See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/5154/changes>
Changes:
[jdeolive] GEOS-5134, adding doReturn() functionality to geoserver base page
[...truncated 74696 lines...]
[WARNING] the "build.repository" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.path" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.revision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.mixedRevisions" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedRevision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedDate" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.status" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.specialStatus" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/feature-pregeneralized/target/feature-pregeneralized-2.2-SNAPSHOT-test-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/feature-pregeneralized/target/feature-pregeneralized-2.2-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/feature-pregeneralized/2.2-SNAPSHOT/feature-pregeneralized-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/feature-pregeneralized/target/feature-pregeneralized-2.2-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/feature-pregeneralized/2.2-SNAPSHOT/feature-pregeneralized-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/feature-pregeneralized/target/feature-pregeneralized-2.2-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/feature-pregeneralized/2.2-SNAPSHOT/feature-pregeneralized-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/feature-pregeneralized/target/feature-pregeneralized-2.2-SNAPSHOT-test-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/feature-pregeneralized/2.2-SNAPSHOT/feature-pregeneralized-2.2-SNAPSHOT-test-sources.jar
[INFO] Building Image Mosaic JDBC Extension
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemosaic-jdbc/target>
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemosaic-jdbc> (directory)
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemosaic-jdbc/src/main/java>
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemosaic-jdbc/src/main/resources>
[INFO] snapshot org.geotools:gt-imagemosaic-jdbc:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-imagemosaic-jdbc:8-SNAPSHOT: checking for updates from osgeo
[INFO] No sources to compile
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemosaic-jdbc/src/test/java>
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemosaic-jdbc/src/test/resources>
[INFO] No tests to run.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.2-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.2-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.2-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.2-SNAPSHOT-test-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.2-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.2-SNAPSHOT/imagemosaic-jdbc-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.2-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.2-SNAPSHOT/imagemosaic-jdbc-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.2-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.2-SNAPSHOT/imagemosaic-jdbc-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.2-SNAPSHOT-test-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.2-SNAPSHOT/imagemosaic-jdbc-2.2-SNAPSHOT-test-sources.jar
[INFO] Building OWS request flow controller
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/control-flow/target>
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/control-flow> (directory)
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/control-flow/src/main/resources>
Downloading: http://repo.opengeo.org//org/geotools/gt-render/8-SNAPSHOT/gt-render-8-SNAPSHOT.jar
[INFO] Compiling 14 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/control-flow/target/classes>
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/control-flow/src/test/resources>
[INFO] Compiling 11 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/control-flow/target/test-classes>
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/control-flow/target/surefire-reports>
T E S T S
Running org.geoserver.flow.NestedRequestSentinelTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.038 sec
Running org.geoserver.flow.controller.IpFlowControllerTest
Thread[Thread-1,5,main] calling requestIncoming
Thread[Thread-1,5,main] waiting
Thread[Thread-1,5,main] calling requestComplete
Thread[Thread-1,5,main] done
Thread[Thread-2,5,main] calling requestIncoming
Thread[Thread-2,5,main] waiting
Thread[Thread-3,5,main] calling requestIncoming
sleep interrupted
Thread[Thread-2,5,main] calling requestComplete
