See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/1114/>
[...truncated 12519 lines...]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/src/community/inspire> (directory)
[WARNING] the "build.repository" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.path" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.revision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.mixedRevisions" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedRevision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedDate" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.status" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.specialStatus" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/src/community/inspire/target/inspire-2.2-SNAPSHOT-sources.jar>
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/src/community/inspire/target/inspire-2.2-SNAPSHOT-test-sources.jar>
[INFO] [dependency:copy-dependencies {execution: copy-dependencies}]
[INFO] Copying gt-api-8-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/src/community/inspire/target/dependency/gt-api-8-SNAPSHOT.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/src/community/inspire/target/inspire-2.2-SNAPSHOT.jar> to /usr/share/jetty/.m2/repository/org/geoserver/community/inspire/2.2-SNAPSHOT/inspire-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/src/community/inspire/target/inspire-2.2-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/community/inspire/2.2-SNAPSHOT/inspire-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/src/community/inspire/target/inspire-2.2-SNAPSHOT-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/community/inspire/2.2-SNAPSHOT/inspire-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/src/community/inspire/target/inspire-2.2-SNAPSHOT-test-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/community/inspire/2.2-SNAPSHOT/inspire-2.2-SNAPSHOT-test-sources.jar
[INFO] Building Simple Feature Service
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/src/community/sfs> (directory)
[INFO] Copying 0 resource
[INFO] Copying 1 resource
[INFO] Compiling 11 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/src/community/sfs/target/classes>
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/src/community/sfs/src/test/resources>
[INFO] Compiling 3 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/src/community/sfs/target/test-classes>
[INFO] Tests are skipped.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/src/community/sfs/target/simpleFeatureService-2.2-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/src/community/sfs/target/simpleFeatureService-2.2-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/src/community/sfs/target/simpleFeatureService-2.2-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/src/community/sfs/target/simpleFeatureService-2.2-SNAPSHOT-test-sources.jar>
[INFO] Copying gt-api-8-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/src/community/sfs/target/dependency/gt-api-8-SNAPSHOT.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/src/community/sfs/target/simpleFeatureService-2.2-SNAPSHOT.jar> to /usr/share/jetty/.m2/repository/org/geoserver/community/simpleFeatureService/2.2-SNAPSHOT/simpleFeatureService-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/src/community/sfs/target/simpleFeatureService-2.2-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/community/simpleFeatureService/2.2-SNAPSHOT/simpleFeatureService-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/src/community/sfs/target/simpleFeatureService-2.2-SNAPSHOT-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/community/simpleFeatureService/2.2-SNAPSHOT/simpleFeatureService-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/src/community/sfs/target/simpleFeatureService-2.2-SNAPSHOT-test-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/community/simpleFeatureService/2.2-SNAPSHOT/simpleFeatureService-2.2-SNAPSHOT-test-sources.jar
[INFO] Building Aggregating Data Store
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/src/community/feature-aggregate> (directory)
[INFO] Copying 3 resources
[INFO] snapshot org.geotools.unsupported:gt-feature-aggregate:8-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 8 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/src/community/feature-aggregate/target/classes>
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/src/community/feature-aggregate/src/test/java>
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/src/community/feature-aggregate/src/test/resources>
[INFO] No sources to compile
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/src/community/feature-aggregate/target/feature-aggregate-2.2-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/src/community/feature-aggregate/target/feature-aggregate-2.2-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/src/community/feature-aggregate/target/feature-aggregate-2.2-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/src/community/feature-aggregate/target/feature-aggregate-2.2-SNAPSHOT-test-sources.jar>
