We are using the image mosaic plugin in geoserver 2.5.4.
We created a store containing ECW images with 4 bands.
This store is published with differents styles :
- one containing a channel selection bands 4, 3 and 2
- one containing a channel selection bands 1, 2 and 3
When we preview this layer and select different style, all is fine.
But when we add transparency using footprints.shp, we have some errors, but only when geoserver display a tile that intersects the mask in footprints.shp.
Is there a workaround or a fix ?
Bests regards
MY SLD
*<?xml version="1.0" encoding="ISO-8859-1"?>*
*<*``*StyledLayerDescriptor* ``*version*``*=*``*"1.0.0"* ``*xmlns*``*=*``*"*
*http://www.opengis.net/sld*
*"* ``*xmlns:ogc*``*=*``*"*
*http://www.opengis.net/ogc*
*xmlns:xlink*``*=*``*"*`[`*http://www.w3.org/1999/xlink*`](http://www.w3.org/1999/xlink)`*"* ``*xmlns:xsi*``*=*``*"*`[`*http://www.w3.org/2001/XMLSchema-instance*`](http://www.w3.org/2001/XMLSchema-instance)`*"*`
xsi:schemaLocation*=*
*http://www.opengis.net/sld*`](http://www.opengis.net/sld)
*http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd*
*<*``*NamedLayer*``*>*
*<*``*Name*``*>bathy example</*``*Name*``*>*
*<*``*UserStyle*``*>*
*<*``*Name*``*>RGB image 3 channels</*``*Name*``*>*
*<*``*Title*``*>RGB image</*``*Title*``*>*
*<*``*FeatureTypeStyle*``*>*
*<*``*Rule*``*>*
*<*``*RasterSymbolizer*``*>*
*<*``*ChannelSelection*``*>*
*<*``*RedChannel*``*>*
*<*``*SourceChannelName*``*>1</*``*SourceChannelName*``*>*
*</*``*RedChannel*``*>*
*<*``*GreenChannel*``*>*
*<*``*SourceChannelName*``*>2</*``*SourceChannelName*``*>*
*</*``*GreenChannel*``*>*
*<*``*BlueChannel*``*>*
*<*``*SourceChannelName*``*>3</*``*SourceChannelName*``*>*
*</*``*BlueChannel*``*>*
*</*``*ChannelSelection*``*>*
*</*``*RasterSymbolizer*``*>*
*</*``*Rule*``*>*
*</*``*FeatureTypeStyle*``*>*
*</*``*UserStyle*``*>*
*</*``*NamedLayer*``*>*
*</*``*StyledLayerDescriptor*``*>*
Geoserver logs
2015-11-04 13:42:53,665 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Error rendering coverage on the fast path
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:332)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:252)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:124)
at org.geoserver.wms.GetMap.executeInternal(GetMap.java:510)
at org.geoserver.wms.GetMap.run(GetMap.java:254)
at org.geoserver.wms.GetMap.run(GetMap.java:125)
at org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:329)
at sun.reflect.GeneratedMethodAccessor187.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Method.java:622)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:319)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
at org.geoserver.kml.WebMapServiceKmlInterceptor.invoke(WebMapServiceKmlInterceptor.java:34)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:62)
at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:36)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:80)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:55)
at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:33)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
at com.sun.proxy.$Proxy62.getMap(Unknown Source)
at sun.reflect.GeneratedMethodAccessor186.invoke(Unknown Source)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:791)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:273)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:723)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:83)
at org.geoserver.security.filter.GeoServerPreAuthenticationFilter.doFilter(GeoServerPreAuthenticationFilter.java:75)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:76)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:293)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:861)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:606)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
at java.lang.Thread.run(Thread.java:701)
Caused by: org.geoserver.platform.ServiceException: org.geotools.coverage.processing.CoverageProcessingException: org.geotools.coverage.processing.CoverageProcessingException: org.geotools.coverage.processing.CoverageProcessingException: org.geotools.coverage.processing.CoverageProcessingException: org.geotools.coverage.processing.CoverageProcessingException: org.geotools.coverage.processing.CoverageProcessingException: org.geotools.coverage.processing.CoverageProcessingException: java.lang.IllegalArgumentException: Band number 4 is not valid.
at org.geoserver.wms.map.RenderedImageMapOutputFormat.directRasterRender(RenderedImageMapOutputFormat.java:906)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:330)
… 110 more
Caused by: org.geotools.coverage.processing.CoverageProcessingException: org.geotools.coverage.processing.CoverageProcessingException: org.geotools.coverage.processing.CoverageProcessingException: org.geotools.coverage.processing.CoverageProcessingException: org.geotools.coverage.processing.CoverageProcessingException: org.geotools.coverage.processing.CoverageProcessingException: org.geotools.coverage.processing.CoverageProcessingException: java.lang.IllegalArgumentException: Band number 4 is not valid.
