[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-master-online #1196
See <http://hudson.opengeo.org/hudson/job/geoserver-master-online/1196/&gt;
[...truncated 19422 lines...]
  ValidateSchema = false
  Filter = null
  CQLFilter = null
  FeatureId = null
  Transparent = false
  Tiled = false
  TilesOrigin = null
  Palette = null
  Elevation =
  FeatureVersion = null
  RemoteOwsType = null
  RemoteOwsURL = null
  MaxFeatures = null
  StartIndex = null
  Angle = 0.0
  Version = 1.1.1
  Request = getmap
  RawKvp = {BBOX=-180,-90,180,90, VERSION=1.1.1, FORMAT=application/vnd.google-earth.kml xml, SERVICE=wms, HEIGHT=1024, REQUEST=getmap, LAYERS=cite:Bridges, STYLES=notthere, WIDTH=1024, SRS=EPSG:4326}
  Get = true
  BaseUrl = http://localhost:8080/geoserver/
  RequestCharset = UTF-8
10 May 04:20:36 INFO [geoserver.wms] -
Request: getServiceInfo
Request: getMap
  Time =
  Buffer = 0
  Layers = [org.geoserver.wms.MapLayerInfo@anonymised.com, org.geoserver.wms.MapLayerInfo@anonymised.com]
  Height = 1024
  Width = 1024
  Filters = null
  Styles = [StyleImpl[ name=notthere], StyleImpl[ name=BasicPolygons]]
  SRS = EPSG:4326
  Format = application/vnd.google-earth.kml xml
  Bbox = ReferencedEnvelope[-180.0 : 180.0, -90.0 : 90.0]
  BgColor = java.awt.Color[r=255,g=255,b=255]
  Crs = GEOGCS["WGS 84",
  DATUM["World Geodetic System 1984",
    SPHEROID["WGS 84", 6378137.0, 298.257223563, AUTHORITY["EPSG","7030"]],
    AUTHORITY["EPSG","6326"]],
  PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]],
  UNIT["degree", 0.017453292519943295],
  AXIS["Geodetic longitude", EAST],
  AXIS["Geodetic latitude", NORTH],
  AUTHORITY["EPSG","4326"]]
  Exceptions = SE_XML
  FormatOptions = {KMLTITLE=myCustomLayerTitle}
  Env = {}
  ViewParams = null
  Sld = null
  SldBody = null
  SldVersion = null
  Filter = null
  CQLFilter = null
  FeatureId = null
  Transparent = false
  Tiled = false
  TilesOrigin = null
  Palette = null
  Elevation =
  RemoteOwsURL = null
  MaxFeatures = null
  StartIndex = null
  Angle = 0.0
  Version = 1.1.1
  Request = getmap
  RawKvp = {BBOX=-180,-90,180,90, VERSION=1.1.1, FORMAT_OPTIONS=kmltitle:myCustomLayerTitle, FORMAT=application/vnd.google-earth.kml xml, SERVICE=wms, HEIGHT=1024, REQUEST=getmap, LAYERS=cite:Bridges,cite:BasicPolygons, STYLES=notthere,BasicPolygons, WIDTH=1024, SRS=EPSG:4326}
  Get = true
Request: getMap
  Time =
  Buffer = 0
  Layers = [org.geoserver.wms.MapLayerInfo@anonymised.com]
  Height = 1024
  Width = 1024
  Filters = null
  Styles = [StyleImpl[ name=BasicPolygons]]
  SRS = EPSG:4326
  Exceptions = SE_XML
  FormatOptions = {}
  Env = {}
  ViewParams = null
  Sld = null
  SldBody = null
  SldVersion = null
  Filter = null
  CQLFilter = null
  FeatureId = null
  Transparent = false
  Tiled = false
  TilesOrigin = null
  Palette = null
  Elevation =
  RemoteOwsURL = null
  MaxFeatures = null
  StartIndex = null
  Angle = 0.0
  Version = 1.1.1
  Request = getmap
  RawKvp = {BBOX=-180,-90,180,90, VERSION=1.1.1, FORMAT=application/vnd.google-earth.kml xml, SERVICE=wms, HEIGHT=1024, REQUEST=getmap, LAYERS=cite:BasicPolygons, STYLES=BasicPolygons, WIDTH=1024, SRS=EPSG:4326}
  Get = true
10 May 04:20:36 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: startup date [Fri May 10 04:20:34 UTC 2013]; root of context hierarchy
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.781 sec
Running org.geoserver.kml.KMLTransformerTest
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.48 sec
Running org.geoserver.kml.KMLVectorTransformerTest
10 May 04:20:39 ERROR [geotools.map] - Call MapContent dispose() to prevent memory leaks
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.033 sec
Running org.geoserver.kml.KMZMapProducerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.381 sec
Results :
Tests run: 54, Failures: 0, Errors: 0, Skipped: 0
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/kml/target/kml-2.4-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/kml/target/kml-2.4-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/kml/target/kml-2.4-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/kml/target/kml-2.4-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/kml/target/kml-2.4-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/kml/2.4-SNAPSHOT/kml-2.4-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/kml/target/kml-2.4-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/kml/2.4-SNAPSHOT/kml-2.4-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/kml/target/kml-2.4-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/kml/2.4-SNAPSHOT/kml-2.4-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/kml/target/kml-2.4-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/kml/2.4-SNAPSHOT/kml-2.4-SNAPSHOT-test-sources.jar
