See <http://hudson.opengeo.org/hudson/job/geoserver-master-online/997/>
[...truncated 26335 lines...]
sleep interrupted
Thread[Thread-11,5,main] calling requestComplete
Thread[Thread-11,5,main] done
sleep interrupted
Thread[Thread-12,5,main] calling requestComplete
Thread[Thread-12,5,main] done
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.228 sec
Running org.geoserver.flow.controller.BasicOWSFlowControllerTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.001 sec
Running org.geoserver.flow.controller.SingleIpFlowControllerTest
Thread[Thread-13,5,main] calling requestIncoming
Thread[Thread-13,5,main] waiting
Thread[Thread-13,5,main] calling requestComplete
Thread[Thread-13,5,main] done
Thread[Thread-14,5,main] calling requestIncoming
Thread[Thread-14,5,main] waiting
Thread[Thread-15,5,main] calling requestIncoming
sleep interrupted
Thread[Thread-14,5,main] calling requestComplete
Thread[Thread-14,5,main] done
Thread[Thread-15,5,main] waiting
sleep interrupted
Thread[Thread-15,5,main] calling requestComplete
Thread[Thread-15,5,main] done
Thread[Thread-16,5,main] calling requestIncoming
Thread[Thread-16,5,main] waiting
Thread[Thread-16,5,main] calling requestComplete
Thread[Thread-16,5,main] done
Thread[Thread-17,5,main] calling requestIncoming
Thread[Thread-17,5,main] waiting
Thread[Thread-18,5,main] calling requestIncoming
Thread[Thread-18,5,main] waiting
sleep interrupted
Thread[Thread-17,5,main] calling requestComplete
Thread[Thread-17,5,main] done
sleep interrupted
Thread[Thread-18,5,main] calling requestComplete
Thread[Thread-18,5,main] done
Thread[Thread-19,5,main] calling requestIncoming
Thread[Thread-19,5,main] waiting
Thread[Thread-19,5,main] calling requestComplete
Thread[Thread-19,5,main] done
Thread[Thread-20,5,main] calling requestIncoming
Thread[Thread-20,5,main] waiting
Thread[Thread-21,5,main] calling requestIncoming
sleep interrupted
Thread[Thread-20,5,main] calling requestComplete
Thread[Thread-20,5,main] done
Thread[Thread-21,5,main] waiting
sleep interrupted
Thread[Thread-21,5,main] calling requestComplete
Thread[Thread-21,5,main] done
Thread[Thread-22,5,main] calling requestIncoming
Thread[Thread-22,5,main] waiting
Thread[Thread-23,5,main] calling requestIncoming
Thread[Thread-23,5,main] waiting
sleep interrupted
Thread[Thread-22,5,main] calling requestComplete
Thread[Thread-22,5,main] done
sleep interrupted
Thread[Thread-23,5,main] calling requestComplete
Thread[Thread-23,5,main] done
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.309 sec
Running org.geoserver.flow.controller.GlobalFlowControllerTest
Thread[Thread-24,5,main] calling requestIncoming
Thread[Thread-24,5,main] waiting
Thread[Thread-25,5,main] calling requestIncoming
Thread[Thread-24,5,main] calling requestComplete
Thread[Thread-24,5,main] done
Thread[Thread-26,5,main] calling requestIncoming
Thread[Thread-26,5,main] waiting
Thread[Thread-27,5,main] calling requestIncoming
Thread[Thread-28,5,main] calling requestIncoming
sleep interrupted
Thread[Thread-26,5,main] calling requestComplete
Thread[Thread-26,5,main] done
Thread[Thread-27,5,main] waiting
sleep interrupted
Thread[Thread-27,5,main] calling requestComplete
Thread[Thread-27,5,main] done
Thread[Thread-28,5,main] waiting
sleep interrupted
Thread[Thread-28,5,main] calling requestComplete
Thread[Thread-28,5,main] done
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.508 sec
Results :
Tests run: 19, Failures: 0, Errors: 0, Skipped: 0
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/extension/control-flow/target/control-flow-2.3-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/extension/control-flow/target/control-flow-2.3-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/extension/control-flow/target/control-flow-2.3-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/extension/control-flow/target/control-flow-2.3-SNAPSHOT-test-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/extension/control-flow/target/control-flow-2.3-SNAPSHOT.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/control-flow/2.3-SNAPSHOT/control-flow-2.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/extension/control-flow/target/control-flow-2.3-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/control-flow/2.3-SNAPSHOT/control-flow-2.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/extension/control-flow/target/control-flow-2.3-SNAPSHOT-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/control-flow/2.3-SNAPSHOT/control-flow-2.3-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/extension/control-flow/target/control-flow-2.3-SNAPSHOT-test-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/control-flow/2.3-SNAPSHOT/control-flow-2.3-SNAPSHOT-test-sources.jar
