoserver.gwc.GWCTest)
testRemoveGridsets(org.geoserver.gwc.GWCTest)
testLayerInfoAlternateStylesChanged(org.geoserver.gwc.layer.CatalogLayerEventListenerTest)
testRenameAlternateStyle(org.geoserver.gwc.layer.CatalogStyleChangeListenerTest)
testMarshallingParameterFilters(org.geoserver.gwc.layer.GeoServerTileLayerInfoPersistenceTest)
testGetModifiableParameters(org.geoserver.gwc.layer.GeoServerTileLayerTest)
testEnabled(org.geoserver.gwc.layer.GeoServerTileLayerTest)
testGetTilePreconditions(org.geoserver.gwc.layer.GeoServerTileLayerTest)
testGetGridSubsets(org.geoserver.gwc.layer.GeoServerTileLayerTest)
testGetParameterFilters(org.geoserver.gwc.layer.GeoServerTileLayerTest)
testGetMetaTilingFactors(org.geoserver.gwc.layer.GeoServerTileLayerTest)
testIsQueryable(org.geoserver.gwc.layer.GeoServerTileLayerTest)
testGetMetaInformation(org.geoserver.gwc.layer.GeoServerTileLayerTest)
testGetDefaultParameterFilters(org.geoserver.gwc.layer.GeoServerTileLayerTest)
testGetName(org.geoserver.gwc.layer.GeoServerTileLayerTest)
testGetTile(org.geoserver.gwc.layer.GeoServerTileLayerTest)
testGetMimeTypes(org.geoserver.gwc.layer.GeoServerTileLayerTest)
testGetStyles(org.geoserver.gwc.layer.GeoServerTileLayerTest)
Tests run: 136, Failures: 0, Errors: 46, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/gwc/target/surefire-reports> for the individual test results.
[INFO] Total time: 12 minutes 55 seconds
[INFO] Finished at: Tue Apr 02 13:32:53 UTC 2013
[INFO] Final Memory: 70M/320M