[INFO] Building GeoWebCache (GWC) Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/gwc/target&gt;
[INFO] [GitCommitIdMojo] Running on '/var/lib/hudson/jobs/geoserver-master/workspace/.git' repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = GEOS-5803, using proper name for storage parameter
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 09.05.2013 @ 15:57:51 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 10-May-2013 04:08
[INFO] [GitCommitIdMojo] build.build.time = 10.05.2013 @ 04:20:40 UTC
[INFO] [GitCommitIdMojo] build.branch = eb78a0bff82fea38108565580318edc0103498e2
[INFO] [GitCommitIdMojo] build.commit.user.email = jdeolive@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = jdeolive
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = eb78a0b
[INFO] [GitCommitIdMojo] build.commit.id = eb78a0bff82fea38108565580318edc0103498e2
[INFO] [GitCommitIdMojo] build.commit.message.full = GEOS-5803, using proper name for storage parameter
[INFO] Copying 0 resource
[INFO] Copying 13 resources
[INFO] snapshot org.geowebcache:gwc-core:1.4-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-core:1.4-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:geowebcache:1.4-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:geowebcache:1.4-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-georss:1.4-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-georss:1.4-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-gmaps:1.4-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-gmaps:1.4-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-kml:1.4-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-kml:1.4-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-rest:1.4-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-rest:1.4-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-tms:1.4-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-tms:1.4-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-ve:1.4-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-ve:1.4-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-wms:1.4-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-wms:1.4-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-wmts:1.4-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-wmts:1.4-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-diskquota-jdbc:1.4-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-diskquota-jdbc:1.4-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-diskquota:1.4-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-diskquota:1.4-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-diskquota-core:1.4-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-diskquota-core:1.4-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-diskquota-core:1.4-SNAPSHOT: checking for updates from codehaus
[INFO] snapshot org.geowebcache:gwc-diskquota-core:1.4-SNAPSHOT: checking for updates from oracleReleases
[INFO] Compiling 36 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/gwc/target/classes&gt;
[WARNING] COMPILATION WARNING :
[WARNING] <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStoreProvider.java&gt;:\[24,33\] sun.reflect.generics.scope.DummyScope is Sun proprietary API and may be removed in a future release
[INFO] 1 warning
[ERROR] COMPILATION ERROR :
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/gwc/src/main/java/org/geoserver/gwc/layer/GeoServerTileLayer.java&gt;:\[75,7\] org.geoserver.gwc.layer.GeoServerTileLayer is not abstract and does not override abstract method getInfoMimeTypes() in org.geowebcache.layer.TileLayer
[INFO] 1 error
[ERROR] BUILD FAILURE
[INFO] Compilation failure
[INFO] Total time: 12 minutes 24 seconds
[INFO] Finished at: Fri May 10 04:20:48 UTC 2013
[INFO] Final Memory: 70M/326M
See <http://hudson.opengeo.org/hudson/job/geoserver-master-online/1197/&gt;
[...truncated 19405 lines...]
