[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-master-online #1289
See <http://hudson.opengeo.org/hudson/job/geoserver-master-online/1289/&gt;
[...truncated 17253 lines...]
  at sun.reflect.GeneratedMethodAccessor160.invoke(Unknown Source)
  at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:24)
Caused by: java.io.FileNotFoundException: ./target/default248449168276168999data/workspaces/cdf/cdf/Updates/featuretype.xml.tmp (No such file or directory)
  at java.io.FileOutputStream.open(Native Method)
  at java.io.FileOutputStream.<init>(FileOutputStream.java:179)
  at java.io.FileOutputStream.<init>(FileOutputStream.java:131)
  at org.geoserver.data.util.IOUtils.xStreamPersist(IOUtils.java:411)
  at org.geoserver.config.GeoServerPersister.persist(GeoServerPersister.java:786)
  ... 48 more
testAddModify(org.geoserver.security.web.usergroup.XMLUserGroupConfigDetailsPanelTest) Time elapsed: 125 sec <<< ERROR!
java.lang.IllegalStateException: you can only locate or create sessions in the context of a request cycle
  at org.apache.wicket.Session.findOrCreate(Session.java:208)
  at org.apache.wicket.Session.get(Session.java:252)
  at org.geoserver.web.GeoServerWicketTestSupport.clearErrorMessages(GeoServerWicketTestSupport.java:43)
  at sun.reflect.GeneratedMethodAccessor162.invoke(Unknown Source)
  at org.junit.internal.runners.statements.RunAfters.evaluate(RunAfters.java:33)
testRemove(org.geoserver.security.web.usergroup.XMLUserGroupConfigDetailsPanelTest) Time elapsed: 1 sec <<< ERROR!
java.lang.NullPointerException
  at org.geoserver.test.GeoServerSystemTestSupport.getSecurityManager(GeoServerSystemTestSupport.java:365)
  at org.geoserver.security.web.AbstractSecurityWicketTestSupport.setUp(AbstractSecurityWicketTestSupport.java:92)
  at sun.reflect.GeneratedMethodAccessor173.invoke(Unknown Source)
Results :
Failed tests: testAddModifyRemove(org.geoserver.security.web.auth.UsernamePasswordDetailsPanelTest): expected:<AuthenticationPage> but was:<SecurityNamedServiceEditPage>
  testFill(org.geoserver.security.web.group.NewGroupPageTest): expected:<SecurityNamedServiceEditPage> but was:<NewGroupPage>
  testAddModify(org.geoserver.security.web.passwd.MasterPasswordProviderPanelTest): expected:<PasswordPage> but was:<SecurityNamedServiceEditPage>
  testAddModify(org.geoserver.security.web.passwd.PasswordPolicyDetailsPanelTest): expected:<PasswordPage> but was:<SecurityNamedServiceEditPage>
  testAddModifyRemove(org.geoserver.security.web.role.XMLRoleConfigDetailsPanelTest): expected:<UserGroupRoleServicesPage> but was:<SecurityNamedServiceNewPage>
Tests in error:
  testAllServicesReadOnly(org.geoserver.security.web.group.EditGroupPageTest): com.thoughtworks.xstream.io.StreamException: : Disk quota exceeded
  testReadOnlyUserGroupService(org.geoserver.security.web.group.EditGroupPageTest): : Disk quota exceeded
  testReadOnlyRoleService(org.geoserver.security.web.group.EditGroupPageTest): : Disk quota exceeded
  testNew(org.geoserver.security.web.group.GroupListPageTest): com.thoughtworks.xstream.io.StreamException: : Disk quota exceeded
  testEdit(org.geoserver.security.web.group.GroupListPageTest): com.thoughtworks.xstream.io.StreamException: : Disk quota exceeded
  testRenders(org.geoserver.security.web.group.GroupListPageTest): com.thoughtworks.xstream.io.StreamException: : Disk quota exceeded
  testRemove(org.geoserver.security.web.group.GroupListPageTest): com.thoughtworks.xstream.io.StreamException: : Disk quota exceeded
  testGroupNameConflict(org.geoserver.security.web.group.NewGroupPageTest): : Disk quota exceeded
  testReadOnlyRoleService(org.geoserver.security.web.group.NewGroupPageTest): : Disk quota exceeded
  testRemove(org.geoserver.security.web.passwd.MasterPasswordProviderPanelTest): : Disk quota exceeded
  testRemove(org.geoserver.security.web.passwd.PasswordPolicyDetailsPanelTest): : Disk quota exceeded
