See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/5200/changes>
Changes:
[mdavis] Added configuration for Rendering Transformation processes BarnesSurface, Heatmap, PointStacker
[...truncated 72140 lines...]
Jun 21, 2012 7:05:41 PM org.geoserver.test.SampleDataAccessWfsTest testGetFeature
INFO: WFS GetFeature response:
<wfs:FeatureCollection numberOfFeatures="2"
timeStamp="2012-06-21T19:05:40.910Z"
xmlns:gml="http://www.opengis.net/gml"
xmlns:gsml="http://www.example.org/sample-data-access/GeoSciML-lite"
xmlns:ogc="http://www.opengis.net/ogc"
xmlns:ows="http://www.opengis.net/ows"
xmlns:wfs="http://www.opengis.net/wfs"
xmlns:xlink="http://www.w3.org/1999/xlink"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/wfs http://localhost:8080/geoserver/schemas/wfs/1.1.0/wfs.xsd http://www.example.org/sample-data-access/GeoSciML-lite http://localhost:8080/geoserver/wfs?service=WFS&version=1.1.0&request=DescribeFeatureType&typeName=gsml%3AMappedFeature">
<gml:featureMembers>
<gsml:MappedFeature gml:id="mf1">
<gml:description>GUNTHORPE FORMATION</gml:description>
<gsml:specification>
<gsml:GeologicUnit gml:id="mf1.spec">
<gml:description>Gunthorpe specification description</gml:description>
</gsml:GeologicUnit>
</gsml:specification>
<gsml:shape>
<gml:Polygon srsDimension="2">
<gml:exterior>
<gml:LinearRing srsDimension="2">
<gml:posList>-1.2 52.5 -1.2 52.6 -1.1 52.6 -1.1 52.5 -1.2 52.5</gml:posList>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</gsml:shape>
</gsml:MappedFeature>
<gsml:MappedFeature gml:id="mf2">
<gml:description>MERCIA MUDSTONE GROUP</gml:description>
<gsml:GeologicUnit gml:id="mf2.spec">
<gml:description>Mercia specification description</gml:description>
<gsml:shape>
<gml:exterior>
<gml:posList>-1.3 52.5 -1.3 52.6 -1.2 52.6 -1.2 52.5 -1.3 52.5</gml:posList>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</gsml:shape>
</gml:featureMembers>
</wfs:FeatureCollection>
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 13.21 sec
Results :
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-filter/8-SNAPSHOT/gt-xsd-filter-8-SNAPSHOT.jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/src/extension/app-schema/sample-data-access-test/target/sample-data-access-test-2.2-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/src/extension/app-schema/sample-data-access-test/target/sample-data-access-test-2.2-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/src/extension/app-schema/sample-data-access-test> (directory)
[WARNING] the "build.repository" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.path" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.revision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.mixedRevisions" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedRevision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedDate" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.status" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.specialStatus" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/src/extension/app-schema/sample-data-access-test/target/sample-data-access-test-2.2-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/src/extension/app-schema/sample-data-access-test/target/sample-data-access-test-2.2-SNAPSHOT-test-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/src/extension/app-schema/sample-data-access-test/target/sample-data-access-test-2.2-SNAPSHOT.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/sample-data-access-test/2.2-SNAPSHOT/sample-data-access-test-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/src/extension/app-schema/sample-data-access-test/target/sample-data-access-test-2.2-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/sample-data-access-test/2.2-SNAPSHOT/sample-data-access-test-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/src/extension/app-schema/sample-data-access-test/target/sample-data-access-test-2.2-SNAPSHOT-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/sample-data-access-test/2.2-SNAPSHOT/sample-data-access-test-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/src/extension/app-schema/sample-data-access-test/target/sample-data-access-test-2.2-SNAPSHOT-test-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/sample-data-access-test/2.2-SNAPSHOT/sample-data-access-test-2.2-SNAPSHOT-test-sources.jar
[INFO] Building ArcSDE DataStore Extension
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/src/extension/arcsde/target>
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/src/extension/arcsde> (directory)
[INFO] Copying 6 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/src/extension/arcsde/src/main/resources>
[INFO] snapshot org.geotools:gt-arcsde-common:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-arcsde-common:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:arcsde-plugin:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:arcsde-plugin:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-arcsde:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-arcsde:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-sde-dummy:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-sde-dummy:8-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/gt-api/8-SNAPSHOT/gt-api-8-SNAPSHOT.jar
[INFO] Compiling 2 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/src/extension/arcsde/target/classes>
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/src/extension/arcsde/src/test/resources>
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/src/extension/arcsde/target/test-classes>
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/src/extension/arcsde/target/surefire-reports>
T E S T S
Running org.geoserver.web.data.store.arcsde.ArcSDECoverageStoreEditPanelTest
21 Jun 19:05:46 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/src/extension/arcsde/./target/mock939078053700740804data>
21 Jun 19:05:52 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/src/extension/arcsde/./target/mock4777799167230836955data>
21 Jun 19:05:54 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/src/extension/arcsde/./target/mock6518048201471304718data>
21 Jun 19:05:55 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/src/extension/arcsde/./target/mock4899416189278100686data>
21 Jun 19:05:57 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/src/extension/arcsde/./target/mock582145265350552473data>
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 12.245 sec
Results :
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/src/extension/arcsde/target/arcsde-2.2-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/src/extension/arcsde/target/arcsde-2.2-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/src/extension/arcsde/target/arcsde-2.2-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/src/extension/arcsde/target/arcsde-2.2-SNAPSHOT-test-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/src/extension/arcsde/target/arcsde-2.2-SNAPSHOT.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/arcsde/2.2-SNAPSHOT/arcsde-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/src/extension/arcsde/target/arcsde-2.2-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/arcsde/2.2-SNAPSHOT/arcsde-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/src/extension/arcsde/target/arcsde-2.2-SNAPSHOT-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/arcsde/2.2-SNAPSHOT/arcsde-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/src/extension/arcsde/target/arcsde-2.2-SNAPSHOT-test-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/arcsde/2.2-SNAPSHOT/arcsde-2.2-SNAPSHOT-test-sources.jar
[INFO] Building GeoSearch Index Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/src/extension/geosearch/target>
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/src/extension/geosearch> (directory)
[INFO] Copying 3 resources
[INFO] Copying 4 resources
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Error transferring file: repo.opengeo.org
org.geotools.xsd:gt-xsd-filter:jar:8-SNAPSHOT
from the specified remote repositories:
geosolutions (http://maven.geo-solutions.it/),
central (http://repo1.maven.org/maven2),
osgeo (http://download.osgeo.org/webdav/geotools/),
maven2-repository.dev.java.net (http://download.java.net/maven/2),
maven-restlet (http://maven.restlet.org),
opengeo (http://repo.opengeo.org/)
Path to dependency:
1) org.geoserver.extension:geosearch:jar:2.2-SNAPSHOT
2) org.geoserver:main:jar:2.2-SNAPSHOT
3) org.geotools.xsd:gt-xsd-sld:jar:8-SNAPSHOT
4) org.geotools.xsd:gt-xsd-filter:jar:8-SNAPSHOT
[INFO] Total time: 29 minutes 5 seconds
[INFO] Finished at: Thu Jun 21 19:06:08 UTC 2012
[INFO] Final Memory: 70M/424M
Failed to send e-mail to mdavis because no e-mail address is known, and no default e-mail domain is configured
