[Geoserver-devel] Hudson failing with "too many open files"
It seems that Hudson is in the middle of a “too many open files” crisis, e.g., from a CITE tests build:
Caused by: java.io.IOException: java.io.IOException: error=24, Too many open files
I guess it needs a kick? Maybe with a check of which files are being left open, to see if we can do anything about it (seems to happen from time to time)
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
THanks for the heads up Andrea. Kicked the server and looking into increasing the open file limit since from what i can tell from the open files it held by the hudson user nothing jumps out.
On Mon, Aug 5, 2013 at 2:07 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
Get your SQL database under version control now!
Version control is standard for application code, but databases havent
caught up. So what steps can you take to put your SQL databases under
version control? Why should you start doing it? Read more to find out.
http://pubads.g.doubleclick.net/gampad/clk?id=49501711&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
On Mon, Aug 5, 2013 at 4:50 PM, Justin Deoliveira <jdeolive@anonymised.com>wrote:
All right, thanks for fixing it!
information.
Ing. Andrea Aime
@geowolf
Technical Lead