  testFill(org.geoserver.security.web.role.EditRolePageTest): : Disk quota exceeded
  testReadOnlyRoleService(org.geoserver.security.web.role.EditRolePageTest): : Disk quota exceeded
  testFill(org.geoserver.security.web.role.NewRolePageTest): : Disk quota exceeded
  testEditParentRole(org.geoserver.security.web.role.RoleListPageTest): javax.xml.transform.TransformerException: java.io.IOException: Disk quota exceeded
  testNew(org.geoserver.security.web.role.RoleListPageTest): com.thoughtworks.xstream.io.StreamException: : Disk quota exceeded
  testEdit(org.geoserver.security.web.role.RoleListPageTest): com.thoughtworks.xstream.io.StreamException: : Disk quota exceeded
  testRenders(org.geoserver.security.web.role.RoleListPageTest): com.thoughtworks.xstream.io.StreamException: : Disk quota exceeded
  testRemove(org.geoserver.security.web.role.RoleListPageTest): com.thoughtworks.xstream.io.StreamException: : Disk quota exceeded
  testFill(org.geoserver.security.web.service.EditServiceAccessRulePageTest): com.thoughtworks.xstream.io.StreamException: : Disk quota exceeded
  testReadOnlyRoleService(org.geoserver.security.web.service.EditServiceAccessRulePageTest): : Disk quota exceeded
  testFill(org.geoserver.security.web.service.NewServiceAccessRulePageTest): : Disk quota exceeded
  testDuplicateRule(org.geoserver.security.web.service.NewServiceAccessRulePageTest): : Disk quota exceeded
  testReadOnlyRoleService(org.geoserver.security.web.service.NewServiceAccessRulePageTest): : Disk quota exceeded
  testNew(org.geoserver.security.web.service.ServiceAccessRulePageTest): Disk quota exceeded
  testEdit(org.geoserver.security.web.service.ServiceAccessRulePageTest): com.thoughtworks.xstream.io.StreamException: : Disk quota exceeded
  testRenders(org.geoserver.security.web.service.ServiceAccessRulePageTest): com.thoughtworks.xstream.io.StreamException: : Disk quota exceeded
  testRemove(org.geoserver.security.web.service.ServiceAccessRulePageTest): com.thoughtworks.xstream.io.StreamException: : Disk quota exceeded
  testRemoveUser(org.geoserver.security.web.user.ConfirmRemovalUserPanelTest): java.io.IOException: Could not create the temp directory ./target/mock2186789641291185807tmp
  testRemoveUser(org.geoserver.security.web.user.ConfirmRemovalUserPanelTest): you can only locate or create sessions in the context of a request cycle
  testRemoveUserWithRoles(org.geoserver.security.web.user.ConfirmRemovalUserPanelTest)
  testRemoveUserWithRoles(org.geoserver.security.web.user.ConfirmRemovalUserPanelTest): you can only locate or create sessions in the context of a request cycle
  testPasswordsDontMatch(org.geoserver.security.web.user.EditUserPageTest): ./target/default439412001083395822data/security/role/default/config.xml (No such file or directory)
  testPasswordsDontMatch(org.geoserver.security.web.user.EditUserPageTest): you can only locate or create sessions in the context of a request cycle
  testFill(org.geoserver.security.web.user.EditUserPageTest)
  testFill(org.geoserver.security.web.user.EditUserPageTest): you can only locate or create sessions in the context of a request cycle
  testAllServicesReadOnly(org.geoserver.security.web.user.EditUserPageTest)
  testAllServicesReadOnly(org.geoserver.security.web.user.EditUserPageTest): you can only locate or create sessions in the context of a request cycle
  testReadOnlyUserGroupService(org.geoserver.security.web.user.EditUserPageTest)
  testReadOnlyUserGroupService(org.geoserver.security.web.user.EditUserPageTest): you can only locate or create sessions in the context of a request cycle
  testReadOnlyRoleService(org.geoserver.security.web.user.EditUserPageTest)
  testReadOnlyRoleService(org.geoserver.security.web.user.EditUserPageTest): you can only locate or create sessions in the context of a request cycle
