[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-trunk #5081
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/5081/changes&gt;
Changes:
[riniangreani] App-schema isList tests: subsetting should affect other property values outside the filter properties.
[...truncated 66724 lines...]
            <gsml:observationMethod>
                <gsml:CGI_TermValue>
                    <gsml:value codeSpace="http://urn.opengis.net">urn:ogc:def:nil:OGC::missing</gsml:value>
                </gsml:CGI_TermValue>
            </gsml:observationMethod>
            <gsml:positionalAccuracy>
                <gsml:CGI_NumericValue>
                    <gsml:principalValue uom="urn:ogc:def:uom:UCUM:m">120.0</gsml:principalValue>
                </gsml:CGI_NumericValue>
            </gsml:positionalAccuracy>
            <gsml:samplingFrame xlink:href="urn:cgi:feature:CGI:EarthNaturalSurface"/>
            <gsml:specification>
                <gsml:GeologicUnit gml:id="gu.25682">
                    <gml:name codeSpace="urn:ietf:rfc:2141">New Group</gml:name>
                    <gml:name>-Xy</gml:name>
                    <gsml:purpose>instance</gsml:purpose>
                    <gsml:geologicUnitType xlink:href="urn:ogc:def:nil:OGC::unknown"/>
                </gsml:GeologicUnit>
            </gsml:specification>
            <gsml:shape>
                <gml:Point srsDimension="2" srsName="urn:x-ogc:def:crs:EPSG:4326">
                    <gml:pos>-34.9502 117.8102</gml:pos>
                </gml:Point>
            </gsml:shape>
        </gsml:MappedFeature>
    </gml:featureMember>
</wfs:FeatureCollection>
May 2, 2012 2:04:05 PM org.geoserver.test.PropertySelectionTest testSameNameDiffNamespace1
INFO: wfs?request=GetFeature&typeName=ex:MyTestFeature&propertyname=ex:name response:
<wfs:FeatureCollection numberOfFeatures="2" timeStamp="2012-05-02T14:04:05.906Z" xmlns:cv="http://www.opengis.net/cv/0.2.1&quot; xmlns:ex="http://example.com" xmlns:gml="http://www.opengis.net/gml&quot;
    xmlns:gsml="urn:cgi:xmlns:CGI:GeoSciML:2.0" xmlns:ogc="http://www.opengis.net/ogc&quot; xmlns:om="http://www.opengis.net/om/1.0&quot; xmlns:ows="http://www.opengis.net/ows&quot;
    xmlns:sa="http://www.opengis.net/sampling/1.0&quot; xmlns:sml="http://www.opengis.net/sensorML/1.0.1&quot; xmlns:swe="http://www.opengis.net/swe/1.0.1&quot; xmlns:wfs="http://www.opengis.net/wfs&quot;
    xmlns:xlink="http://www.w3.org/1999/xlink&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xsi:schemaLocation="http://example.com <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/app-schema-test/target/app-schema-mock5515428144044447460data/featureTypes/ex_MyTestFeature/SameNameDiffNamespace.xsd&gt; http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd&quot;&gt;
    <gml:featureMember>
        <ex:MyTestFeature gml:id="f1">
            <ex:name>First Feature</ex:name>
        </ex:MyTestFeature>
    <gml:featureMember>
        <ex:MyTestFeature gml:id="f2">
            <ex:name>Second Feature</ex:name>
        </ex:MyTestFeature>
May 2, 2012 2:04:05 PM org.geoserver.test.PropertySelectionTest testSameNameDiffNamespace2
INFO: wfs?request=GetFeature&typeName=ex:MyTestFeature&propertyname=gml:name response:
<wfs:FeatureCollection numberOfFeatures="2" timeStamp="2012-05-02T14:04:05.935Z" xmlns:cv="http://www.opengis.net/cv/0.2.1&quot; xmlns:ex="http://example.com" xmlns:gml="http://www.opengis.net/gml&quot;
    <gml:featureMember>
            <gml:name>Feature 1</gml:name>
        </ex:MyTestFeature>
    <gml:featureMember>
            <gml:name>Feature 2</gml:name>
        </ex:MyTestFeature>
May 2, 2012 2:04:05 PM org.geoserver.test.PropertySelectionTest testSameNameDiffNamespace3
INFO: WFS GetFeature response:
<wfs:FeatureCollection numberMatched="unknown" numberReturned="2" timeStamp="2012-05-02T14:04:05.963Z" xmlns:cv="http://www.opengis.net/cv/0.2.1&quot; xmlns:ex="http://example.com"
    xmlns:gml="http://www.opengis.net/gml&quot; xmlns:gsml="urn:cgi:xmlns:CGI:GeoSciML:2.0" xmlns:om="http://www.opengis.net/om/1.0&quot; xmlns:sa="http://www.opengis.net/sampling/1.0&quot;
    xmlns:sml="http://www.opengis.net/sensorML/1.0.1&quot; xmlns:swe="http://www.opengis.net/swe/1.0.1&quot; xmlns:wfs="http://www.opengis.net/wfs/2.0&quot; xmlns:xlink="http://www.w3.org/1999/xlink&quot;
    xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xsi:schemaLocation="http://www.opengis.net/gml/3.2 http://schemas.opengis.net/gml/3.2.1/gml.xsd http://www.opengis.net/wfs/2.0 http://schemas.opengis.net/wfs/2.0/wfs.xsd http://example.com <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/app-schema-test/target/app-schema-mock5515428144044447460data/featureTypes/ex_MyTestFeature/SameNameDiffNamespace.xsd&quot;&gt;&gt;
