[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ geotools ---
WAGON_VERSION: 1.0-beta-2
Downloading: dav:[http://repo.opengeo.org/org/geotools/geotools/9-SNAPSHOT/maven-metadata.xml](http://repo.opengeo.org/org/geotools/geotools/9-SNAPSHOT/maven-metadata.xml)
[WARNING] Could not transfer metadata org.geotools:geotools:9-SNAPSHOT/maven-metadata.xml from/to opengeo (dav:[http://repo.opengeo.org](http://repo.opengeo.org/)): Failed to transfer file: [http://repo.opengeo.org/org/geotools/geotools/9-SNAPSHOT/maven-metadata.xml.](http://repo.opengeo.org/org/geotools/geotools/9-SNAPSHOT/maven-metadata.xml.) Return code is: 0
[INFO] Reactor Summary:
[INFO]
[INFO] Geotools .......................................... FAILURE [44.442s]
[INFO] Build tools for Geotools 2 .....................… SKIPPED
The geotools docs job is failing with:
ssh: Could not resolve hostname geotools.org: Temporary failure in name resolution
lost connection
So I assume hudson is having a very bad day.
Jody