  Filter = null
  CQLFilter = null
  FeatureId = null
  Transparent = false
  Tiled = false
  TilesOrigin = null
  Palette = null
  Elevation =
  RemoteOwsURL = null
  MaxFeatures = null
  StartIndex = null
  Angle = 0.0
  Version = 1.1.1
  Request = getmap
  Get = true
11 May 04:21:08 INFO [geoserver.wms] -
Request: getMap
  Time =
  Buffer = 0
  Height = 1024
  Width = 1024
  Filters = null
  SRS = EPSG:4326
  Exceptions = SE_XML
  Env = {}
  ViewParams = null
  Sld = null
  SldBody = null
  SldVersion = null
  Filter = null
  CQLFilter = null
  FeatureId = null
  Transparent = false
  Tiled = false
  TilesOrigin = null
  Palette = null
  Elevation =
  RemoteOwsURL = null
  MaxFeatures = null
  StartIndex = null
  Angle = 0.0
  Version = 1.1.1
  Request = getmap
  Get = true
11 May 04:21:09 INFO [geoserver.wms] -
Request: getMap
  Time =
  Buffer = 0
  Height = 1024
  Width = 1024
  Filters = null
  SRS = EPSG:4326
  Exceptions = SE_XML
  FormatOptions = {}
  Env = {}
  ViewParams = null
  Sld = null
  SldBody = null
  SldVersion = null
  Filter = null
  CQLFilter = null
  FeatureId = null
  Transparent = false
  Tiled = false
  TilesOrigin = null
  Palette = null
  Elevation =
  RemoteOwsURL = null
  MaxFeatures = null
  StartIndex = null
  Angle = 0.0
  Version = 1.1.1
  Request = getmap
  Get = true
11 May 04:21:09 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: startup date [Sat May 11 04:21:06 UTC 2013]; root of context hierarchy
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.572 sec
11 May 04:21:11 ERROR [geotools.map] - Call MapContent dispose() to prevent memory leaks
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.403 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.036 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.627 sec
Results :
[INFO] [GitCommitIdMojo] build.commit.message.short = factored out script reading and execution into util class, and added optional (ignore failure) statements
[INFO] [GitCommitIdMojo] build.commit.time = 10.05.2013 @ 18:08:17 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 11-May-2013 04:08
[INFO] [GitCommitIdMojo] build.build.time = 11.05.2013 @ 04:21:13 UTC
[INFO] [GitCommitIdMojo] build.branch = 5bbbd1f3ac589d29e6d1714e71ac7b0d5a222b0a
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 5bbbd1f
[INFO] [GitCommitIdMojo] build.commit.id = 5bbbd1f3ac589d29e6d1714e71ac7b0d5a222b0a
[INFO] [GitCommitIdMojo] build.commit.message.full = factored out script reading and execution into util class, and added optional (ignore failure) statements
[INFO] 1 warning
[INFO] 1 error
[INFO] Total time: 12 minutes 36 seconds
[INFO] Finished at: Sat May 11 04:21:21 UTC 2013
[INFO] Final Memory: 70M/321M
See <http://hudson.opengeo.org/hudson/job/geoserver-master-online/1198/&gt;
[...truncated 19438 lines...]
