See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/831/>
[...truncated 12404 lines...]
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/mock6235402173548468972data>
21 Apr 04:10:34 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/mock6546550242638524979data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/mock5651403420628266172data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/mock2152541478374416141data>
21 Apr 04:10:35 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/mock7340427203285080747data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/mock8691113058145885976data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/mock2392049365554551421data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/mock4326687674601091906data>
21 Apr 04:10:36 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/mock1620262021427370587data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/mock1227145154053158480data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/mock896798204304828401data>
21 Apr 04:10:37 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/mock1687684373650133199data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/mock914615971768465719data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/mock5939942214408357847data>
21 Apr 04:10:38 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/mock4661118471644124886data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/mock129230336365711443data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/mock2227324651891998465data>
21 Apr 04:10:39 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/mock1889487235772841103data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/mock3723062091148242827data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/mock4127905776475605305data>
21 Apr 04:10:40 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/mock6013085674395107073data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/mock7305778396269288777data>
21 Apr 04:10:41 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/mock6119950608589603186data>
Tests run: 45, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 14.72 sec
Running org.geoserver.template.GeoServerTemplateLoader2Test
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/mock3387458947077798601data>
21 Apr 04:10:42 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/mock97378642090241222data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/mock842166737110565999data>
21 Apr 04:10:43 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/mock5292739563133256024data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/mock5374292922261330066data>
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.322 sec
Running org.geoserver.ows.URLManglersTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/mock4498011967349253024data>
21 Apr 04:10:44 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/mock2993276897603881656data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/mock1572766449228786657data>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.961 sec
Running org.geoserver.security.GeoServerRoleFilterTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/mock5863645958281156318data>
21 Apr 04:10:45 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/mock8658883330032850631data>
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.303 sec
Running org.geoserver.security.validation.PasswordValidatorTest
21 Apr 04:10:46 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/live7211084871749177409data>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.288 sec
Running org.geoserver.security.impl.DataAccessRuleDAOTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Running org.geoserver.security.impl.GeoServerUserDaoTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Running org.geoserver.security.xml.XMLRoleServiceTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/live1898790449821043295data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/live6569989905738138956data>
21 Apr 04:10:47 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/live420986853159912252data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/live8159890590071056253data>
21 Apr 04:10:48 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/live7388947762689303925data>
21 Apr 04:10:49 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/live6301827223845576280data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/live2195230829851692412data>
21 Apr 04:10:50 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/live8356711709142258613data>
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.246 sec
Running org.geoserver.data.util.CoverageUtilsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.001 sec
Running org.geoserver.security.decorators.SecuredFeatureSourceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.01 sec
Running org.geoserver.catalog.impl.CatalogBuilderTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/mock3995729479761372966data>
Apr 21, 2012 4:10:51 AM org.geotools.referencing.operation.projection.TransverseMercator.Inverse transform
WARNING: Possible use of "Transverse_Mercator (Inverse transform)" projection outside its valid area.
Latitude 2181°05.9'N is out of range (±90°).
Apr 21, 2012 4:10:51 AM org.geoserver.test.RemoteOWSTestSupport isRemoteWMSStatesAvailable
WARNING: Skipping remote OWS test because they were not enabled via -DremoteOwsTests=true
Apr 21, 2012 4:10:51 AM org.geoserver.catalog.impl.CatalogBuilderTest testWMS
WARNING: Remote OWS tests disabled, skipping catalog builder wms tests
Apr 21, 2012 4:10:55 AM org.geoserver.catalog.ResourcePool$DataStoreCache dispose
INFO: Disposing datastore 'cite'
INFO: Disposing datastore 'cgf'
INFO: Disposing datastore 'sf'
INFO: Disposing datastore 'cdf'
Apr 21, 2012 4:10:55 AM org.geoserver.catalog.ResourcePool$FeatureTypeCache dispose
INFO: Disposing feature type 'Points'
Apr 21, 2012 4:10:55 AM org.geoserver.catalog.ResourcePool$CoverageHintReaderCache dispose
INFO: Disposing coverage store 'DEM'
INFO: Disposing coverage store 'largeMosaic'
{AllowMultithreading=false, Filter=, MaxAllowedTiles=-1, InputTransparentColor=, OutputTransparentColor=, SUGGESTED_TILE_SIZE=512,512, USE_JAI_IMAGEREAD=true, BackgroundValues=}
INFO: Disposing coverage store 'smallMosaic'
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.129 sec
Running org.geoserver.security.impl.DefaultDataAccessManagerAuthTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.039 sec
Running org.geoserver.security.rememberme.RememberMeTest
21 Apr 04:10:55 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/mock6577853340319353950data>
21 Apr 04:10:56 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/./target/mock7172687474939081721data>
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.104 sec
Results :
Failed tests:
testAuthenticationEntry(org.geoserver.security.auth.LRUAuthenticationCacheTest)
Tests run: 453, Failures: 1, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/target/surefire-reports> for the individual test results.
[INFO] Total time: 3 minutes 36 seconds
[INFO] Finished at: Sat Apr 21 04:10:57 UTC 2012
[INFO] Final Memory: 54M/409M
