See <http://hudson.opengeo.org/hudson/job/geoserver-master-online/1300/>
[...truncated 33211 lines...]
[INFO] [GitCommitIdMojo] build.build.time = 23.08.2013 @ 04:29:12 UTC
[INFO] [GitCommitIdMojo] build.branch = 404bf5dacc496e8b82898322101f08e69dd5033a
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 404bf5d
[INFO] [GitCommitIdMojo] build.commit.id = 404bf5dacc496e8b82898322101f08e69dd5033a
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-5987] DescribeRecord xsi:schemaLocation lacks a / just before CSW-discovery.xsd
[INFO] [site:attach-descriptor {execution: default-attach-descriptor}]
Downloading: http://repo.opengeo.org//org/geotools/gt-opengis/11-SNAPSHOT/gt-opengis-11-SNAPSHOT.jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/community/target/community-2.5-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/community/pom.xml> to /usr/share/jetty/.m2/repository/org/geoserver/community/2.5-SNAPSHOT/community-2.5-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/community/target/community-2.5-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/community/2.5-SNAPSHOT/community-2.5-SNAPSHOT-tests.jar
[INFO] Building GeoServer Extensions
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/extension/target>
[INFO] [GitCommitIdMojo] Running on '/var/lib/hudson/jobs/geoserver-master/workspace/.git' repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-5987] DescribeRecord xsi:schemaLocation lacks a / just before CSW-discovery.xsd
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 22.08.2013 @ 16:55:56 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 23-Aug-2013 04:08
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/extension/target/extension-2.5-SNAPSHOT-tests.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/extension/pom.xml> to /usr/share/jetty/.m2/repository/org/geoserver/extension/2.5-SNAPSHOT/extension-2.5-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/extension/target/extension-2.5-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/2.5-SNAPSHOT/extension-2.5-SNAPSHOT-tests.jar
[INFO] Building Application Schema Support
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/extension/app-schema/target>
[INFO] [GitCommitIdMojo] build.build.time = 23.08.2013 @ 04:29:15 UTC
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/extension/app-schema/target/app-schema-2.5-SNAPSHOT-tests.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/extension/app-schema/pom.xml> to /usr/share/jetty/.m2/repository/org/geoserver/extension/app-schema/2.5-SNAPSHOT/app-schema-2.5-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/extension/app-schema/target/app-schema-2.5-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/app-schema/2.5-SNAPSHOT/app-schema-2.5-SNAPSHOT-tests.jar
[INFO] Building Application Schema Integration Test
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/extension/app-schema/app-schema-test/target>
[INFO] [GitCommitIdMojo] build.build.time = 23.08.2013 @ 04:29:19 UTC
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/extension/app-schema/app-schema-test/src/main/java>
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/extension/app-schema/app-schema-test/src/main/resources>
[INFO] snapshot org.geotools:gt-app-schema:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-app-schema:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:app-schema:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:app-schema:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-complex:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-complex:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-complex:11-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-complex:11-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-app-schema-resolver:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-app-schema-resolver:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-app-schema-resolver:11-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-app-schema-resolver:11-SNAPSHOT: checking for updates from geosolutions