[INFO] Copying gt-api-8-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/src/community/feature-aggregate/target/dependency/gt-api-8-SNAPSHOT.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/src/community/feature-aggregate/target/feature-aggregate-2.2-SNAPSHOT.jar> to /usr/share/jetty/.m2/repository/org/geoserver/community/feature-aggregate/2.2-SNAPSHOT/feature-aggregate-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/src/community/feature-aggregate/target/feature-aggregate-2.2-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/community/feature-aggregate/2.2-SNAPSHOT/feature-aggregate-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/src/community/feature-aggregate/target/feature-aggregate-2.2-SNAPSHOT-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/community/feature-aggregate/2.2-SNAPSHOT/feature-aggregate-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/src/community/feature-aggregate/target/feature-aggregate-2.2-SNAPSHOT-test-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/community/feature-aggregate/2.2-SNAPSHOT/feature-aggregate-2.2-SNAPSHOT-test-sources.jar
[INFO] Building GeoServer Community Release Module
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/src/community/release> (directory)
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/src/community/release/src/main/java>
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/src/community/release/src/main/resources>
[INFO] snapshot org.geoserver.community:spatialite:2.2-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver.community:spatialite:2.2-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geoserver/community/spatialite/2.2-SNAPSHOT/spatialite-2.2-SNAPSHOT.pom
[INFO] Unable to find resource 'org.geoserver.community:spatialite:pom:2.2-SNAPSHOT' in repository opengeo (http://repo.opengeo.org/)
Downloading: http://download.osgeo.org/webdav/geotools//org/geoserver/community/spatialite/2.2-SNAPSHOT/spatialite-2.2-SNAPSHOT.pom
[INFO] Unable to find resource 'org.geoserver.community:spatialite:pom:2.2-SNAPSHOT' in repository osgeo (http://download.osgeo.org/webdav/geotools/)
[INFO] snapshot org.geoserver.community:teradata:2.2-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver.community:teradata:2.2-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geoserver/community/teradata/2.2-SNAPSHOT/teradata-2.2-SNAPSHOT.pom
[INFO] Unable to find resource 'org.geoserver.community:teradata:pom:2.2-SNAPSHOT' in repository opengeo (http://repo.opengeo.org/)
Downloading: http://download.osgeo.org/webdav/geotools//org/geoserver/community/teradata/2.2-SNAPSHOT/teradata-2.2-SNAPSHOT.pom
[INFO] Unable to find resource 'org.geoserver.community:teradata:pom:2.2-SNAPSHOT' in repository osgeo (http://download.osgeo.org/webdav/geotools/)
Downloading: http://repo.opengeo.org//org/geoserver/community/spatialite/2.2-SNAPSHOT/spatialite-2.2-SNAPSHOT.jar
[INFO] Unable to find resource 'org.geoserver.community:spatialite:jar:2.2-SNAPSHOT' in repository opengeo (http://repo.opengeo.org/)
Downloading: http://download.osgeo.org/webdav/geotools//org/geoserver/community/spatialite/2.2-SNAPSHOT/spatialite-2.2-SNAPSHOT.jar
[INFO] Unable to find resource 'org.geoserver.community:spatialite:jar:2.2-SNAPSHOT' in repository osgeo (http://download.osgeo.org/webdav/geotools/)
Downloading: http://repo.opengeo.org//org/geoserver/community/teradata/2.2-SNAPSHOT/teradata-2.2-SNAPSHOT.jar
[INFO] Unable to find resource 'org.geoserver.community:teradata:jar:2.2-SNAPSHOT' in repository opengeo (http://repo.opengeo.org/)
Downloading: http://download.osgeo.org/webdav/geotools//org/geoserver/community/teradata/2.2-SNAPSHOT/teradata-2.2-SNAPSHOT.jar
[INFO] Unable to find resource 'org.geoserver.community:teradata:jar:2.2-SNAPSHOT' in repository osgeo (http://download.osgeo.org/webdav/geotools/)
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Missing:
1) org.geoserver.community:spatialite:jar:2.2-SNAPSHOT
Try downloading the file manually from the project website.
Then, install it using the command:
mvn install:install-file -DgroupId=org.geoserver.community -DartifactId=spatialite -Dversion=2.2-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file
Alternatively, if you host your own repository you can deploy the file there:
mvn deploy:deploy-file -DgroupId=org.geoserver.community -DartifactId=spatialite -Dversion=2.2-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
Path to dependency:
1) org.geoserver.community:release:jar:2.2-SNAPSHOT
2) org.geoserver.community:spatialite:jar:2.2-SNAPSHOT
2) org.geoserver.community:teradata:jar:2.2-SNAPSHOT
mvn install:install-file -DgroupId=org.geoserver.community -DartifactId=teradata -Dversion=2.2-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file
mvn deploy:deploy-file -DgroupId=org.geoserver.community -DartifactId=teradata -Dversion=2.2-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
Path to dependency:
2 required artifacts are missing.
for artifact:
from the specified remote repositories:
central (http://repo1.maven.org/maven2),
osgeo (http://download.osgeo.org/webdav/geotools/),
maven-restlet (http://maven.restlet.org),
[INFO] Total time: 4 minutes 2 seconds
[INFO] Finished at: Sat Jun 09 03:34:59 UTC 2012
[INFO] Final Memory: 87M/435M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/trunk/geoserver-trunk-2012-06-09-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
