[Geoserver-devel] IIORegistry issues on tomcat
Recently i ran into the dreaded well known issue with imageio plugins under tomcat, explained in detail on the geosolutions blog. [1]
The jar moving solution did not seem to work for me, but disabling the JreMemoryLeakPreventionListener (or more setting the appContextProtection to false) does work. However, while looking around for others having the same issue I also came across the last post on this thread:
http://tomcat.10.n6.nabble.com/Problems-with-ImageIO-td2073212.html
That mentions doing an ImageIO.scanForPlugins() on app startup also fixes the problem. So i tried it out in GeoServerInitStartupListener and indeed it did work for me. So question is, should we add it permanently? Any foreseen downfall? I didn’t exactly test it strenuously.
Thanks.
-Justin
[1] http://geo-solutions.blogspot.com/2010/05/fix-geotools-and-geoserver-not-able-to.html
Justin Deoliveira
OpenGeo - http://opengeo.org
On Wed, Feb 29, 2012 at 12:18 AM, Justin Deoliveira
<jdeolive@anonymised.com> wrote:
Any foreseen downfall? I didn't exactly test it strenuously.
Hmm... that sounds like a good idea, personally I'm not aware of downsides.
I'm not sure if that is the full story though, we should do something
like that for JAI as well... hmmm... probably not, as we setup our own
replacement JAI registry after the server is initialized anyways
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
mob: +39 339 8844549
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
Cool, thanks. So if there are no objections to doing so within a day or so i will add this in. Attached is the patch.
On Wed, Feb 29, 2012 at 4:05 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hmm… that sounds like a good idea, personally I’m not aware of downsides.
I’m not sure if that is the full story though, we should do something
like that for JAI as well… hmmm… probably not, as we setup our own
Ing. Andrea Aime
Tech lead
Justin Deoliveira
(attachments)
GeoserverInitStartupListener.java.patch (1.42 KB)