  SldVersion = null
  Filter = null
  CQLFilter = null
  FeatureId = null
  Transparent = false
  Tiled = false
  TilesOrigin = null
  Palette = null
  Elevation =
  RemoteOwsURL = null
  MaxFeatures = null
  StartIndex = null
  Angle = 0.0
  Version = 1.1.1
  Request = getmap
  Get = true
12 May 04:20:57 INFO [geoserver.wms] -
Request: getMap
  Time =
  Buffer = 0
  Height = 1024
  Width = 1024
  Filters = null
  SRS = EPSG:4326
  Exceptions = SE_XML
  Env = {}
  ViewParams = null
  Sld = null
  SldBody = null
  SldVersion = null
  Filter = null
  CQLFilter = null
  FeatureId = null
  Transparent = false
  Tiled = false
  TilesOrigin = null
  Palette = null
  Elevation =
  RemoteOwsURL = null
  MaxFeatures = null
  StartIndex = null
  Angle = 0.0
  Version = 1.1.1
  Request = getmap
  Get = true
Request: getMap
  Time =
  Buffer = 0
  Height = 1024
  Width = 1024
  Filters = null
  SRS = EPSG:4326
  Exceptions = SE_XML
  FormatOptions = {}
  Env = {}
  ViewParams = null
  Sld = null
  SldBody = null
  SldVersion = null
  Filter = null
  CQLFilter = null
  FeatureId = null
  Transparent = false
  Tiled = false
  TilesOrigin = null
  Palette = null
  Elevation =
  RemoteOwsURL = null
  MaxFeatures = null
  StartIndex = null
  Angle = 0.0
  Version = 1.1.1
  Request = getmap
  Get = true
12 May 04:20:57 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: startup date [Sun May 12 04:20:55 UTC 2013]; root of context hierarchy
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.97 sec
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.128 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.035 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.036 sec
Results :
[INFO] [GitCommitIdMojo] build.timestamp = 12-May-2013 04:08
[INFO] [GitCommitIdMojo] build.build.time = 12.05.2013 @ 04:21:01 UTC
[INFO] 1 warning
[INFO] 1 error
[INFO] Total time: 12 minutes 27 seconds
[INFO] Finished at: Sun May 12 04:21:08 UTC 2013
See <http://hudson.opengeo.org/hudson/job/geoserver-master-online/1199/&gt;
[...truncated 19473 lines...]
  Filter = null
  CQLFilter = null
  FeatureId = null
  Transparent = false
  Tiled = false
  TilesOrigin = null
  Palette = null
  Elevation =
  RemoteOwsURL = null
  MaxFeatures = null
  StartIndex = null
  Angle = 0.0
  Version = 1.1.1
  Request = getmap
  Get = true
13 May 04:21:36 INFO [geoserver.wms] -
Request: getMap
  Time =
  Buffer = 0
  Height = 1024
  Width = 1024
  Filters = null
  SRS = EPSG:4326
  Exceptions = SE_XML
  Env = {}
  ViewParams = null
  Sld = null
  SldBody = null
  SldVersion = null
  Filter = null
  CQLFilter = null
  FeatureId = null
  Transparent = false
  Tiled = false
  TilesOrigin = null
  Palette = null
  Elevation =
  RemoteOwsURL = null
  MaxFeatures = null
  StartIndex = null
  Angle = 0.0
  Version = 1.1.1
  Request = getmap
  Get = true
Request: getMap
  Time =
  Buffer = 0
  Height = 1024
  Width = 1024
  Filters = null
  SRS = EPSG:4326
  Exceptions = SE_XML
  FormatOptions = {}
  Env = {}
  ViewParams = null
  Sld = null
  SldBody = null
  SldVersion = null
  Filter = null
  CQLFilter = null
  FeatureId = null
  Transparent = false
  Tiled = false
  TilesOrigin = null
  Palette = null
  Elevation =
  RemoteOwsURL = null
  MaxFeatures = null
  StartIndex = null
  Angle = 0.0
  Version = 1.1.1
  Request = getmap
  Get = true
13 May 04:21:37 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: startup date [Mon May 13 04:21:34 UTC 2013]; root of context hierarchy
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.571 sec
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.33 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.043 sec
13 May 04:21:39 ERROR [geotools.map] - Call MapContent dispose() to prevent memory leaks
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.001 sec
Results :
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #233 from martin-sucha/fix-comments-hack
[INFO] [GitCommitIdMojo] build.commit.time = 12.05.2013 @ 15:04:43 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 13-May-2013 04:08
[INFO] [GitCommitIdMojo] build.build.time = 13.05.2013 @ 04:21:40 UTC
[INFO] [GitCommitIdMojo] build.branch = e1c449c47ea23d644d5dd9621ec7b053e255b14a
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = e1c449c
[INFO] [GitCommitIdMojo] build.commit.id = e1c449c47ea23d644d5dd9621ec7b053e255b14a
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #233 from martin-sucha/fix-comments-hack
Remove hacks for comments in WMS capabilities.
