[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-trunk #5096
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/5096/changes&gt;
Changes:
[mcr] Fix GEOS-5100
[...truncated 43770 lines...]
  at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl.transform(TransformerImpl.java:707)
  at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl.transform(TransformerImpl.java:313)
  at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:298)
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:131)
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:110)
  at org.geoserver.wms.capabilities.GetCapabilitiesResponse.write(GetCapabilitiesResponse.java:143)
  at org.geoserver.ows.Dispatcher.response(Dispatcher.java:909)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:276)
  at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
  at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
  at org.geoserver.test.GeoServerAbstractTestSupport$3.service(GeoServerAbstractTestSupport.java:1236)
  at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1255)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1190)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:606)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:589)
  at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:574)
  at org.geoserver.gwc.wms.CachingExtendedCapabilitiesProviderTest.testTileSets(CachingExtendedCapabilitiesProviderTest.java:67)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:147)
  at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
  at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
  at junit.extensions.TestSetup.run(TestSetup.java:25)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
May 7, 2012 4:00:55 PM org.geoserver.catalog.impl.ResourceInfoImpl boundingBox
WARNING: Failed to derive native bbox from declared one
org.geotools.referencing.operation.projection.ProjectionException: The transform result may be 11,823,003.718 meters away from the expected position. Are you sure that the input coordinates are inside this map projection area of validity? The point is located 19°12.4'E away from the central meridian and 0°00.0'N away from the latitude of origin. The projection is "Transverse_Mercator".
  at org.geotools.referencing.operation.projection.MapProjection.checkReciprocal(MapProjection.java:679)
  at org.geotools.referencing.operation.projection.MapProjection.transform(MapProjection.java:871)
  at org.geotools.referencing.operation.projection.MapProjection.transform(MapProjection.java:906)
  at org.geotools.referencing.operation.transform.AbstractMathTransform.transform(AbstractMathTransform.java:237)
  at org.geotools.referencing.CRS.transform(CRS.java:1284)
  at org.geotools.referencing.CRS.transform(CRS.java:1350)
  at org.geotools.geometry.jts.ReferencedEnvelope.transform(ReferencedEnvelope.java:648)
  at org.geotools.geometry.jts.ReferencedEnvelope.transform(ReferencedEnvelope.java:603)
  at org.geoserver.catalog.impl.ResourceInfoImpl.boundingBox(ResourceInfoImpl.java:214)
  at sun.reflect.GeneratedMethodAccessor144.invoke(Unknown Source)
  at org.geoserver.catalog.impl.ModificationProxy.invoke(ModificationProxy.java:144)
  at $Proxy10.boundingBox(Unknown Source)
  at org.geoserver.wms.capabilities.GetCapabilitiesTransformer$CapabilitiesTranslator.handleLayer(GetCapabilitiesTransformer.java:830)
  at org.geoserver.wms.capabilities.GetCapabilitiesTransformer$CapabilitiesTranslator.handleLayerTree(GetCapabilitiesTransformer.java:759)
  at org.geoserver.wms.capabilities.GetCapabilitiesTransformer$CapabilitiesTranslator.handleLayers(GetCapabilitiesTransformer.java:641)
  at org.geoserver.wms.capabilities.GetCapabilitiesTransformer$CapabilitiesTranslator.handleCapability(GetCapabilitiesTransformer.java:407)
  at org.geoserver.wms.capabilities.GetCapabilitiesTransformer$CapabilitiesTranslator.encode(GetCapabilitiesTransformer.java:275)
  at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:716)
  at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl.transformIdentity(TransformerImpl.java:636)
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.107 sec
Running org.geoserver.gwc.GWCTransactionListenerTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.065 sec
Running org.geoserver.gwc.layer.CatalogLayerEventListenerTest
May 7, 2012 4:00:58 PM org.geoserver.gwc.layer.CatalogLayerEventListener handleLayerGroupInfoChange
INFO: Truncating TileLayer for layer group 'LayerGroupName' due to a change in its layers or styles
May 7, 2012 4:00:58 PM org.geoserver.gwc.layer.CatalogLayerEventListener handleLayerInfoChange
INFO: Truncating default style for layer mock:Layer, as it changed from oldStyle to newStyle
INFO: Truncating cached style removedStyleName of layer mock:Layer as it's no longer one of the layer's styles
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.101 sec
Results :
Tests run: 111, Failures: 0, Errors: 0, Skipped: 0
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-sld/8-SNAPSHOT/gt-xsd-sld-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-property/8-SNAPSHOT/gt-property-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-fes/8-SNAPSHOT/gt-xsd-fes-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-render/8-SNAPSHOT/gt-render-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-image/8-SNAPSHOT/gt-image-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-arcgrid/8-SNAPSHOT/gt-arcgrid-8-SNAPSHOT.jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/gwc-2.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/gwc-2.2-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc&gt; (directory)
[WARNING] the "build.repository" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.path" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.revision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.mixedRevisions" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedRevision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedDate" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.status" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.specialStatus" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/gwc-2.2-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/gwc-2.2-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/gwc-2.2-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/gwc/2.2-SNAPSHOT/gwc-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/gwc-2.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/gwc/2.2-SNAPSHOT/gwc-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/gwc-2.2-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/gwc/2.2-SNAPSHOT/gwc-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/gwc-2.2-SNAPSHOT-test-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/gwc/2.2-SNAPSHOT/gwc-2.2-SNAPSHOT-test-sources.jar
[INFO] Building REST Support Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/rest/target&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/rest&gt; (directory)
[INFO] Copying 3 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/rest/src/main/resources&gt;
Downloading: http://repo.opengeo.org//org/geotools/gt-main/8-SNAPSHOT/gt-main-8-SNAPSHOT.jar
[INFO] Compiling 24 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/rest/target/classes&gt;
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/rest/src/test/resources&gt;
[INFO] Compiling 12 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/rest/target/test-classes&gt;
[ERROR] BUILD ERROR
[INFO] Fatal error compiling
Embedded error: Error while executing the external compiler.
