See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/4992/changes>
Changes:
[aaime] Reprojection console, wiring up the srs description panel, and improving label styling in the area of validity preview
[aaime] [GEOS-5006] GeoserverGridShiftLocator, patch by Oscar Fonts
[...truncated 39706 lines...]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc> (directory)
[INFO] Copying 7 resources
[INFO] Copying 20 resources
Downloading: http://repo.opengeo.org//org/geotools/ogc/net.opengis.ows/8-SNAPSHOT/net.opengis.ows-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-main/8-SNAPSHOT/gt-main-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-gtopo30/8-SNAPSHOT/gt-gtopo30-8-SNAPSHOT.jar
[INFO] Compiling 30 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/target/classes>
[INFO] Copying 0 resource
[INFO] Compiling 7 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/target/test-classes>
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/target/surefire-reports>
T E S T S
Running org.geoserver.gwc.web.layer.NewCachedLayerPageTest
24 Mar 19:49:11 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/./target/mock1442421227930641146data>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 13.903 sec
Running org.geoserver.gwc.web.gridset.GridSetsPageTest
24 Mar 19:49:23 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/./target/mock6855265758717695617data>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.399 sec
Running org.geoserver.gwc.web.GWCSettingsPageTest
24 Mar 19:49:26 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/./target/mock2013177301802829236data>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.378 sec
Running org.geoserver.gwc.web.gridset.GridSetNewPageTest
24 Mar 19:49:30 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/./target/mock1265678774846120738data>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.551 sec
Running org.geoserver.gwc.web.layer.LayerEditCacheOptionsTabPanelInfoTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.244 sec
Running org.geoserver.gwc.web.layer.LayerCacheOptionsTabPanelTest
24 Mar 19:49:34 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/./target/mock1208133016687128624data>
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.154 sec
Running org.geoserver.gwc.web.layer.CachedLayersPageTest
24 Mar 19:49:38 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/./target/mock5352417936276839585data>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.205 sec
Results :
Tests run: 13, Failures: 0, Errors: 0, Skipped: 0
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/target/web-gwc-2.2-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/target/web-gwc-2.2-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] [svn-revision-number:revision {execution: default}]
[WARNING] the "build.repository" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.path" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.revision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.mixedRevisions" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedRevision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedDate" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.status" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.specialStatus" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/target/web-gwc-2.2-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/target/web-gwc-2.2-SNAPSHOT-test-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/target/web-gwc-2.2-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-gwc/2.2-SNAPSHOT/web-gwc-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/target/web-gwc-2.2-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-gwc/2.2-SNAPSHOT/web-gwc-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/target/web-gwc-2.2-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-gwc/2.2-SNAPSHOT/web-gwc-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/target/web-gwc-2.2-SNAPSHOT-test-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-gwc/2.2-SNAPSHOT/web-gwc-2.2-SNAPSHOT-test-sources.jar
[INFO] Building WFS UI Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target>
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs> (directory)
[INFO] Copying 5 resources
[INFO] Compiling 2 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target/classes>
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target/test-classes>
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target/surefire-reports>
T E S T S
Running org.geoserver.wfs.web.WFSAdminPageTest
24 Mar 19:49:49 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/./target/mock3681340441724699428data>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.839 sec
Results :
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target/web-wfs-2.2-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target/web-wfs-2.2-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target/web-wfs-2.2-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target/web-wfs-2.2-SNAPSHOT-test-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target/web-wfs-2.2-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-wfs/2.2-SNAPSHOT/web-wfs-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target/web-wfs-2.2-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-wfs/2.2-SNAPSHOT/web-wfs-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target/web-wfs-2.2-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-wfs/2.2-SNAPSHOT/web-wfs-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target/web-wfs-2.2-SNAPSHOT-test-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-wfs/2.2-SNAPSHOT/web-wfs-2.2-SNAPSHOT-test-sources.jar
[INFO] Building Demoes Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target>
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo> (directory)
[INFO] Copying 9 resources
[INFO] snapshot org.geotools:gt-sample-data:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-sample-data:8-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 13 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target/classes>
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/src/main/java/org/geoserver/web/demo/ReprojectPage.java>:\[19,31\] cannot find symbol
symbol : class GeometryTextArea
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/src/main/java/org/geoserver/web/demo/ReprojectPage.java>:\[42,4\] cannot find symbol
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/src/main/java/org/geoserver/web/demo/ReprojectPage.java>:\[44,4\] cannot find symbol
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/src/main/java/org/geoserver/web/demo/ReprojectPage.java>:\[107,25\] cannot find symbol
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/src/main/java/org/geoserver/web/demo/ReprojectPage.java>:\[110,25\] cannot find symbol
[INFO] Total time: 12 minutes 52 seconds
[INFO] Finished at: Sat Mar 24 19:50:02 UTC 2012
[INFO] Final Memory: 62M/260M