[INFO] 1 warning
[INFO] 1 error
[INFO] Total time: 13 minutes 5 seconds
[INFO] Finished at: Mon May 13 04:21:55 UTC 2013
[INFO] Final Memory: 71M/306M
See <http://hudson.opengeo.org/hudson/job/geoserver-master-online/1200/&gt;
  SldVersion = null
  Filter = null
  CQLFilter = null
  FeatureId = null
  Transparent = false
  Tiled = false
  TilesOrigin = null
  Palette = null
  Elevation =
  RemoteOwsURL = null
  MaxFeatures = null
  StartIndex = null
  Angle = 0.0
  Version = 1.1.1
  Request = getmap
  Get = true
14 May 04:20:46 INFO [geoserver.wms] -
Request: getMap
  Time =
  Buffer = 0
  Height = 1024
  Width = 1024
  Filters = null
  SRS = EPSG:4326
  Exceptions = SE_XML
  Env = {}
  ViewParams = null
  Sld = null
  SldBody = null
  SldVersion = null
  Filter = null
  CQLFilter = null
  FeatureId = null
  Transparent = false
  Tiled = false
  TilesOrigin = null
  Palette = null
  Elevation =
  RemoteOwsURL = null
  MaxFeatures = null
  StartIndex = null
  Angle = 0.0
  Version = 1.1.1
  Request = getmap
  Get = true
Request: getMap
  Time =
  Buffer = 0
  Height = 1024
  Width = 1024
  Filters = null
  SRS = EPSG:4326
  Exceptions = SE_XML
  FormatOptions = {}
  Env = {}
  ViewParams = null
  Sld = null
  SldBody = null
  SldVersion = null
  Filter = null
  CQLFilter = null
  FeatureId = null
  Transparent = false
  Tiled = false
  TilesOrigin = null
  Palette = null
  Elevation =
  RemoteOwsURL = null
  MaxFeatures = null
  StartIndex = null
  Angle = 0.0
  Version = 1.1.1
  Request = getmap
  Get = true
14 May 04:20:46 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: startup date [Tue May 14 04:20:44 UTC 2013]; root of context hierarchy
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.314 sec
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.438 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.046 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.523 sec
Results :
[INFO] [GitCommitIdMojo] build.commit.message.short = GEOS-5618: Remove references to getID() as they break feature chaining with joining.
[INFO] [GitCommitIdMojo] build.commit.time = 13.05.2013 @ 05:43:33 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 14-May-2013 04:08
[INFO] [GitCommitIdMojo] build.build.time = 14.05.2013 @ 04:20:50 UTC
[INFO] [GitCommitIdMojo] build.branch = 08f60336f8e5ef7cbbc52ad959a868afcaf4086f
[INFO] [GitCommitIdMojo] build.commit.user.email = rini.angreani@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = RiniAngreani
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 08f6033
[INFO] [GitCommitIdMojo] build.commit.id = 08f60336f8e5ef7cbbc52ad959a868afcaf4086f
[INFO] [GitCommitIdMojo] build.commit.message.full = GEOS-5618: Remove references to getID() as they break feature chaining with joining.
[INFO] 1 warning
[INFO] 1 error
[INFO] Total time: 12 minutes 23 seconds
[INFO] Finished at: Tue May 14 04:20:58 UTC 2013
[INFO] Final Memory: 70M/293M
See <http://hudson.opengeo.org/hudson/job/geoserver-master-online/1201/&gt;
