[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-trunk #5157
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/5157/&gt;
[...truncated 12508 lines...]
31 May 15:31:23 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock1595733808633842553data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock8384502149240877762data&gt;
31 May 15:31:24 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock8396953026844539401data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock5248743242269415966data&gt;
31 May 15:31:25 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock2220795418873525033data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock9173406153669723349data&gt;
31 May 15:31:26 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock3359203355795473078data&gt;
31 May 15:31:27 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock4431317632177192364data&gt;
31 May 15:31:31 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock5206358597264368471data&gt;
Tests run: 45, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 24.48 sec
Running org.geoserver.template.GeoServerTemplateLoader2Test
31 May 15:31:33 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock6247714532289588804data&gt;
31 May 15:31:35 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock4139572094447730558data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock4843143704862249821data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock1528297286728121067data&gt;
31 May 15:31:36 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock8411156190541893153data&gt;
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.506 sec
Running org.geoserver.ows.URLManglersTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock7536156658534526391data&gt;
31 May 15:31:37 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock5584843726381539835data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock1630856170421431481data&gt;
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.415 sec
Running org.geoserver.security.GeoServerRoleFilterTest
31 May 15:31:38 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock3907358684011121914data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock58379065966009040data&gt;
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.591 sec
Running org.geoserver.security.validation.PasswordValidatorTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/live5406105343059731659data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.25 sec
Running org.geoserver.security.impl.DataAccessRuleDAOTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Running org.geoserver.security.impl.GeoServerUserDaoTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.007 sec
Running org.geoserver.security.xml.XMLRoleServiceTest
31 May 15:31:39 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/live3309490066888201427data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/live980474869232162189data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/live5130068790562285322data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/live3709712471478904031data&gt;
31 May 15:31:41 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/live8259315218405120196data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/live7869933787995682847data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/live71947966595793900data&gt;
31 May 15:31:42 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/live3060693347475694080data&gt;
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.001 sec
Running org.geoserver.data.util.CoverageUtilsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.001 sec
Running org.geoserver.security.decorators.SecuredFeatureSourceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.011 sec
Running org.geoserver.catalog.impl.CatalogBuilderTest
31 May 15:31:43 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock1615632224829608293data&gt;
May 31, 2012 3:31:43 PM org.geotools.referencing.operation.projection.TransverseMercator.Inverse transform
WARNING: Possible use of "Transverse_Mercator (Inverse transform)" projection outside its valid area.
Latitude 2181°05.9'N is out of range (±90°).
May 31, 2012 3:31:43 PM org.geoserver.test.RemoteOWSTestSupport isRemoteWMSStatesAvailable
WARNING: Skipping remote OWS test because they were not enabled via -DremoteOwsTests=true
May 31, 2012 3:31:43 PM org.geoserver.catalog.impl.CatalogBuilderTest testWMS
WARNING: Remote OWS tests disabled, skipping catalog builder wms tests
May 31, 2012 3:31:49 PM org.geoserver.catalog.ResourcePool$DataStoreCache dispose
INFO: Disposing datastore 'sf'
INFO: Disposing datastore 'cgf'
INFO: Disposing datastore 'cite'
INFO: Disposing datastore 'cdf'
May 31, 2012 3:31:49 PM org.geoserver.catalog.ResourcePool$FeatureTypeCache dispose
INFO: Disposing feature type 'Points'
May 31, 2012 3:31:49 PM org.geoserver.catalog.ResourcePool$CoverageHintReaderCache dispose
INFO: Disposing coverage store 'largeMosaic'
INFO: Disposing coverage store 'DEM'
{AllowMultithreading=false, Filter=, MaxAllowedTiles=-1, InputTransparentColor=, OutputTransparentColor=, SUGGESTED_TILE_SIZE=512,512, USE_JAI_IMAGEREAD=true, BackgroundValues=}
May 31, 2012 3:31:55 PM org.geoserver.catalog.ResourcePool$CoverageHintReaderCache dispose
INFO: Disposing coverage store 'smallMosaic'
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 12.533 sec
Running org.geoserver.security.impl.DefaultDataAccessManagerAuthTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.039 sec
Running org.geoserver.security.rememberme.RememberMeTest
31 May 15:31:55 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock5458535941569439920data&gt;
31 May 15:31:56 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock4812172518939702263data&gt;
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.756 sec
Results :
Tests run: 458, Failures: 0, Errors: 0, Skipped: 0
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-2.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-2.2-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main&gt; (directory)
[WARNING] the "build.repository" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.path" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.revision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.mixedRevisions" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedRevision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedDate" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.status" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.specialStatus" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-2.2-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-2.2-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-2.2-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/main/2.2-SNAPSHOT/main-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-2.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/main/2.2-SNAPSHOT/main-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-2.2-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/main/2.2-SNAPSHOT/main-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-2.2-SNAPSHOT-test-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/main/2.2-SNAPSHOT/main-2.2-SNAPSHOT-test-sources.jar
[INFO] Building Web Feature Service Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/target&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs&gt; (directory)
[INFO] Copying 11 resources
[INFO] Copying 10 resources
[INFO] snapshot org.geotools.jdbc:gt-jdbc-h2:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-h2:8-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 236 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/classes&gt;
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/src/main/java/org/geoserver/wfs/xml/gml3/AbstractGeometryTypeBinding.java&gt;:\[39,8\] cannot find symbol
symbol : constructor AbstractGeometryTypeBinding(<nulltype>)
location: class org.geotools.gml3.bindings.AbstractGeometryTypeBinding
[INFO] Total time: 4 minutes 34 seconds
[INFO] Finished at: Thu May 31 15:32:07 UTC 2012
[INFO] Final Memory: 54M/390M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/5158/changes&gt;
