[Geoserver-devel] Identical table names in different schemas
I just observed some odd behavior if there are two tables with the same name in two different schemas and the schema is left blank when adding a data store (I tested with PostGIS).
In such a scenario, only one table is listed when you attempt to publish a new layer. However, in the “Edit Layer” form, the columns of both tables are listed in section “Feature Type Details”.
This seems to happen because JDBCFeatureSource#getColumnsMetadata calls DatabaseMetaData#getColumns with null as schema and hence the JDBC driver returns the columns of both tables.
Is this behavior intended, a known limitation or would you consider that a bug? Or should one never leave the schema field empty when connecting to a database?
Stefan
