See <http://hudson.opengeo.org/hudson/job/geoserver-master-online/1230/>
Started by timer
[src] $ /opt/apache-maven-2.2.1/bin/mvn -U -Djava.awt.headless=true -Dtest.maxHeapSize=256M -P allExtensions,owsRemoteTests clean install -DconfigDirectory=../../../data
[INFO] Scanning for projects...
[WARNING]
Profile with id: 'owsRemoteTests' has not been activated.
[INFO] Reactor build order:
[INFO] GeoServer
[INFO] Core Platform Module
[INFO] Open Web Service Module
[INFO] Main Module
[INFO] Web Feature Service Module
[INFO] Web Coverage Service Module
[INFO] Web Map Service Module
[INFO] GeoServer Web Modules
[INFO] Core UI Module
[INFO] Security UI Module
[INFO] GeoServer Security Modules
[INFO] GeoServer JDBC Security Module
[INFO] GeoServer LDAP Security Module
[INFO] Web Coverage Service 1.0 Module
[INFO] Web Coverage Service 1.1 Module
[INFO] Web Map Service KML output formats
[INFO] GeoWebCache (GWC) Module
[INFO] REST Support Module
[INFO] REST Configuration Service Module
[INFO] WMS UI Module
[INFO] GWC UI Module
[INFO] WFS UI Module
[INFO] Demoes Module
[INFO] WCS UI Module
[INFO] GeoServer Web Application
[INFO] Community Space
[INFO] GeoServer Extensions
[INFO] Application Schema Support
[INFO] Application Schema Integration Test
[INFO] Sample DataAccess Integration Test
[INFO] ArcSDE DataStore Extension
[INFO] GeoSearch Index Module
[INFO] H2 DataStore Extension
[INFO] SQL Server DataStore Extension
[INFO] Oracle DataStore Extension
[INFO] MySQL DataStore Extension
[INFO] DB2 DataStore Extension
[INFO] ImageMap Output Format
[INFO] ImageI/O-Ext GDAL Coverage Extension
[INFO] JP2K Coverage Extension
[INFO] ogr2ogr Output Format
[INFO] Excel Output Format
[INFO] Validation Module
[INFO] Chart external graphics support
[INFO] Feature Generalization Extension
[INFO] Image Mosaic JDBC Extension
[INFO] OWS request flow controller
[INFO] Web Processing Service parent
[INFO] Web Processing Service Module
[INFO] Web Processing Service GUI
[INFO] GeoServer Layer Querying filter functions
[INFO] Teradata DataStore Extension
[INFO] GeoServer Monitor Extensions
[INFO] Core Monitor Extension
[INFO] Monitor Hibernate Extension
[INFO] GeoServer CAS Security Module
[INFO] GeoServer Security Extension Modules
[INFO] XLST based WFS output format
[INFO] GeoServer INSPIRE Extensions
[INFO] Building GeoServer
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] Running on '/var/lib/hudson/jobs/geoserver-master/workspace/.git' repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = KML 2 superoverlay refactor and tests
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 12.06.2013 @ 18:42:19 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 13-Jun-2013 04:01
[INFO] [GitCommitIdMojo] build.build.time = 13.06.2013 @ 04:01:16 UTC
[INFO] [GitCommitIdMojo] build.branch = 53410366a32420f26bcafb13f168129c0f867d6e
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 5341036
[INFO] [GitCommitIdMojo] build.commit.id = 53410366a32420f26bcafb13f168129c0f867d6e
[INFO] [GitCommitIdMojo] build.commit.message.full = KML 2 superoverlay refactor and tests
[INFO] [site:attach-descriptor {execution: default-attach-descriptor}]
[INFO] snapshot org.geotools:gt-api:10-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-api:10-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:library:10-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:library:10-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:modules:10-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:modules:10-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/modules/10-SNAPSHOT/modules-10-20130612.055210-79.pom
[ERROR] BUILD ERROR
[INFO] Error building POM (may not be this project's POM).
Project ID: org.geotools:library:pom:null
Reason: Cannot find parent: org.geotools:modules for project: org.geotools:library:pom:null for project org.geotools:library:pom:null
[INFO] Total time: 14 seconds
[INFO] Finished at: Thu Jun 13 04:01:20 UTC 2013
[INFO] Final Memory: 35M/364M