java.io.IOException: error=12, Cannot allocate memory
[INFO] Total time: 22 minutes 41 seconds
[INFO] Finished at: Mon May 07 16:01:02 UTC 2012
[INFO] Final Memory: 63M/267M
Failed to send e-mail to mcr because no e-mail address is known, and no default e-mail domain is configured
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/5097/changes&gt;
Changes:
[afabiani] - JIRA: GEOS 5099
[...truncated 53337 lines...]
org.geotools.referencing.operation.projection.ProjectionException: The transform result may be 200,566.547 meters away from the expected position. Are you sure that the input coordinates are inside this map projection area of validity? The point is located 53°23.4'W away from the central meridian and 21327°36.2'S away from the latitude of origin. The projection is "Transverse_Mercator".
  at org.geoserver.wms.DefaultWebMapService.autoSetBoundsAndSize(DefaultWebMapService.java:563)
  at org.geoserver.web.demo.PreviewLayer.getRequest(PreviewLayer.java:144)
  at org.geoserver.web.demo.PreviewLayer.getWmsLink(PreviewLayer.java:192)
  at org.geoserver.web.demo.MapPreviewPage$1.getComponentForProperty(MapPreviewPage.java:81)
  at org.geoserver.web.wicket.GeoServerTablePanel$1$1.populateItem(GeoServerTablePanel.java:143)
  at org.apache.wicket.markup.html.list.ListView.onPopulate(ListView.java:562)
  at org.apache.wicket.markup.repeater.AbstractRepeater.onBeforeRender(AbstractRepeater.java:131)
  at org.apache.wicket.Component.internalBeforeRender(Component.java:1071)
  at org.apache.wicket.Component.beforeRender(Component.java:1105)
  at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1753)
  at org.apache.wicket.Component.onBeforeRender(Component.java:3946)
  at org.apache.wicket.markup.repeater.AbstractRepeater.onBeforeRender(AbstractRepeater.java:151)
  at org.apache.wicket.markup.repeater.AbstractPageableView.onBeforeRender(AbstractPageableView.java:121)
  at org.apache.wicket.Page.onBeforeRender(Page.java:1531)
  at org.apache.wicket.Component.prepareForRender(Component.java:2292)
  at org.apache.wicket.Page.prepareForRender(Page.java:1521)
  at org.apache.wicket.Component.prepareForRender(Component.java:2329)
  at org.apache.wicket.Page.renderPage(Page.java:892)
  at org.apache.wicket.request.target.component.PageRequestTarget.respond(PageRequestTarget.java:63)
  at org.apache.wicket.request.AbstractRequestCycleProcessor.respond(AbstractRequestCycleProcessor.java:105)
  at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1258)
  at org.apache.wicket.RequestCycle.step(RequestCycle.java:1329)
  at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1436)
  at org.apache.wicket.RequestCycle.request(RequestCycle.java:545)
  at org.apache.wicket.protocol.http.MockWebApplication.processRequestCycle(MockWebApplication.java:527)
  at org.apache.wicket.util.tester.BaseWicketTester.executeListener(BaseWicketTester.java:262)
  at org.apache.wicket.util.tester.BaseWicketTester.clickLink(BaseWicketTester.java:861)
  at org.geoserver.web.demo.MapPreviewPageTest.testLayerNamesPrefixed(MapPreviewPageTest.java:63)
Tests run: 3, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 22.949 sec <<< FAILURE!
Running org.geoserver.web.demo.PreviewLayerProviderTest
08 May 11:08:19 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/./target/mock4353756782433579236data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.458 sec
Running org.geoserver.web.demo.SRSListPageTest
08 May 11:08:21 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/./target/mock5530472779810873819data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.594 sec
Running org.geoserver.web.demo.ReprojectPageTest
08 May 11:08:23 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/./target/mock8122417634770507567data&gt;
08 May 11:08:24 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/./target/mock1175255841512376522data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/./target/mock8974479625154625727data&gt;
08 May 11:08:25 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/./target/mock4297469143163997837data&gt;
08 May 11:08:27 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/./target/mock4694393581557016109data&gt;
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.536 sec
Running org.geoserver.web.demo.DemoRequestsPageTest
08 May 11:08:28 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/./target/mock7990124259669022269data&gt;
08 May 11:08:29 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/./target/mock5732581082563596344data&gt;
08 May 11:08:30 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/./target/mock4240049439029049227data&gt;
08 May 11:08:31 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/./target/mock5639370953392448764data&gt;
08 May 11:08:32 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/./target/mock2116666942857624343data&gt;
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.554 sec
Results :
Failed tests:
  testLayerNamesPrefixed(org.geoserver.web.demo.MapPreviewPageTest)
Tests run: 15, Failures: 1, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 30 minutes 49 seconds
[INFO] Finished at: Tue May 08 11:08:34 UTC 2012
[INFO] Final Memory: 60M/287M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/5098/changes&gt;
