lately I've been working, under OpenGeo request, to improve
the situation vs image pyramids, in particular, making it
easier to configure a file based one.
Before the changes you'd had to manually build a mosaic for
each level and then also build manually a property file in the
root. That is a long and tedious process with many steps
in which you can make a mistake.
After the change you can basically point the coverage store
to a "pyramid shaped" structure (aka, a directory with a set
of sub directories, each containing a mosaic of the same area
at a different resolution level) and it will do all of the
above for you. If the pyramid has been built with gdal_retile
it will also take care of reformatting it to the structure
the coverage store actually expects.
The tutorial is now here and points to data you can use
to actually replicate it step by step (assuming you're running
from a recent nightly build that is)
http://gridlock.openplans.org/geoserver/trunk/doc/en/user/tutorials/index.html
The only thing you won't be able to replicate is the layer
configuration, where you'll get the wrong layer name due to
http://jira.codehaus.org/browse/GEOT-2953 (which I hope will
be fixed soon, already provided a patch).
Is anyone interested to give the tutorial a spin, a review?
Is there anything missing or that could be done better?
Andrea Aime
OpenGeo - http://opengeo.org
- jira fxed
- feedback sent and already incorporate
I am going to give it another spin with a larger dataset.
Simone.
Ing. Simone Giannecchini
Founder - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
http://www.linkedin.com/in/simonegiannecchini
http://twitter.com/simogeo
On Tue, Feb 16, 2010 at 2:45 PM, Andrea Aime <aaime@anonymised.com> wrote:
Andrea Aime
SOLARIS 10 is the OS for Data Centers - provides features such as DTrace,
Predictive Self Healing and Award Winning ZFS. Get Solaris 10 NOW
http://p.sf.net/sfu/solaris-dev2dev
Geoserver-devel mailing list