Thread[Thread-2,5,main] done
Thread[Thread-3,5,main] waiting
sleep interrupted
Thread[Thread-3,5,main] calling requestComplete
Thread[Thread-3,5,main] done
Thread[Thread-4,5,main] calling requestIncoming
Thread[Thread-4,5,main] waiting
Thread[Thread-5,5,main] calling requestIncoming
Thread[Thread-5,5,main] waiting
sleep interrupted
Thread[Thread-4,5,main] calling requestComplete
Thread[Thread-4,5,main] done
sleep interrupted
Thread[Thread-5,5,main] calling requestComplete
Thread[Thread-5,5,main] done
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.178 sec
Running org.geoserver.flow.controller.BasicOWSFlowControllerTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.009 sec
Running org.geoserver.flow.controller.UserFlowControllerTest
Thread[Thread-6,5,main] calling requestIncoming
Thread[Thread-6,5,main] waiting
Thread[Thread-6,5,main] calling requestComplete
Thread[Thread-6,5,main] done
Thread[Thread-7,5,main] calling requestIncoming
Thread[Thread-7,5,main] waiting
Thread[Thread-8,5,main] calling requestIncoming
sleep interrupted
Thread[Thread-7,5,main] calling requestComplete
Thread[Thread-7,5,main] done
Thread[Thread-8,5,main] waiting
sleep interrupted
Thread[Thread-8,5,main] calling requestComplete
Thread[Thread-8,5,main] done
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.085 sec
Running org.geoserver.flow.controller.GlobalFlowControllerTest
Thread[Thread-9,5,main] calling requestIncoming
Thread[Thread-9,5,main] waiting
Thread[Thread-10,5,main] calling requestIncoming
Thread[Thread-9,5,main] calling requestComplete
Thread[Thread-9,5,main] done
Thread[Thread-11,5,main] calling requestIncoming
Thread[Thread-11,5,main] waiting
Thread[Thread-12,5,main] calling requestIncoming
Thread[Thread-13,5,main] calling requestIncoming
sleep interrupted
Thread[Thread-11,5,main] calling requestComplete
Thread[Thread-11,5,main] done
Thread[Thread-12,5,main] waiting
sleep interrupted
Thread[Thread-12,5,main] calling requestComplete
Thread[Thread-12,5,main] done
Thread[Thread-13,5,main] waiting
sleep interrupted
Thread[Thread-13,5,main] calling requestComplete
Thread[Thread-13,5,main] done
Tests run: 3, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 1.501 sec <<< FAILURE!
Running org.geoserver.flow.controller.IpBlacklistFilterTest
30 May 23:07:10 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/control-flow/./target/mock898204214870151404data>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.586 sec
Running org.geoserver.flow.controller.SingleIpFlowControllerTest
Thread[Thread-18,5,main] calling requestIncoming
Thread[Thread-18,5,main] waiting
Thread[Thread-18,5,main] calling requestComplete
Thread[Thread-18,5,main] done
Thread[Thread-19,5,main] calling requestIncoming
Thread[Thread-19,5,main] waiting
Thread[Thread-20,5,main] calling requestIncoming
sleep interrupted
Thread[Thread-19,5,main] calling requestComplete
Thread[Thread-19,5,main] done
Thread[Thread-20,5,main] waiting
sleep interrupted
Thread[Thread-20,5,main] calling requestComplete
Thread[Thread-20,5,main] done
Thread[Thread-21,5,main] calling requestIncoming
Thread[Thread-21,5,main] waiting
Thread[Thread-21,5,main] calling requestComplete
Thread[Thread-21,5,main] done
Thread[Thread-22,5,main] calling requestIncoming
Thread[Thread-22,5,main] waiting
Thread[Thread-23,5,main] calling requestIncoming
Thread[Thread-23,5,main] waiting
sleep interrupted
Thread[Thread-22,5,main] calling requestComplete
Thread[Thread-22,5,main] done
sleep interrupted
Thread[Thread-23,5,main] calling requestComplete
Thread[Thread-23,5,main] done
Thread[Thread-24,5,main] calling requestIncoming
Thread[Thread-24,5,main] waiting
Thread[Thread-25,5,main] calling requestIncoming
Thread[Thread-25,5,main] waiting
sleep interrupted
Thread[Thread-24,5,main] calling requestComplete
Thread[Thread-24,5,main] done
sleep interrupted
Thread[Thread-25,5,main] calling requestComplete
Thread[Thread-25,5,main] done
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.228 sec
Running org.geoserver.flow.ControlFlowCallbackTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.204 sec
Running org.geoserver.flow.config.DefaultControlFlowConfigurationTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.003 sec
Results :
Failed tests:
testSingleDelay(org.geoserver.flow.controller.GlobalFlowControllerTest)
Tests run: 18, Failures: 1, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/control-flow/target/surefire-reports> for the individual test results.
[INFO] Total time: 30 minutes 16 seconds
[INFO] Finished at: Wed May 30 23:07:15 UTC 2012
[INFO] Final Memory: 81M/418M