    <wfs:member>
        <ex:MyTestFeature id="f1">
        </ex:MyTestFeature>
    </wfs:member>
    <wfs:member>
        <ex:MyTestFeature id="f2">
        </ex:MyTestFeature>
    </wfs:member>
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.946 sec
Running org.geoserver.test.IdNotEncodedTest
02 May 14:04:06 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/app-schema-test/target/app-schema-mock1414759348270480094data&gt;
May 2, 2012 2:04:08 PM org.geoserver.test.IdNotEncodedTest testGetFeature
<wfs:FeatureCollection numberOfFeatures="4" timeStamp="2012-05-02T14:04:08.242Z" xmlns:cv="http://www.opengis.net/cv/0.2.1&quot; xmlns:gml="http://www.opengis.net/gml&quot;
    xmlns:gsml="urn:cgi:xmlns:CGI:GeoSciML:2.0" xmlns:gwml="http://www.nrcan.gc.ca/xml/gwml/1&quot; xmlns:ogc="http://www.opengis.net/ogc&quot; xmlns:om="http://www.opengis.net/om/1.0&quot;
    xmlns:ows="http://www.opengis.net/ows&quot; xmlns:sa="http://www.opengis.net/sampling/1.0&quot; xmlns:sml="http://www.opengis.net/sensorML/1.0.1&quot; xmlns:swe="http://www.opengis.net/swe/1.0.1&quot;
    xmlns:wfs="http://www.opengis.net/wfs&quot; xmlns:xlink="http://www.w3.org/1999/xlink&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xsi:schemaLocation="http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd http://www.nrcan.gc.ca/xml/gwml/1 <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/app-schema-test/target/app-schema-mock1414759348270480094data/featureTypes/gsml_MappedInterval/HydrogeologicUnit.xsd&quot;&gt;&gt;
    <gml:featureMember>
        <gsml:MappedInterval gml:id="123">
            <gml:description>aquifer</gml:description>
            <gml:name codeSpace="borehole.codespace1">mappedinterval.uri.123</gml:name>
                    <gsml:value codeSpace="borehole.codespace1">http://www.opengis.net/def/nil/OGC/0/unknown&lt;/gsml:value&gt;
                <gwml:HydrostratigraphicUnit gml:id="ubspatial.hydrostratigraphicunit.123">
                    <gml:description> blah</gml:description>
                    <gml:name codeSpace="borehole.codespace1">http://maps.ubspatial.com.au/resource/hydrostratigraphicunit/hydrostratigraphicunit.123&lt;/gml:name&gt;
                    <gsml:occurrence xlink:href="#123"/>
                </gwml:HydrostratigraphicUnit>
        </gsml:MappedInterval>
    <gml:featureMember>
        <gsml:MappedInterval gml:id="456">
            <gml:name codeSpace="borehole.codespace1">mappedinterval.uri.456</gml:name>
                <gwml:HydrostratigraphicUnit gml:id="ubspatial.hydrostratigraphicunit.456">
                    <gml:description> blah blah</gml:description>
                    <gml:name codeSpace="borehole.codespace1">http://maps.ubspatial.com.au/resource/hydrostratigraphicunit/hydrostratigraphicunit.456&lt;/gml:name&gt;
                    <gsml:occurrence xlink:href="#456"/>
    <gml:featureMember>
        <gsml:MappedInterval gml:id="789">
            <gml:description>lithology</gml:description>
            <gml:name codeSpace="borehole.codespace1">mappedinterval.uri.789</gml:name>
                <gwml:HydrostratigraphicUnit gml:id="ubspatial.hydrostratigraphicunit.789">
                    <gml:description> bleh</gml:description>
                    <gml:name codeSpace="borehole.codespace1">http://maps.ubspatial.com.au/resource/hydrostratigraphicunit/hydrostratigraphicunit.789&lt;/gml:name&gt;
                    <gsml:occurrence xlink:href="#789"/>
    <gml:featureMember>
        <gsml:MappedInterval gml:id="012">
            <gml:name codeSpace="borehole.codespace1">mappedinterval.uri.012</gml:name>
                <gwml:HydrostratigraphicUnit gml:id="ubspatial.hydrostratigraphicunit.012">
                    <gml:description> bleh bleh</gml:description>
                    <gml:name codeSpace="borehole.codespace1">http://maps.ubspatial.com.au/resource/hydrostratigraphicunit/hydrostratigraphicunit.012&lt;/gml:name&gt;
                    <gsml:occurrence xlink:href="#012"/>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.305 sec
Results :
Failed tests:
  testQuantityListSubset(org.geoserver.test.TimeSeriesInlineWfsTest)
  testTimePositionSubset(org.geoserver.test.TimeSeriesInlineWfsTest)
  testTimePositionSubset(org.geoserver.test.WaterMLTimeSeriesWfsTest)
  testFilter(org.geoserver.test.WaterMLTimeSeriesWfsTest)
Tests run: 107, Failures: 4, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/app-schema-test/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 27 minutes 36 seconds
[INFO] Finished at: Wed May 02 14:04:08 UTC 2012
[INFO] Final Memory: 71M/324M
Failed to send e-mail to riniangreani because no e-mail address is known, and no default e-mail domain is configured
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/5082/&gt;