[INFO] Building Web Processing Service parent
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/extension/wps/target>
[INFO] [GitCommitIdMojo] Running on '/var/lib/hudson/jobs/geoserver-master/workspace/.git' repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.branch = aa38051111169bc13943bb1bf799abdbf4bc1aac
[INFO] [GitCommitIdMojo] build.commit.id = aa38051111169bc13943bb1bf799abdbf4bc1aac
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-5364] WPS code may fail to release coverage objects, which may result in file locks on windows
[INFO] [GitCommitIdMojo] build.commit.time = 20.10.2012 @ 17:14:02 UTC
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = aa38051
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-5364] WPS code may fail to release coverage objects, which may result in file locks on windows
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = aaime
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.timestamp = 21-Oct-2012 04:08
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.build.time = 21.10.2012 @ 04:28:36 UTC
[INFO] [site:attach-descriptor {execution: default-attach-descriptor}]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/extension/wps/target/wps-2.3-SNAPSHOT-tests.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/extension/wps/pom.xml> to /usr/share/jetty/.m2/repository/org/geoserver/extension/wps/2.3-SNAPSHOT/wps-2.3-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/extension/wps/target/wps-2.3-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/wps/2.3-SNAPSHOT/wps-2.3-SNAPSHOT-tests.jar
[INFO] Building Web Processing Service Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/extension/wps/wps-core/target>
[INFO] Copying 9 resources
[INFO] Copying 14 resources
[INFO] snapshot org.geotools.ogc:net.opengis.wps:9-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools.ogc:net.opengis.wps:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.wps:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wps:9-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools.xsd:gt-xsd-wps:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wps:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-process:9-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools:gt-process:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-process:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-process-raster:9-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools:gt-process-raster:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-process-raster:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-process-geometry:9-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools:gt-process-geometry:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-process-geometry:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-process-feature:9-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools:gt-process-feature:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-process-feature:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-grid:9-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools:gt-grid:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-grid:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-grid:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-grid:9-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-geojson:9-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools:gt-geojson:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-geojson:9-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 117 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/extension/wps/wps-core/target/classes>
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/extension/wps/wps-core/src/main/java/org/geoserver/wps/executor/ExecuteResponseBuilder.java>:\[59,33\] cannot find symbol
symbol : class GridCoverageResource
<http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/extension/wps/wps-core/src/main/java/org/geoserver/wps/executor/SimpleInputProvider.java>:\[53,33\] cannot find symbol
<http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/extension/wps/wps-core/src/main/java/org/geoserver/wps/executor/ExecuteResponseBuilder.java>:\[106,48\] cannot find symbol
location: class org.geoserver.wps.executor.ExecuteResponseBuilder
<http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/extension/wps/wps-core/src/main/java/org/geoserver/wps/executor/SimpleInputProvider.java>:\[147,62\] cannot find symbol
location: class org.geoserver.wps.executor.SimpleInputProvider
[INFO] Total time: 20 minutes 9 seconds
[INFO] Finished at: Sun Oct 21 04:28:43 UTC 2012
[INFO] Final Memory: 81M/378M
