[Geoserver-devel] Image Maps?
Are there any capabilities to generate an HTML Image Map layer to provide
mouse-over capabilities?
Dan
You can have the mouse do a getFeature request (with a bounding box parameter around the mouse by a few pixels) when the mouse stops, then see if anything is underneath the mouse. You can then proceed from there.
Check out the "WMS Example" demo that comes with GeoServer, it does that.
Brent Owens
(The Open Planning Project)
Dan
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-devel mailing list
