See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/5192/>
Started by upstream project "geotools-trunk" build number 4419
Updating https://svn.codehaus.org/geoserver/trunk revision: Jun 19, 2012 10:22:48 AM depth:infinity ignoreExternals: false
ERROR: Failed to update https://svn.codehaus.org/geoserver/trunk
org.tmatesoft.svn.core.SVNException: svn: OPTIONS /geoserver/trunk failed
at org.tmatesoft.svn.core.internal.io.dav.http.HTTPConnection.request(HTTPConnection.java:294)
at org.tmatesoft.svn.core.internal.io.dav.http.HTTPConnection.request(HTTPConnection.java:279)
at org.tmatesoft.svn.core.internal.io.dav.http.HTTPConnection.request(HTTPConnection.java:267)
at org.tmatesoft.svn.core.internal.io.dav.DAVConnection.exchangeCapabilities(DAVConnection.java:516)
at org.tmatesoft.svn.core.internal.io.dav.DAVConnection.open(DAVConnection.java:98)
at org.tmatesoft.svn.core.internal.io.dav.DAVRepository.openConnection(DAVRepository.java:1002)
at org.tmatesoft.svn.core.internal.io.dav.DAVRepository.getRepositoryUUID(DAVRepository.java:147)
at org.tmatesoft.svn.core.wc.SVNBasicClient.createRepository(SVNBasicClient.java:342)
at org.tmatesoft.svn.core.wc.SVNBasicClient.createRepository(SVNBasicClient.java:330)
at org.tmatesoft.svn.core.wc.SVNUpdateClient.update(SVNUpdateClient.java:535)
at org.tmatesoft.svn.core.wc.SVNUpdateClient.doUpdate(SVNUpdateClient.java:401)
at hudson.scm.subversion.UpdateUpdater$TaskImpl.perform(UpdateUpdater.java:134)
at hudson.scm.subversion.WorkspaceUpdater$UpdateTask.delegateTo(WorkspaceUpdater.java:151)
at hudson.scm.SubversionSCM$CheckOutTask.perform(SubversionSCM.java:803)
at hudson.scm.SubversionSCM$CheckOutTask.invoke(SubversionSCM.java:786)
at hudson.scm.SubversionSCM$CheckOutTask.invoke(SubversionSCM.java:767)
at hudson.FilePath.act(FilePath.java:758)
at hudson.FilePath.act(FilePath.java:740)
at hudson.scm.SubversionSCM.checkout(SubversionSCM.java:759)
at hudson.scm.SubversionSCM.checkout(SubversionSCM.java:702)
at hudson.model.AbstractProject.checkout(AbstractProject.java:1479)
at hudson.model.AbstractBuild$AbstractRunner.checkout(AbstractBuild.java:507)
at hudson.model.AbstractBuild$AbstractRunner.run(AbstractBuild.java:424)
at hudson.model.Run.run(Run.java:1366)
at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:46)
at hudson.model.ResourceController.execute(ResourceController.java:88)
at hudson.model.Executor.run(Executor.java:145)
Caused by: org.tmatesoft.svn.core.SVNErrorMessage: svn: OPTIONS /geoserver/trunk failed
at org.tmatesoft.svn.core.SVNErrorMessage.create(SVNErrorMessage.java:200)
at org.tmatesoft.svn.core.SVNErrorMessage.create(SVNErrorMessage.java:146)
at org.tmatesoft.svn.core.SVNErrorMessage.create(SVNErrorMessage.java:89)
... 27 more
Caused by: org.tmatesoft.svn.core.SVNException: svn: OPTIONS request failed on '/geoserver/trunk'
svn: unknown host
at org.tmatesoft.svn.core.internal.wc.SVNErrorManager.error(SVNErrorManager.java:64)
at org.tmatesoft.svn.core.internal.wc.SVNErrorManager.error(SVNErrorManager.java:51)
at org.tmatesoft.svn.core.internal.io.dav.http.HTTPConnection._request(HTTPConnection.java:655)
at org.tmatesoft.svn.core.internal.io.dav.http.HTTPConnection.request(HTTPConnection.java:288)
... 26 more
Caused by: org.tmatesoft.svn.core.SVNErrorMessage: svn: OPTIONS request failed on '/geoserver/trunk'
at org.tmatesoft.svn.core.internal.io.dav.http.HTTPConnection._request(HTTPConnection.java:653)
... 27 more
Caused by: org.tmatesoft.svn.core.SVNErrorMessage: svn: unknown host
at org.tmatesoft.svn.core.internal.io.dav.http.HTTPConnection._request(HTTPConnection.java:408)
... 27 more
Caused by: java.net.UnknownHostException: svn.codehaus.org
at java.net.InetAddress.getAllByName0(InetAddress.java:1158)
at java.net.InetAddress.getAllByName(InetAddress.java:1084)
at java.net.InetAddress.getAllByName(InetAddress.java:1020)
at java.net.InetAddress.getByName(InetAddress.java:970)
at org.tmatesoft.svn.core.internal.util.SVNSocketFactory.createAddres(SVNSocketFactory.java:141)
at org.tmatesoft.svn.core.internal.util.SVNSocketFactory.createSSLSocket(SVNSocketFactory.java:72)
at org.tmatesoft.svn.core.internal.io.dav.http.HTTPConnection.connect(HTTPConnection.java:188)
at org.tmatesoft.svn.core.internal.io.dav.http.HTTPConnection._request(HTTPConnection.java:347)
... 27 more
