[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-master-online #1304
See <http://hudson.opengeo.org/hudson/job/geoserver-master-online/1304/&gt;
[...truncated 586 lines...]
WARNING: Extension lookup occured, but ApplicationContext is unset.
Aug 27, 2013 4:41:29 AM org.geoserver.platform.GeoServerExtensions checkContext
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.001 sec
Running org.geoserver.ows.kvp.KvpUtilsTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.ows.kvp.TimeKvpParserTest
Aug 27, 2013 4:41:30 AM org.geoserver.ows.kvp.TimeKvpParser parse
INFO: Lmiting number of elements in this periodo to 100
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.834 sec
Running org.geoserver.ows.util.CaseInsensitiveMapTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.363 sec
Running org.geoserver.ows.util.OwsUtilsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.003 sec
Running org.geoserver.ows.xml.v1_0.ExceptionReportBindingTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Results :
Tests run: 52, Failures: 0, Errors: 0, Skipped: 0
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/ows/target/ows-2.5-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/ows/target/ows-2.5-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/ows/target/ows-2.5-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/ows/target/ows-2.5-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/ows/target/ows-2.5-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/ows/2.5-SNAPSHOT/ows-2.5-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/ows/target/ows-2.5-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/ows/2.5-SNAPSHOT/ows-2.5-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/ows/target/ows-2.5-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/ows/2.5-SNAPSHOT/ows-2.5-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/ows/target/ows-2.5-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/ows/2.5-SNAPSHOT/ows-2.5-SNAPSHOT-test-sources.jar
[INFO] Building Main Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/main/target&gt;
[INFO] [GitCommitIdMojo] Running on '/var/lib/hudson/jobs/geoserver-master/workspace/.git' repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-5643] problem with legend decoration and input parameter
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 25.08.2013 @ 15:54:51 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 27-Aug-2013 04:40
[INFO] [GitCommitIdMojo] build.build.time = 27.08.2013 @ 04:42:04 UTC
[INFO] [GitCommitIdMojo] build.branch = 1b1cbfa0104f7121372500837d91813533ab9ef5
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 1b1cbfa
[INFO] [GitCommitIdMojo] build.commit.id = 1b1cbfa0104f7121372500837d91813533ab9ef5
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-5643] problem with legend decoration and input parameter
[INFO] Copying 32 resources
[INFO] Copying 163 resources
[INFO] snapshot org.geotools:gt-cql:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-cql:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-validation:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-validation:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-data:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-data:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-jdbc:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-jdbc:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-property:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-property:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:plugin:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:plugin:11-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/plugin/11-SNAPSHOT/plugin-11-SNAPSHOT.pom
[INFO] snapshot org.geotools:gt-epsg-hsql:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-epsg-hsql:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-wms:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-wms:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-xml:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-xml:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-xml:11-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-xml:11-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-render:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-render:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-render:11-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-render:11-SNAPSHOT: checking for updates from geosolutions
Downloading: http://repo.opengeo.org//org/geotools/gt-render/11-SNAPSHOT/gt-render-11-SNAPSHOT.pom
[INFO] snapshot org.geotools.xsd:gt-xsd-sld:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-sld:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-arcgrid:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-arcgrid:11-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/gt-arcgrid/11-SNAPSHOT/gt-arcgrid-11-SNAPSHOT.pom
[INFO] snapshot org.geotools:gt-geotiff:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-geotiff:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-gtopo30:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-gtopo30:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-image:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-image:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-imagemosaic:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-imagemosaic:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-h2:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-h2:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-h2:11-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.jdbc:gt-jdbc-h2:11-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.jdbc:gt-jdbc:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc:11-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.jdbc:gt-jdbc:11-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.jdbc:gt-jdbc-oracle:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-oracle:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-oracle:11-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.jdbc:gt-jdbc-oracle:11-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:11-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:11-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-shapefile:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-shapefile:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-shapefile:11-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-shapefile:11-SNAPSHOT: checking for updates from geosolutions