at org.geotools.renderer.lite.gridcoverage2d.BaseCoverageProcessingNode.getOutput(BaseCoverageProcessingNode.java:342)
at org.geotools.renderer.lite.gridcoverage2d.BaseCoverageProcessingNode.getOutput(BaseCoverageProcessingNode.java:46)
at org.geotools.renderer.lite.gridcoverage2d.StyleVisitorCoverageProcessingNodeAdapter.getOutput(StyleVisitorCoverageProcessingNodeAdapter.java:176)
at org.geotools.renderer.lite.gridcoverage2d.GridCoverageRenderer.prepareFinalImage(GridCoverageRenderer.java:686)
at org.geotools.renderer.lite.gridcoverage2d.GridCoverageRenderer.renderImage(GridCoverageRenderer.java:784)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.directRasterRender(RenderedImageMapOutputFormat.java:895)
… 111 more
Caused by: org.geotools.coverage.processing.CoverageProcessingException: org.geotools.coverage.processing.CoverageProcessingException: org.geotools.coverage.processing.CoverageProcessingException: org.geotools.coverage.processing.CoverageProcessingException: org.geotools.coverage.processing.CoverageProcessingException: org.geotools.coverage.processing.CoverageProcessingException: java.lang.IllegalArgumentException: Band number 4 is not valid.
at org.geotools.renderer.lite.gridcoverage2d.SubchainStyleVisitorCoverageProcessingAdapter.execute(SubchainStyleVisitorCoverageProcessingAdapter.java:116)
at org.geotools.renderer.lite.gridcoverage2d.RasterSymbolizerHelper.execute(RasterSymbolizerHelper.java:68)
at org.geotools.renderer.lite.gridcoverage2d.RasterSymbolizerHelper.execute(RasterSymbolizerHelper.java:50)
at org.geotools.renderer.lite.gridcoverage2d.StyleVisitorCoverageProcessingNodeAdapter$1.execute(StyleVisitorCoverageProcessingNodeAdapter.java:136)
at org.geotools.renderer.lite.gridcoverage2d.BaseCoverageProcessingNode.checkExecuted(BaseCoverageProcessingNode.java:238)
at org.geotools.renderer.lite.gridcoverage2d.BaseCoverageProcessingNode.getOutput(BaseCoverageProcessingNode.java:340)
… 116 more
Caused by: org.geotools.coverage.processing.CoverageProcessingException: org.geotools.coverage.processing.CoverageProcessingException: org.geotools.coverage.processing.CoverageProcessingException: org.geotools.coverage.processing.CoverageProcessingException: org.geotools.coverage.processing.CoverageProcessingException: java.lang.IllegalArgumentException: Band number 4 is not valid.
at org.geotools.renderer.lite.gridcoverage2d.ContrastEnhancementNode.execute(ContrastEnhancementNode.java:224)
at org.geotools.renderer.lite.gridcoverage2d.ContrastEnhancementNode.execute(ContrastEnhancementNode.java:75)
… 124 more
Caused by: org.geotools.coverage.processing.CoverageProcessingException: org.geotools.coverage.processing.CoverageProcessingException: org.geotools.coverage.processing.CoverageProcessingException: org.geotools.coverage.processing.CoverageProcessingException: java.lang.IllegalArgumentException: Band number 4 is not valid.
at org.geotools.renderer.lite.gridcoverage2d.ColorMapNode.execute(ColorMapNode.java:277)
at org.geotools.renderer.lite.gridcoverage2d.ColorMapNode.execute(ColorMapNode.java:55)
… 131 more
Caused by: org.geotools.coverage.processing.CoverageProcessingException: org.geotools.coverage.processing.CoverageProcessingException: org.geotools.coverage.processing.CoverageProcessingException: java.lang.IllegalArgumentException: Band number 4 is not valid.
… 138 more
Caused by: org.geotools.coverage.processing.CoverageProcessingException: org.geotools.coverage.processing.CoverageProcessingException: java.lang.IllegalArgumentException: Band number 4 is not valid.
at org.geotools.renderer.lite.gridcoverage2d.BandMergeNode.execute(BandMergeNode.java:160)
… 143 more
Caused by: org.geotools.coverage.processing.CoverageProcessingException: java.lang.IllegalArgumentException: Band number 4 is not valid.
… 148 more
Caused by: java.lang.IllegalArgumentException: Band number 4 is not valid.
at org.geotools.renderer.lite.gridcoverage2d.BandSelectionNode.execute(BandSelectionNode.java:127)
at org.geotools.renderer.lite.gridcoverage2d.BandSelectionNode.execute(BandSelectionNode.java:48)
… 155 more
2015-11-04 13:42:53,716 ERROR [geoserver.ows] -
… 110 more
… 111 more
… 116 more
… 124 more
… 131 more
… 138 more
… 143 more
… 148 more
Rémi EVE
Administrateur
Plate-Forme Régionale SIG
Région Guyane
66, Avenue du Général De Gaulle
97 300 CAYENNE
Tél : 05 94 28 96 08
Fax : 05 94 28 96 06
E-mail : remi.eve@anonymised.com
Hi Remi,
I’m not aware of any workaround for this.
You should test with a supported version of GeoServer, that is, either a 2.7.x or 2.8.x,
and if the issue is still there, open a bug report at https://osgeo-org.atlassian.net/projects/GEOS/issues/GEOS-6894?filter=allopenissues
On Wed, Nov 4, 2015 at 3:09 PM, Rémi EVE <Remi.EVE@anonymised.com> wrote:
Bests regards
MY SLD
*<*``*Rule*``*>*
*</*``*Rule*``*>*
Geoserver logs
… 110 more
… 111 more
… 116 more
… 124 more
… 131 more
… 138 more
… 143 more
… 148 more
… 155 more
… 110 more
… 111 more
… 116 more
… 124 more
… 131 more
… 138 more
… 143 more
… 148 more
Rémi EVE
Administrateur
Région Guyane
97 300 CAYENNE
E-mail : remi.eve@…4308…
Geoserver-devel mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
