See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/5112/changes>
Changes:
[afabiani] - GEOS-5110
[...truncated 69295 lines...]
<xsd:sequence>
<xsd:element maxOccurs="1" minOccurs="0"
name="specification" nillable="false" type="gml:FeaturePropertyType"/>
<xsd:element maxOccurs="1" minOccurs="1"
name="shape" nillable="false" type="gml:GeometryPropertyType"/>
</xsd:sequence>
</xsd:extension>
</xsd:complexContent>
</xsd:complexType>
<xsd:element name="MappedFeature" substitutionGroup="gml:_Feature" type="gsml:MappedFeatureType"/>
</xsd:schema>
May 11, 2012 3:27:59 PM org.geoserver.test.SampleDataAccessWfsTest testGetFeature
INFO: WFS GetFeature response:
<wfs:FeatureCollection numberOfFeatures="2"
timeStamp="2012-05-11T15:27:59.389Z"
xmlns:gml="http://www.opengis.net/gml"
xmlns:gsml="http://www.example.org/sample-data-access/GeoSciML-lite"
xmlns:ogc="http://www.opengis.net/ogc"
xmlns:ows="http://www.opengis.net/ows"
xmlns:wfs="http://www.opengis.net/wfs"
xmlns:xlink="http://www.w3.org/1999/xlink"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/wfs http://localhost:8080/geoserver/schemas/wfs/1.1.0/wfs.xsd http://www.example.org/sample-data-access/GeoSciML-lite http://localhost:8080/geoserver/wfs?service=WFS&version=1.1.0&request=DescribeFeatureType&typeName=gsml%3AMappedFeature">
<gml:featureMembers>
<gsml:MappedFeature gml:id="mf1">
<gml:description>GUNTHORPE FORMATION</gml:description>
<gsml:specification>
<gsml:GeologicUnit gml:id="mf1.spec">
<gml:description>Gunthorpe specification description</gml:description>
</gsml:GeologicUnit>
</gsml:specification>
<gsml:shape>
<gml:Polygon>
<gml:exterior>
<gml:LinearRing>
<gml:posList>-1.2 52.5 -1.2 52.6 -1.1 52.6 -1.1 52.5 -1.2 52.5</gml:posList>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</gsml:shape>
</gsml:MappedFeature>
<gsml:MappedFeature gml:id="mf2">
<gml:description>MERCIA MUDSTONE GROUP</gml:description>
<gsml:GeologicUnit gml:id="mf2.spec">
<gml:description>Mercia specification description</gml:description>
<gsml:shape>
<gml:Polygon>
<gml:exterior>
<gml:LinearRing>
<gml:posList>-1.3 52.5 -1.3 52.6 -1.2 52.6 -1.2 52.5 -1.3 52.5</gml:posList>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</gsml:shape>
</gml:featureMembers>
</wfs:FeatureCollection>
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 11.105 sec
Results :
Downloading: http://repo.opengeo.org//org/geotools/gt-jdbc/8-SNAPSHOT/gt-jdbc-8-SNAPSHOT.jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/sample-data-access-test/target/sample-data-access-test-2.2-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/sample-data-access-test/target/sample-data-access-test-2.2-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/sample-data-access-test> (directory)
[WARNING] the "build.repository" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.path" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.revision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.mixedRevisions" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedRevision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedDate" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.status" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.specialStatus" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/sample-data-access-test/target/sample-data-access-test-2.2-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/sample-data-access-test/target/sample-data-access-test-2.2-SNAPSHOT-test-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/sample-data-access-test/target/sample-data-access-test-2.2-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/sample-data-access-test/2.2-SNAPSHOT/sample-data-access-test-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/sample-data-access-test/target/sample-data-access-test-2.2-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/sample-data-access-test/2.2-SNAPSHOT/sample-data-access-test-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/sample-data-access-test/target/sample-data-access-test-2.2-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/sample-data-access-test/2.2-SNAPSHOT/sample-data-access-test-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/sample-data-access-test/target/sample-data-access-test-2.2-SNAPSHOT-test-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/sample-data-access-test/2.2-SNAPSHOT/sample-data-access-test-2.2-SNAPSHOT-test-sources.jar
[INFO] Building ArcSDE DataStore Extension
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target>
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde> (directory)
[INFO] Copying 6 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/src/main/resources>
[INFO] snapshot org.geotools:gt-arcsde-common:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-arcsde-common:8-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/gt-arcsde-common/8-SNAPSHOT/gt-arcsde-common-8-SNAPSHOT.pom
[INFO] snapshot org.geotools:arcsde-plugin:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:arcsde-plugin:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-arcsde:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-arcsde:8-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/gt-arcsde/8-SNAPSHOT/gt-arcsde-8-SNAPSHOT.pom
[INFO] snapshot org.geotools:gt-sde-dummy:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-sde-dummy:8-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/gt-arcsde-common/8-SNAPSHOT/gt-arcsde-common-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-arcsde/8-SNAPSHOT/gt-arcsde-8-SNAPSHOT.jar
[INFO] Compiling 2 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/classes>
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/src/test/resources>
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/test-classes>
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/surefire-reports>
T E S T S
Running org.geoserver.web.data.store.arcsde.ArcSDECoverageStoreEditPanelTest
11 May 15:28:06 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/./target/mock4956947310997677132data>
11 May 15:28:12 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/./target/mock3749987163466922606data>
11 May 15:28:13 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/./target/mock6888732506512902756data>
11 May 15:28:14 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/./target/mock9051333175545760549data>
11 May 15:28:15 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/./target/mock436622853227525339data>
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 11.25 sec
Results :
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/arcsde-2.2-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/arcsde-2.2-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/arcsde-2.2-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/arcsde-2.2-SNAPSHOT-test-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/arcsde-2.2-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/arcsde/2.2-SNAPSHOT/arcsde-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/arcsde-2.2-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/arcsde/2.2-SNAPSHOT/arcsde-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/arcsde-2.2-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/arcsde/2.2-SNAPSHOT/arcsde-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/arcsde-2.2-SNAPSHOT-test-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/arcsde/2.2-SNAPSHOT/arcsde-2.2-SNAPSHOT-test-sources.jar
[INFO] Building GeoSearch Index Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/geosearch/target>
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/geosearch> (directory)
[INFO] Copying 3 resources
[INFO] Copying 4 resources
[INFO] Compiling 13 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/geosearch/target/classes>
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/geosearch/src/main/java/org/geoserver/geosearch/rest/KMLMetadataDocumentTransformer.java>:\[117,63\] cannot find symbol
symbol : constructor KMLNetworkLinkTransformer(org.geoserver.wms.WMS)
location: class org.geoserver.kml.KMLNetworkLinkTransformer
[INFO] Total time: 28 minutes 25 seconds
[INFO] Finished at: Fri May 11 15:28:19 UTC 2012
[INFO] Final Memory: 69M/346M
