[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-trunk #5090
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/5090/changes&gt;
Changes:
[aaime] [GEOS-5048] User-defined Datum Shifts, patch by Oscar Fonts, tests by yours truly
[...truncated 464 lines...]
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.022 sec
Running org.geoserver.ows.util.OwsUtilsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Running org.geoserver.ows.kvp.TimeKvpParserTest
May 6, 2012 10:39:02 AM org.geoserver.ows.kvp.TimeKvpParser parse
INFO: Lmiting number of elements in this periodo to 100
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.41 sec
Running org.geoserver.ows.kvp.FormatOptionsKvpParserTest
May 6, 2012 10:39:02 AM org.geoserver.platform.GeoServerExtensions checkContext
SEVERE: Extension lookup occured, but ApplicationContext is unset.
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Running org.geoserver.ows.DispatcherTest
May 6, 2012 10:39:02 AM org.springframework.context.support.AbstractApplicationContext prepareRefresh
INFO: Refreshing org.springframework.context.support.FileSystemXmlApplicationContext@anonymised.com: startup date [Sun May 06 10:39:02 UTC 2012]; root of context hierarchy
May 6, 2012 10:39:02 AM org.springframework.beans.factory.xml.XmlBeanDefinitionReader loadBeanDefinitions
INFO: Loading XML bean definitions from URL [<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/test-classes/org/geoserver/ows/applicationContext.xml\]>
May 6, 2012 10:39:03 AM org.springframework.beans.factory.support.DefaultListableBeanFactory preInstantiateSingletons
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com: defining beans [extensions,dispatcher,messageKvpReader,messageXmlReader,messageResponse,hello,helloWorld,helloWorldService]; root of factory hierarchy
May 6, 2012 10:39:03 AM org.springframework.context.support.AbstractApplicationContext prepareRefresh
INFO: Refreshing org.springframework.context.support.FileSystemXmlApplicationContext@anonymised.com: startup date [Sun May 06 10:39:03 UTC 2012]; root of context hierarchy
May 6, 2012 10:39:03 AM org.springframework.beans.factory.xml.XmlBeanDefinitionReader loadBeanDefinitions
INFO: Loading XML bean definitions from URL [<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/test-classes/org/geoserver/ows/applicationContextOnlyXml.xml\]>
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com: defining beans [extensions,dispatcher,messageXmlReader,messageResponse,hello,helloWorld,helloWorldService]; root of factory hierarchy
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.063 sec
Running org.geoserver.ows.kvp.KvpUtilsTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.geoserver.ows.kvp.CharsetKvpParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.033 sec
Results :
Tests run: 46, Failures: 0, Errors: 0, Skipped: 0
Downloading: http://repo.opengeo.org//org/geotools/ogc/org.w3.xlink/8-SNAPSHOT/org.w3.xlink-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-graph/8-SNAPSHOT/gt-graph-8-SNAPSHOT.jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.2-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows&gt; (directory)
[WARNING] the "build.repository" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.path" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.revision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.mixedRevisions" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedRevision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedDate" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.status" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.specialStatus" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.2-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.2-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.2-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/ows/2.2-SNAPSHOT/ows-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/ows/2.2-SNAPSHOT/ows-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.2-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/ows/2.2-SNAPSHOT/ows-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.2-SNAPSHOT-test-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/ows/2.2-SNAPSHOT/ows-2.2-SNAPSHOT-test-sources.jar
[INFO] Building Main Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main&gt; (directory)
[INFO] Copying 31 resources
[INFO] Copying 159 resources
[INFO] snapshot org.geotools:gt-cql:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-cql:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-validation:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-validation:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-data:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-data:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-jdbc:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-jdbc:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-property:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-property:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:plugin:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:plugin:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-epsg-hsql:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-epsg-hsql:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-wms:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-wms:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-xml:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-xml:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-xml:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-xml:8-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-render:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-render:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-render:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-render:8-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.xsd:gt-xsd-sld:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-sld:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-arcgrid:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-arcgrid:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-geotiff:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-geotiff:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-gtopo30:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-gtopo30:8-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/gt-gtopo30/8-SNAPSHOT/gt-gtopo30-8-SNAPSHOT.pom
[INFO] snapshot org.geotools:gt-image:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-image:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-imagemosaic:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-imagemosaic:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:8-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.jdbc:gt-jdbc:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.jdbc:gt-jdbc:8-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-shapefile:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-shapefile:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-shapefile:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-shapefile:8-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-wfs:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-wfs:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:unsupported:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:unsupported:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:8-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:8-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.ogc:net.opengis.fes:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.fes:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.ogc:net.opengis.fes:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.ogc:net.opengis.fes:8-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:8-SNAPSHOT: checking for updates from geosolutions
[INFO] Compiling 524 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/classes&gt;
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/crs/GeoserverWKTOperationFactory.java&gt;:\[11,44\] cannot find symbol
symbol : class CoordinateOperationFactoryUsingWKT
location: package org.geotools.referencing.factory.epsg
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/crs/GeoserverWKTOperationFactory.java&gt;:\[21,50\] cannot find symbol
symbol: class CoordinateOperationFactoryUsingWKT
public class GeoserverWKTOperationFactory extends CoordinateOperationFactoryUsingWKT
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/crs/GeoserverWKTOperationFactory.java&gt;:\[21,7\] org.vfny.geoserver.crs.GeoserverWKTOperationFactory is not abstract and does not override abstract method createFromCoordinateReferenceSystemCodes(java.lang.String,java.lang.String) in org.opengis.referencing.operation.CoordinateOperationAuthorityFactory
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/crs/GeoserverWKTOperationFactory.java&gt;:\[25,20\] cannot find symbol
symbol : variable MAXIMUM_PRIORITY
location: class org.vfny.geoserver.crs.GeoserverWKTOperationFactory
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/crs/GeoserverWKTOperationFactory.java&gt;:\[29,25\] cannot find symbol
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/crs/GeoserverWKTOperationFactory.java&gt;:\[39,38\] cannot find symbol
symbol : variable FILENAME
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/crs/GeoserverWKTOperationFactory.java&gt;:\[44,12\] cannot find symbol
symbol : variable LOGGER
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/crs/GeoserverWKTOperationFactory.java&gt;:\[47,67\] cannot find symbol
[INFO] Total time: 2 minutes 8 seconds
[INFO] Finished at: Sun May 06 10:39:59 UTC 2012
[INFO] Final Memory: 53M/299M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/5091/changes&gt;
