[Geoserver-devel] Image mosaic black areas (transparency?) problem in 1.7.4
Hi devs (Simone :slight_smile:
these days i switched from 1.7.2 to 1.7.4 because of the REST api, and
its working just fine.
But after I finished with REST, I noticed strange behaviour in mosiac coverage.
It is similar to this issue http://jira.codehaus.org/browse/GEOT-1642
(and its related and dependent ones)
My tiffs are converted to tiffs with internal jpeg compression, using
gdal_translate. Nodata areas are in white colour.
When I put tiled layer black areas randomly start to appear where
there are is no raster data.
Now I also tried nightly build and it is the same situation as 1.7.4.
I repeat, in 1.7.2 it works perfect.
I attached screenshots of the problem.
One notice, in 1.7.4 when edit coverage I had to put
OutputTransparentColor: #000000, if I put OutputTransparentColor:
#FFFFFF as in 1.7.2 areas without rasters are in black color (images
also attached) Why is that, im curious?
Anyone had similar problems?
Thank you, best regards
Ivan Grcic
(attachments)
mosaic174_blackAreas.zip (374 KB)
Ciao Ivan,
is there any chance that you can provide some data so that I can try
to reproduce this behavior locally?
Simone.
Ing. Simone Giannecchini
Owner - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
http://simboss.blogspot.com/
http://www.linkedin.com/in/simonegiannecchini
Ivan Grcic
Crystal Reports - New Free Runtime and 30 Day Trial
Check out the new simplified licensing option that enables unlimited
royalty-free distribution of the report engine for externally facing
server and web deployment.
http://p.sf.net/sfu/businessobjects
Geoserver-devel mailing list
Ciao Ivan,
you have actually discovered a featuer instead of a bug :slight_smile: (reminder
to myself, write documentation for the mosaic plugin).
You have hole between the various elements. The new mosaic will have a
consistent behavior with holes (while the hole hadn't): it will always
use the background values to fill the holes.
This depends on the data type, but for byte data is 0 (your case).
There is an option to set this value explcitly, in your case
I would put 255, so that the filling will be result in white color
(yeah, the vale is replicated over the varios bands of the data). You
do not need to set any output color.
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
On Tue, Jun 9, 2009 at 8:10 PM, Simone
Giannecchini<simone.giannecchini@anonymised.com> wrote:
Ciao Ivan,
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Ivan Grcic
On Thu, Jun 11, 2009 at 8:58 PM, Simone
Ciao Ivan,
Ah instead of 255 i was trying with hex #FFFFFF!
Its working perfect now, grazie mile Simone!
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Ciao Ivan,
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Ivan Grcic
Ivan Grcic
Ciao Ivan,
good to know that things work out.
I actually found a minor bug related to GEOT-1642 while testing your
data, which I am going to fix right now.
However, as you noticed the solution for your problem is the one I
gave you already.
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
On Thu, Jun 11, 2009 at 10:37 PM, Ivan Grcic<ivan.grcic@anonymised.com> wrote:
Ciao Ivan,
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Ciao Ivan,
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Ivan Grcic
Ivan Grcic
Hi Simone,
some problems again :frowning: Although background color works fine now for single layer, when you combine mosaic layers in one WMS layers, the background color (areas where data doesnt exist) covers the other layer data. In 1.7.2 works normal, in 1.7.4 problem occurs.
I attached screenshots (i changed the white bg color for gray, sou you can see where the extent of two mosaics are)
Any suggestions?
Thank you
On Thu, Jun 11, 2009 at 8:58 PM, Simone Giannecchini <simone.giannecchini@anonymised.com> wrote:
Ciao Ivan,
consistent behavior with holes (while the hole hadn’t): it will always
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Ciao Ivan,
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Ivan Grcic
Ivan Grcic
(attachments)
See my comment on http://jira.codehaus.org/browse/GEOS-3197.
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
On Tue, Jun 23, 2009 at 4:11 PM, Ivan Grcic<ivan.grcic@anonymised.com> wrote:
Hi Simone,
Any suggestions?
Thank you
Ciao Ivan,
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
> Ciao Ivan,
> Simone.
> GeoSolutions S.A.S.
> Via Carignoni 51
> 55041 Camaiore (LU)
> Italy
> fax: +39 0584983027
>> coverage.
>> Ivan Grcic
>> _______________________________________________
>> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
Ivan Grcic
Are you an open source citizen? Join us for the Open Source Bridge
conference!
Portland, OR, June 17-19. Two days of sessions, one day of unconference:
$250.
Need another reason to go? 24-hour hacker lounge. Register today!
http://ad.doubleclick.net/clk;215844324;13503038;v?http://opensourcebridge.org
