[Geoserver-devel] IAU module: it's mostly data, what to do?
the IAU authority support module (for planetary CRS) in GeoTools is basically just packaging new data, and leveraging existing property CRS support, already used by gt-epsg-wtk and gt-espg-extension.
Now it’s time to package it for GeoServer. It will not have anything special for GeoServer, as it’s just an extra database, it’s a simple drop in: the zip file will only contain gt-iau-wkt.
So the question is, where do I package it? Two points of view:
  • The database is new, thus community
  • The module is just data, the code is not new: extension
    What say you?
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
I would drop into core on main branch; it is additive functionality that will not disrupt stability of existing installations.
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
I thank you for the vote of confidence but… maybe not? Having IAU built-in means that every GeoServer
installation will suddenly sport over 2000 new codes in the capabilities documents, and CRS lookups
(aka “give me the identifier of this weird CRS without an id”) will generally be slowed down by the
sequential scan and comparison performed by property based CRS authorities.
Space is great, but should not affect those that decided to only look down at Earth (who can blame them,
there’s lots to see!).
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
I think it can go in as an extension, it’s really just more data.
Ian
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Having it as an extension sounds reasonable to me as well.
Torben
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Thank you all, I’ve made the PR:
https://github.com/geoserver/geoserver/pull/7028
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
