[Geoserver-devel] If you are having problems with surefire builds see here
yesterday my openjdk updated and today I found surefire was not working anymore. In case you end up
in the same boat, there is some discussion here
https://stackoverflow.com/questions/53010200/maven-surefire-could-not-find-forkedbooter-class/53016532#53016532
I’ve tried to use this
<useSystemClassLoader>false</useSystemClassLoader>
but then security tests started failing…
For the time being I’ve reverted to an older Oracle JDK 8, that seems to work fine.
Another option seems to be to add this new “jdk.net.URLClassPath.disableClassPathURLCheck” system property to
surefire jvm args, but I haven’t tried it yet
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
