See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/5048/changes>
Changes:
[mcr] Adding a LRU authentication cache
[...truncated 23072 lines...]
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock6465032725180211120data>
20 Apr 11:55:16 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock4073287854979052225data>
20 Apr 11:55:16 ERROR [geoserver.wfs] - Transaction failed
org.geoserver.wfs.WFSTransactionException: Update error: Transaction does not have authorization for Locks:Locks.0
at org.geoserver.wfs.UpdateElementHandler.execute(UpdateElementHandler.java:260)
at org.geoserver.wfs.Transaction.execute(Transaction.java:319)
at org.geoserver.wfs.Transaction.transaction(Transaction.java:104)
at org.geoserver.wfs.DefaultWebFeatureService20.transaction(DefaultWebFeatureService20.java:120)
at sun.reflect.GeneratedMethodAccessor236.invoke(Unknown Source)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:318)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:32)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
at $Proxy15.transaction(Unknown Source)
at sun.reflect.GeneratedMethodAccessor235.invoke(Unknown Source)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:769)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:272)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:789)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.geoserver.test.GeoServerAbstractTestSupport$3.service(GeoServerAbstractTestSupport.java:1236)
at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1255)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1190)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1172)
at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:791)
at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:738)
at org.geoserver.test.GeoServerAbstractTestSupport.post(GeoServerAbstractTestSupport.java:718)
at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:925)
at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:908)
at org.geoserver.wfs.v2_0.GetFeatureWithLockTest.testUpdateLockedFeatureWithoutLockId(GetFeatureWithLockTest.java:146)
at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:147)
at sun.reflect.GeneratedMethodAccessor206.invoke(Unknown Source)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
Caused by: org.geotools.data.FeatureLockException: Transaction does not have authorization for Locks:Locks.0
at org.geotools.data.InProcessLockingManager.assertAccess(InProcessLockingManager.java:287)
at org.geotools.data.InProcessLockingManager$1.write(InProcessLockingManager.java:334)
at org.geotools.data.FilteringFeatureWriter.write(FilteringFeatureWriter.java:108)
at org.geotools.data.AbstractFeatureStore.modifyFeatures(AbstractFeatureStore.java:203)
at org.geotools.data.AbstractFeatureStore.modifyFeatures(AbstractFeatureStore.java:129)
at org.vfny.geoserver.global.GeoServerFeatureStore.modifyFeatures(GeoServerFeatureStore.java:182)
at org.geoserver.wfs.UpdateElementHandler.execute(UpdateElementHandler.java:254)
... 64 more
20 Apr 11:55:16 ERROR [geoserver.ows] -
at org.geoserver.wfs.Transaction.execute(Transaction.java:330)
Caused by: org.geoserver.wfs.WFSTransactionException: Update error: Transaction does not have authorization for Locks:Locks.0
... 63 more
... 64 more
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock3952292054670855870data>
20 Apr 11:55:17 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock5866181209070069445data>
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.677 sec
Running org.geoserver.wfs.ReprojectionWriteTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock2745245620474264118data>
20 Apr 11:55:19 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock4260875319342285509data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock1835761604066810193data>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.161 sec
Running org.geoserver.wfs.AliasTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock8435677367474200715data>
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<xsd:schema xmlns:cdf="http://www.opengis.net/cite/data" xmlns:gml="http://www.opengis.net/gml" xmlns:gs="http://geoserver.org" xmlns:xsd="http://www.w3.org/2001/XMLSchema" elementFormDefault="qualified" targetNamespace="http://www.opengis.net/cite/data">
<xsd:import namespace="http://www.opengis.net/gml" schemaLocation="http://localhost:8080/geoserver/schemas/gml/2.1.2/feature.xsd"/>
<xsd:complexType name="ft15Type">
<xsd:complexContent>
<xsd:extension base="gml:AbstractFeatureType">
<xsd:sequence>
<xsd:element maxOccurs="1" minOccurs="0" name="boundedBy" nillable="true" type="gml:PolygonPropertyType"/>
<xsd:element maxOccurs="1" minOccurs="0" name="pointProperty" nillable="true" type="gml:PointPropertyType"/>
</xsd:sequence>
</xsd:extension>
</xsd:complexContent>
</xsd:complexType>
<xsd:element name="ft15" substitutionGroup="gml:_Feature" type="cdf:ft15Type"/>
</xsd:schema>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.342 sec
Running org.geoserver.wfs.xml.GMLOutputFormatTest
20 Apr 11:55:20 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock4381100099133392251data>
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.563 sec
Results :
Tests in error:
testValidAuth(org.geoserver.wfs.SecuredGetFeatureTest)
testValidAuthAdmin(org.geoserver.wfs.SecuredGetFeatureTest)
testNoLimits(org.geoserver.wfs.ResourceAccessManagerWFSTest)
testReadFilter(org.geoserver.wfs.ResourceAccessManagerWFSTest)
testReadFilterReproject(org.geoserver.wfs.ResourceAccessManagerWFSTest)
testFilterAttribute(org.geoserver.wfs.ResourceAccessManagerWFSTest)
testFilterRequestedAttribute(org.geoserver.wfs.ResourceAccessManagerWFSTest)
testExtraAttributesNoFilter(org.geoserver.wfs.ResourceAccessManagerWFSTest)
testLimitAttributesNoFilter(org.geoserver.wfs.ResourceAccessManagerWFSTest)
testInsertNoLimits(org.geoserver.wfs.ResourceAccessManagerWFSTest)
testInsertRestricted(org.geoserver.wfs.ResourceAccessManagerWFSTest)
testInsertAttributeRestricted(org.geoserver.wfs.ResourceAccessManagerWFSTest)
testUpdateNoLimits(org.geoserver.wfs.ResourceAccessManagerWFSTest)
testUpdateLimitWrite(org.geoserver.wfs.ResourceAccessManagerWFSTest)
testUpdateAttributeRestricted(org.geoserver.wfs.ResourceAccessManagerWFSTest)
testDeleteLimitWrite(org.geoserver.wfs.ResourceAccessManagerWFSTest)
Tests run: 406, Failures: 0, Errors: 16, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/surefire-reports> for the individual test results.
[INFO] Total time: 7 minutes 38 seconds
[INFO] Finished at: Fri Apr 20 11:55:20 UTC 2012
[INFO] Final Memory: 55M/419M
Failed to send e-mail to mcr because no e-mail address is known, and no default e-mail domain is configured
