[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-master-online #1204
See <http://hudson.opengeo.org/hudson/job/geoserver-master-online/1204/&gt;
[...truncated 16116 lines...]
18 May 05:08:09 WARN [bootstrap.BootstrapAttributeTypeRegistry] - Attribute subtreeMinimumQuality does not have normalizer : using NoopNormalizer
18 May 05:08:09 WARN [bootstrap.BootstrapAttributeTypeRegistry] - Attribute supportedAlgorithms does not have normalizer : using NoopNormalizer
18 May 05:08:09 WARN [bootstrap.BootstrapAttributeTypeRegistry] - Attribute namingContexts does not have normalizer : using NoopNormalizer
18 May 05:08:09 WARN [bootstrap.BootstrapAttributeTypeRegistry] - Attribute deltaRevocationList does not have normalizer : using NoopNormalizer
18 May 05:08:09 WARN [bootstrap.BootstrapAttributeTypeRegistry] - Attribute c-TelexNumber does not have normalizer : using NoopNormalizer
18 May 05:08:09 WARN [bootstrap.BootstrapAttributeTypeRegistry] - Attribute mailPreferenceOption does not have normalizer : using NoopNormalizer
18 May 05:08:09 WARN [bootstrap.BootstrapAttributeTypeRegistry] - Attribute altServer does not have normalizer : using NoopNormalizer
18 May 05:08:09 WARN [bootstrap.BootstrapAttributeTypeRegistry] - Attribute supportedExtension does not have normalizer : using NoopNormalizer
18 May 05:08:09 WARN [bootstrap.BootstrapAttributeTypeRegistry] - Attribute dSAQuality does not have normalizer : using NoopNormalizer
18 May 05:08:09 WARN [bootstrap.BootstrapAttributeTypeRegistry] - Attribute facsimileTelephoneNumber does not have normalizer : using NoopNormalizer
18 May 05:08:09 WARN [bootstrap.BootstrapAttributeTypeRegistry] - Attribute preferredDeliveryMethod does not have normalizer : using NoopNormalizer
18 May 05:08:09 WARN [bootstrap.BootstrapAttributeTypeRegistry] - Attribute byteCode does not have normalizer : using NoopNormalizer
18 May 05:08:09 WARN [bootstrap.BootstrapAttributeTypeRegistry] - Attribute telexNumber does not have normalizer : using NoopNormalizer
18 May 05:08:09 WARN [bootstrap.BootstrapAttributeTypeRegistry] - Attribute teletexTerminalIdentifier does not have normalizer : using NoopNormalizer
18 May 05:08:09 WARN [bootstrap.BootstrapAttributeTypeRegistry] - Attribute cACertificate does not have normalizer : using NoopNormalizer
18 May 05:08:09 WARN [bootstrap.BootstrapAttributeTypeRegistry] - Attribute userCertificate does not have normalizer : using NoopNormalizer
18 May 05:08:09 WARN [bootstrap.BootstrapAttributeTypeRegistry] - Attribute certificateRevocationList does not have normalizer : using NoopNormalizer
18 May 05:08:09 WARN [bootstrap.BootstrapAttributeTypeRegistry] - Attribute authorityRevocationList does not have normalizer : using NoopNormalizer
18 May 05:08:09 WARN [bootstrap.BootstrapAttributeTypeRegistry] - Attribute subtreeSpecification does not have normalizer : using NoopNormalizer
18 May 05:08:09 WARN [bootstrap.BootstrapAttributeTypeRegistry] - Attribute javaSerializedData does not have normalizer : using NoopNormalizer
18 May 05:08:09 WARN [bootstrap.BootstrapAttributeTypeRegistry] - Attribute searchGuide does not have normalizer : using NoopNormalizer
18 May 05:08:09 WARN [bootstrap.BootstrapAttributeTypeRegistry] - Attribute photo does not have normalizer : using NoopNormalizer
18 May 05:08:09 WARN [bootstrap.BootstrapAttributeTypeRegistry] - Attribute supportedControl does not have normalizer : using NoopNormalizer
18 May 05:08:09 WARN [bootstrap.BootstrapAttributeTypeRegistry] - Attribute supportedSASLMechanisms does not have normalizer : using NoopNormalizer
18 May 05:08:09 WARN [bootstrap.BootstrapAttributeTypeRegistry] - Attribute supportedLDAPVersion does not have normalizer : using NoopNormalizer
18 May 05:08:09 WARN [bootstrap.BootstrapAttributeTypeRegistry] - Attribute dynamicSubtrees does not have normalizer : using NoopNormalizer
18 May 05:08:09 WARN [bootstrap.BootstrapAttributeTypeRegistry] - Attribute entryTtl does not have normalizer : using NoopNormalizer
18 May 05:08:09 WARN [bootstrap.BootstrapAttributeTypeRegistry] - Attribute userPKCS12 does not have normalizer : using NoopNormalizer
18 May 05:08:09 WARN [bootstrap.BootstrapAttributeTypeRegistry] - Attribute userSMIMECertificate does not have normalizer : using NoopNormalizer
18 May 05:08:09 WARN [bootstrap.BootstrapAttributeTypeRegistry] - Attribute otherMailbox does not have normalizer : using NoopNormalizer
18 May 05:08:09 WARN [btree.BTreePartition] - Using default cache size of 100 for index on attribute 1.3.6.1.4.1.18060.0.4.1.2.2
18 May 05:08:09 WARN [btree.BTreePartition] - Using default cache size of 100 for index on attribute 1.3.6.1.4.1.18060.0.4.1.2.3
18 May 05:08:09 WARN [btree.BTreePartition] - Using default cache size of 100 for index on attribute objectClass
18 May 05:08:09 WARN [btree.BTreePartition] - Using default cache size of 100 for index on attribute 1.3.6.1.4.1.18060.0.4.1.2.1
18 May 05:08:09 WARN [btree.BTreePartition] - Using default cache size of 100 for index on attribute 1.3.6.1.4.1.18060.0.4.1.2.6
18 May 05:08:09 WARN [btree.BTreePartition] - Using default cache size of 100 for index on attribute 1.3.6.1.4.1.18060.0.4.1.2.7
18 May 05:08:09 WARN [btree.BTreePartition] - Using default cache size of 100 for index on attribute 1.3.6.1.4.1.18060.0.4.1.2.4
18 May 05:08:09 WARN [btree.BTreePartition] - Using default cache size of 100 for index on attribute 1.3.6.1.4.1.18060.0.4.1.2.5
18 May 05:08:09 WARN [jdbm.JdbmPartition] - Using the default entry cache size of 10000 for test partition
18 May 05:08:09 WARN [core.DefaultDirectoryService] - You didn't change the admin password of directory service instance 'default'. Please update the admin password as soon as possible to prevent a possible security breach.
