[Geoserver-devel] imageio-ext-gdal switching to GDAL 2.x
GDAL is switching to Proj 6 https://trac.osgeo.org/gdal/wiki/rfc73_proj6_wkt2_srsbarn with version 2.5. Perhaps it would be better not to call GDAL 2.2 as new because there is rather soon a brand new GDAL which may not be totally compatible if imageio-ext is getting any information about projections through the GDAL bindings. See Backward compatibility in the RFC above.
-Jukka Rahkonen-
Lähettäjä: Andrea Aime <andrea.aime@…1268…>
Lähetetty: tiistai 26. helmikuuta 2019 16.39
Vastaanottaja: Geotools-Devel list geotools-devel@lists.sourceforge.net; Geoserver-devel geoserver-devel@lists.sourceforge.net
Aihe: [Geoserver-devel] imageio-ext-gdal switching to GDAL 2.x
in order to align the resurrecting OGR store and the imageio-ext GDAL stuff we are going to switch
imageio-ext to use the GDAL 2.x bindings (the 2.2.0 ones in particular, since I’ve done most of the
testing with them, but verified they work with 2.4 natives too).
So a new imageio-ext 1.3.0 version will be created that depends on the new GDAL, and master
will be switched to use it.
Also, imageio-ext master contains a few old “incomplete experiments” that we have been pushing forward ever since,
e.g., 1.2.x was branched off 1.1.x, not from master.
Since we are there, we are going to rename master to something else (master-2019-ex?), and fork a new
master branch off 1.2.x, this hopefully will allow us to do some more “normal” branch management
(except that we’ll cut releases from the new master, imageio-ext has no place for “experimental stuff”
since GT,GWC and GS only depend to it from official releases, not snapshots).
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Hi Jukka,
we are not going to support that switch for a while, this round of funding only allows us to get so far, and what we
have to deliver needs to be done now and be somewhat production ready.
I’d say, GDAL 2.5 + proj6 wil be a concern of another round of funding, if we’re lucky enough to get one, which may
start happening as soon as GDAL 2.5+ is distributed in LTS Linux distros (that’s what most installs go on, at least in my experience).
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