Downloading: http://repo.opengeo.org//org/geotools/schemas/geosciml-3.2-seegrid/3.2.0-1/geosciml-3.2-seegrid-3.2.0-1.pom
[INFO] Unable to find resource 'org.geotools.schemas:geosciml-3.2-seegrid:pom:3.2.0-1' in repository opengeo (http://repo.opengeo.org/)
Downloading: http://download.osgeo.org/webdav/geotools//org/geotools/schemas/geosciml-3.2-seegrid/3.2.0-1/geosciml-3.2-seegrid-3.2.0-1.pom
[INFO] Unable to find resource 'org.geotools.schemas:geosciml-3.2-seegrid:pom:3.2.0-1' in repository osgeo (http://download.osgeo.org/webdav/geotools/)
Downloading: http://maven.restlet.org/org/geotools/schemas/geosciml-3.2-seegrid/3.2.0-1/geosciml-3.2-seegrid-3.2.0-1.pom
[INFO] Unable to find resource 'org.geotools.schemas:geosciml-3.2-seegrid:pom:3.2.0-1' in repository maven-restlet (http://maven.restlet.org)
Downloading: http://repo1.maven.org/maven2/org/geotools/schemas/geosciml-3.2-seegrid/3.2.0-1/geosciml-3.2-seegrid-3.2.0-1.pom
[INFO] Unable to find resource 'org.geotools.schemas:geosciml-3.2-seegrid:pom:3.2.0-1' in repository central (http://repo1.maven.org/maven2)
Downloading: http://repo.opengeo.org//org/geotools/ogc/net.opengis.ows/11-SNAPSHOT/net.opengis.ows-11-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-sld/11-SNAPSHOT/gt-xsd-sld-11-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-fes/11-SNAPSHOT/gt-xsd-fes-11-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-validation/11-SNAPSHOT/gt-validation-11-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-wfs/11-SNAPSHOT/gt-wfs-11-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-process/11-SNAPSHOT/gt-process-11-SNAPSHOT.jar
[INFO] No sources to compile
[INFO] Copying 132 resources
Downloading: http://repo.opengeo.org//org/geotools/schemas/geosciml-3.2-seegrid/3.2.0-1/geosciml-3.2-seegrid-3.2.0-1.jar
[INFO] Unable to find resource 'org.geotools.schemas:geosciml-3.2-seegrid:jar:3.2.0-1' in repository opengeo (http://repo.opengeo.org/)
Downloading: http://download.osgeo.org/webdav/geotools//org/geotools/schemas/geosciml-3.2-seegrid/3.2.0-1/geosciml-3.2-seegrid-3.2.0-1.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-geojson/11-SNAPSHOT/gt-geojson-11-SNAPSHOT.jar
[INFO] Unable to find resource 'org.geotools.schemas:geosciml-3.2-seegrid:jar:3.2.0-1' in repository osgeo (http://download.osgeo.org/webdav/geotools/)
Downloading: http://maven.restlet.org/org/geotools/schemas/geosciml-3.2-seegrid/3.2.0-1/geosciml-3.2-seegrid-3.2.0-1.jar
[INFO] Unable to find resource 'org.geotools.schemas:geosciml-3.2-seegrid:jar:3.2.0-1' in repository maven-restlet (http://maven.restlet.org)
Downloading: http://repo1.maven.org/maven2/org/geotools/schemas/geosciml-3.2-seegrid/3.2.0-1/geosciml-3.2-seegrid-3.2.0-1.jar
[INFO] Unable to find resource 'org.geotools.schemas:geosciml-3.2-seegrid:jar:3.2.0-1' in repository central (http://repo1.maven.org/maven2)
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Missing:
1) org.geotools.schemas:geosciml-3.2-seegrid:jar:3.2.0-1
Try downloading the file manually from the project website.
Then, install it using the command:
mvn install:install-file -DgroupId=org.geotools.schemas -DartifactId=geosciml-3.2-seegrid -Dversion=3.2.0-1 -Dpackaging=jar -Dfile=/path/to/file
Alternatively, if you host your own repository you can deploy the file there:
mvn deploy:deploy-file -DgroupId=org.geotools.schemas -DartifactId=geosciml-3.2-seegrid -Dversion=3.2.0-1 -Dpackaging=jar -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
Path to dependency:
1) org.geoserver.extension:app-schema-test:jar:2.5-SNAPSHOT
2) org.geotools.schemas:geosciml-3.2-seegrid:jar:3.2.0-1
1 required artifact is missing.
for artifact:
from the specified remote repositories:
central (http://repo1.maven.org/maven2),
osgeo (http://download.osgeo.org/webdav/geotools/),
maven-restlet (http://maven.restlet.org),
[INFO] Total time: 20 minutes 30 seconds
[INFO] Finished at: Fri Aug 23 04:29:24 UTC 2013
[INFO] Final Memory: 85M/323M