  testPasswordsDontMatch(org.geoserver.security.web.user.NewUserPageTest): ./target/default8034784355133093789data/security/filter/interceptor/config.xml (No such file or directory)
  testPasswordsDontMatch(org.geoserver.security.web.user.NewUserPageTest): you can only locate or create sessions in the context of a request cycle
  testInvalidWorkflow(org.geoserver.security.web.user.NewUserPageTest)
  testInvalidWorkflow(org.geoserver.security.web.user.NewUserPageTest): you can only locate or create sessions in the context of a request cycle
  testUserNameConflict(org.geoserver.security.web.user.NewUserPageTest)
  testUserNameConflict(org.geoserver.security.web.user.NewUserPageTest): you can only locate or create sessions in the context of a request cycle
  testFill2(org.geoserver.security.web.user.NewUserPageTest)
  testFill2(org.geoserver.security.web.user.NewUserPageTest): you can only locate or create sessions in the context of a request cycle
  testFill3(org.geoserver.security.web.user.NewUserPageTest)
  testFill3(org.geoserver.security.web.user.NewUserPageTest): you can only locate or create sessions in the context of a request cycle
  testFill(org.geoserver.security.web.user.NewUserPageTest)
  testFill(org.geoserver.security.web.user.NewUserPageTest): you can only locate or create sessions in the context of a request cycle
  testReadOnlyRoleService(org.geoserver.security.web.user.NewUserPageTest)
  testReadOnlyRoleService(org.geoserver.security.web.user.NewUserPageTest): you can only locate or create sessions in the context of a request cycle
  testRemoveWithRoles(org.geoserver.security.web.user.UserListPageTest): Error persisting DataStoreInfoImpl[sf] to <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/web/security/target/default5205240245736038948data/workspaces/sf/sf/datastore.xml&gt;
  testRemoveWithRoles(org.geoserver.security.web.user.UserListPageTest): you can only locate or create sessions in the context of a request cycle
  testReadOnlyService(org.geoserver.security.web.user.UserListPageTest)
  testReadOnlyService(org.geoserver.security.web.user.UserListPageTest): you can only locate or create sessions in the context of a request cycle
  testNew(org.geoserver.security.web.user.UserListPageTest)
  testNew(org.geoserver.security.web.user.UserListPageTest): you can only locate or create sessions in the context of a request cycle
  testEdit(org.geoserver.security.web.user.UserListPageTest)
  testEdit(org.geoserver.security.web.user.UserListPageTest): you can only locate or create sessions in the context of a request cycle
  testRenders(org.geoserver.security.web.user.UserListPageTest)
  testRenders(org.geoserver.security.web.user.UserListPageTest): you can only locate or create sessions in the context of a request cycle
  testRemove(org.geoserver.security.web.user.UserListPageTest)
  testRemove(org.geoserver.security.web.user.UserListPageTest): you can only locate or create sessions in the context of a request cycle
  testAddModify(org.geoserver.security.web.usergroup.XMLUserGroupConfigDetailsPanelTest): Error persisting FeatureTypeInfoImpl[Updates] to <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/web/security/target/default248449168276168999data/workspaces/cdf/cdf/Updates/featuretype.xml&gt;
  testAddModify(org.geoserver.security.web.usergroup.XMLUserGroupConfigDetailsPanelTest): you can only locate or create sessions in the context of a request cycle
  testRemove(org.geoserver.security.web.usergroup.XMLUserGroupConfigDetailsPanelTest): you can only locate or create sessions in the context of a request cycle
Tests run: 114, Failures: 5, Errors: 72, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/web/security/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 11 minutes 14 seconds
[INFO] Finished at: Mon Aug 12 04:15:00 UTC 2013
[INFO] Final Memory: 65M/374M
See <http://hudson.opengeo.org/hudson/job/geoserver-master-online/1290/&gt;
