[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-trunk #5073
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/5073/changes&gt;
Changes:
[groldan] fixes #GEOS-5081: fix non deterministic behavior of the Catalog.getLayerGroupByName(...) family of methods
[groldan] Force saving the layer resource in CatalogImplTest.testEnableLayer(), otherwise the final assert works by accident on the default catalog implementation
[groldan] SettingsInfoImpl lacks a setId method. Adding it.
[mcr] Fixing GEOS-5079
[groldan] make org.geoserver.wms.WatermarkInfo serializable
[groldan] do not rely on a specific list order, nothing mandates the returned list to be in the same order FeaturetypeInfos were added
[groldan] fixes #GEOS-5078, always clip the saved gridsubset's extent to the gridset's area of validity
[...truncated 12459 lines...]
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock6838928094929895183data&gt;
01 May 01:41:20 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock78317513823764953data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock1042610164848326493data&gt;
01 May 01:41:21 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock3088817079065433836data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock7051683367912815113data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock3727081293131774558data&gt;
01 May 01:41:22 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock1904749044126923462data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock657581092520691776data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock5396064184915673584data&gt;
01 May 01:41:23 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock608782023091251625data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock5630733596630093838data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock3789509560329841749data&gt;
01 May 01:41:24 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock1528090744414902941data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock1777357018779774858data&gt;
01 May 01:41:25 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock8353075095255359197data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock4780671316559339394data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock4308468963708883392data&gt;
01 May 01:41:26 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock1253011116107577827data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock5017624740431790490data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock8173731252297581700data&gt;
01 May 01:41:27 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock2818960660072603706data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock8660807782210138563data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock6679111320431016403data&gt;
Tests run: 45, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 15.066 sec <<< FAILURE!
Running org.geoserver.template.GeoServerTemplateLoader2Test
01 May 01:41:28 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock6022158424899291389data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock5045992408561311996data&gt;
01 May 01:41:29 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock465642244606055043data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock2587459727441055240data&gt;
01 May 01:41:30 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock6160060972775768813data&gt;
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.12 sec
Running org.geoserver.ows.URLManglersTest
01 May 01:41:31 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock6419142284981029497data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock1507421276051249534data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock4845429062842649356data&gt;
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.27 sec
Running org.geoserver.security.GeoServerRoleFilterTest
01 May 01:41:32 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock6045621781158665591data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock7364422434932021027data&gt;
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.526 sec
Running org.geoserver.security.validation.PasswordValidatorTest
01 May 01:41:33 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/live8144201918292733490data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.225 sec
Running org.geoserver.security.impl.DataAccessRuleDAOTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.geoserver.security.impl.GeoServerUserDaoTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Running org.geoserver.security.xml.XMLRoleServiceTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/live6364366193364622323data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/live6992036409943097844data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/live925658724101216149data&gt;
01 May 01:41:34 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/live2580334578748304152data&gt;
01 May 01:41:35 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/live8498729862616370329data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/live6392765836269413931data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/live222901840066377758data&gt;
01 May 01:41:36 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/live8128658957871482522data&gt;
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.245 sec
Running org.geoserver.data.util.CoverageUtilsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.geoserver.security.decorators.SecuredFeatureSourceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.01 sec
Running org.geoserver.catalog.impl.CatalogBuilderTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock2810811798071997007data&gt;
May 1, 2012 1:41:36 AM org.geotools.referencing.operation.projection.TransverseMercator.Inverse transform
WARNING: Possible use of "Transverse_Mercator (Inverse transform)" projection outside its valid area.
Latitude 2181°05.9'N is out of range (±90°).
May 1, 2012 1:41:36 AM org.geoserver.test.RemoteOWSTestSupport isRemoteWMSStatesAvailable
WARNING: Skipping remote OWS test because they were not enabled via -DremoteOwsTests=true
May 1, 2012 1:41:36 AM org.geoserver.catalog.impl.CatalogBuilderTest testWMS
WARNING: Remote OWS tests disabled, skipping catalog builder wms tests
May 1, 2012 1:41:41 AM org.geoserver.catalog.ResourcePool$DataStoreCache dispose
INFO: Disposing datastore 'cgf'
INFO: Disposing datastore 'cite'
INFO: Disposing datastore 'cdf'
INFO: Disposing datastore 'sf'
May 1, 2012 1:41:41 AM org.geoserver.catalog.ResourcePool$FeatureTypeCache dispose
INFO: Disposing feature type 'Points'
May 1, 2012 1:41:41 AM org.geoserver.catalog.ResourcePool$CoverageHintReaderCache dispose
INFO: Disposing coverage store 'DEM'
INFO: Disposing coverage store 'largeMosaic'
{AllowMultithreading=false, Filter=, MaxAllowedTiles=-1, InputTransparentColor=, OutputTransparentColor=, SUGGESTED_TILE_SIZE=512,512, USE_JAI_IMAGEREAD=true, BackgroundValues=}
INFO: Disposing coverage store 'smallMosaic'
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.907 sec
Running org.geoserver.security.impl.DefaultDataAccessManagerAuthTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.045 sec
Running org.geoserver.security.rememberme.RememberMeTest
01 May 01:41:41 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock8224809795675995932data&gt;
01 May 01:41:42 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock264427974384667746data&gt;
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.165 sec
Results :
Failed tests:
  testRemoveLayerGroupWithWorkspace(org.geoserver.config.GeoServerPersisterTest)
Tests run: 449, Failures: 1, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 3 minutes 48 seconds
[INFO] Finished at: Tue May 01 01:41:42 UTC 2012
[INFO] Final Memory: 54M/328M
Failed to send e-mail to mcr because no e-mail address is known, and no default e-mail domain is configured
Sorry about that, I was pretty sure I fully build the project before
committing but it looks like I missed something. Fix is coming.
Gabriel
Changes:
Results :
Failed tests:
Gabriel Roldan
OpenGeo - http://opengeo.org
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/5074/changes&gt;