18 May 05:08:09 ERROR [jndi.ServerContextFactory] - Failed to bind an LDAP service (10389) to the service registry.
java.net.BindException: Address already in use
  at sun.nio.ch.Net.bind(Native Method)
  at sun.nio.ch.ServerSocketChannelImpl.bind(ServerSocketChannelImpl.java:119)
  at sun.nio.ch.ServerSocketAdaptor.bind(ServerSocketAdaptor.java:59)
  at org.apache.mina.transport.socket.nio.SocketAcceptor.registerNew(SocketAcceptor.java:429)
  at org.apache.mina.transport.socket.nio.SocketAcceptor.access$900(SocketAcceptor.java:52)
  at org.apache.mina.transport.socket.nio.SocketAcceptor$Worker.run(SocketAcceptor.java:258)
  at org.apache.mina.util.NamePreservingRunnable.run(NamePreservingRunnable.java:43)
  at java.lang.Thread.run(Thread.java:619)
Tests run: 5, Failures: 0, Errors: 3, Skipped: 0, Time elapsed: 13.237 sec <<< FAILURE!
testBindBeforeGroupSearch(org.geoserver.security.ldap.LDAPAuthenticationProviderTest) Time elapsed: 1748 sec <<< ERROR!
org.apache.directory.shared.ldap.exception.LdapConfigurationException: Failed to bind an LDAP service (10389) to the service registry. [Root exception is java.net.BindException: Address already in use]
  at org.apache.directory.server.jndi.ServerContextFactory.startLDAP0(ServerContextFactory.java:499)
  at org.apache.directory.server.jndi.ServerContextFactory.startLDAP(ServerContextFactory.java:413)
  at org.apache.directory.server.jndi.ServerContextFactory.afterStartup(ServerContextFactory.java:212)
  at org.apache.directory.server.core.DefaultDirectoryService.startup(DefaultDirectoryService.java:239)
  at org.apache.directory.server.core.jndi.AbstractContextFactory.getInitialContext(AbstractContextFactory.java:118)
  at javax.naming.spi.NamingManager.getInitialContext(NamingManager.java:667)
  at javax.naming.InitialContext.getDefaultInitCtx(InitialContext.java:288)
  at javax.naming.InitialContext.init(InitialContext.java:223)
  at javax.naming.InitialContext.<init>(InitialContext.java:197)
  at javax.naming.directory.InitialDirContext.<init>(InitialDirContext.java:82)
  at org.geoserver.security.ldap.LDAPAuthenticationProviderTest.startApacheDirectoryServer(LDAPAuthenticationProviderTest.java:125)
  at org.geoserver.security.ldap.LDAPAuthenticationProviderTest.initLdapServer(LDAPAuthenticationProviderTest.java:66)
  at org.geoserver.security.ldap.LDAPAuthenticationProviderTest.testBindBeforeGroupSearch(LDAPAuthenticationProviderTest.java:197)
Caused by: java.net.BindException: Address already in use
testGroupAdminGroup(org.geoserver.security.ldap.LDAPAuthenticationProviderTest) Time elapsed: 3234 sec <<< ERROR!
  at org.geoserver.security.ldap.LDAPAuthenticationProviderTest.testGroupAdminGroup(LDAPAuthenticationProviderTest.java:290)
testUserFilterAndFormat(org.geoserver.security.ldap.LDAPAuthenticationProviderTest) Time elapsed: 1630 sec <<< ERROR!
  at org.geoserver.security.ldap.LDAPAuthenticationProviderTest.testUserFilterAndFormat(LDAPAuthenticationProviderTest.java:244)
Results :
Tests in error:
  testBindBeforeGroupSearch(org.geoserver.security.ldap.LDAPAuthenticationProviderTest): Failed to bind an LDAP service (10389) to the service registry.
  testGroupAdminGroup(org.geoserver.security.ldap.LDAPAuthenticationProviderTest): Failed to bind an LDAP service (10389) to the service registry.
  testUserFilterAndFormat(org.geoserver.security.ldap.LDAPAuthenticationProviderTest): Failed to bind an LDAP service (10389) to the service registry.
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/security/ldap/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 11 minutes 58 seconds
[INFO] Finished at: Sat May 18 05:08:10 UTC 2013
[INFO] Final Memory: 66M/318M
See <http://hudson.opengeo.org/hudson/job/geoserver-master-online/1205/&gt;