Downloading: http://repo.opengeo.org//org/geotools/gt-shapefile/11-SNAPSHOT/gt-shapefile-11-SNAPSHOT.pom
[INFO] snapshot org.geotools:gt-transform:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-transform:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-transform:11-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-transform:11-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-wfs:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-wfs:11-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/gt-wfs/11-SNAPSHOT/gt-wfs-11-SNAPSHOT.pom
[INFO] snapshot org.geotools:unsupported:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:unsupported:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:11-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:11-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:11-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:11-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.ogc:net.opengis.fes:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.fes:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.ogc:net.opengis.fes:11-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.ogc:net.opengis.fes:11-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:11-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:11-SNAPSHOT: checking for updates from geosolutions
Downloading: http://repo.opengeo.org//org/geotools/gt-render/11-SNAPSHOT/gt-render-11-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-shapefile/11-SNAPSHOT/gt-shapefile-11-SNAPSHOT.jar
[INFO] Compiling 571 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/main/target/classes&gt;
[INFO] Copying 100 resources
[INFO] Copying 34 resources
Downloading: http://repo.opengeo.org//org/geotools/gt-arcgrid/11-SNAPSHOT/gt-arcgrid-11-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-wfs/11-SNAPSHOT/gt-wfs-11-SNAPSHOT.jar
[INFO] Compiling 170 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/main/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/main/target/surefire-reports&gt;
T E S T S
Running org.geoserver.ManifestLoaderTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 16.216 sec
Running org.geoserver.ManifestLoaderTest$ManifestPropertiesTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.295 sec
Running org.geoserver.catalog.CatalogIntegrationTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 16.772 sec
Running org.geoserver.catalog.LayerGroupHelperTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 14.125 sec
Running org.geoserver.catalog.PredicatesTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.009 sec
Running org.geoserver.catalog.ResourcePoolTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 17.939 sec
Running org.geoserver.catalog.SchemaMappingTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.029 sec
Running org.geoserver.catalog.impl.CascadeDeleteVisitorTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Running org.geoserver.catalog.impl.CascadeRemovalReporterTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.249 sec
Running org.geoserver.catalog.impl.CatalogBuilderIntTest
<http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/main/./target/smallMosaic&gt;
<http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/main/./target/largeMosaic&gt;
Results :
Tests run: 45, Failures: 0, Errors: 0, Skipped: 0
[ERROR] FATAL ERROR
[INFO] The forked VM terminated without saying properly goodbye. VM crash or System.exit called ?
[INFO] Trace
java.lang.RuntimeException: The forked VM terminated without saying properly goodbye. VM crash or System.exit called ?
  at org.apache.maven.plugin.surefire.booterclient.output.ForkClient.close(ForkClient.java:257)
  at org.apache.maven.plugin.surefire.booterclient.ForkStarter.fork(ForkStarter.java:301)
  at org.apache.maven.plugin.surefire.booterclient.ForkStarter.run(ForkStarter.java:116)
  at org.apache.maven.plugin.surefire.AbstractSurefireMojo.executeProvider(AbstractSurefireMojo.java:740)
  at org.apache.maven.plugin.surefire.AbstractSurefireMojo.executeAllProviders(AbstractSurefireMojo.java:682)
  at org.apache.maven.plugin.surefire.AbstractSurefireMojo.executeAfterPreconditionsChecked(AbstractSurefireMojo.java:648)
  at org.apache.maven.plugin.surefire.AbstractSurefireMojo.execute(AbstractSurefireMojo.java:586)
  at org.apache.maven.plugin.DefaultPluginManager.executeMojo(DefaultPluginManager.java:490)
  at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoals(DefaultLifecycleExecutor.java:694)
  at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoalWithLifecycle(DefaultLifecycleExecutor.java:556)
  at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoal(DefaultLifecycleExecutor.java:535)
  at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoalAndHandleFailures(DefaultLifecycleExecutor.java:387)
  at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeTaskSegments(DefaultLifecycleExecutor.java:348)
  at org.apache.maven.lifecycle.DefaultLifecycleExecutor.execute(DefaultLifecycleExecutor.java:180)
  at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:328)
  at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:138)
  at org.apache.maven.cli.MavenCli.main(MavenCli.java:362)
  at org.apache.maven.cli.compat.CompatibleMain.main(CompatibleMain.java:60)
  at org.codehaus.classworlds.Launcher.launchEnhanced(Launcher.java:315)
  at org.codehaus.classworlds.Launcher.launch(Launcher.java:255)
  at org.codehaus.classworlds.Launcher.mainWithExitCode(Launcher.java:430)
  at org.codehaus.classworlds.Launcher.main(Launcher.java:375)
[INFO] Total time: 7 minutes 41 seconds
[INFO] Finished at: Tue Aug 27 04:48:04 UTC 2013
[INFO] Final Memory: 65M/387M
See <http://hudson.opengeo.org/hudson/job/geoserver-master-online/1305/&gt;
