[Geoserver-devel] ImageMosaic documentation ignores DBMS index capabilities
Two comments:
  • The attribution is given to GeoTools instead of GeoSolution, is that intentional?
  • Is possible to use additional attributes in the index file/table and filter the layer by them with &CQL_QUERY= ? If it is, it would be nice a include an example in the tutorial. There was a user’s question about this somewhere which I couldn’t answer.
-Jukka Rahkonen-
Torben Barsballe wrote:
Pull request for the doc update: https://github.com/geoserver/geoserver/pull/1349/files
I have adapted portions (mostly the JDBC configuration) of the GeoSolutions materials to flesh out the configuration section.
I have also added a bunch of updates based on my testing/usage of imagemosaic.
Torben
On Tue, Nov 24, 2015 at 6:06 AM, Simone Giannecchini <simone.giannecchini@…1268…> wrote:
Ciao Torben,
the explanation is as usual lack of time and changing priorities.
We created that material for training purposes and then we never had
the time to contribute (portion of ) it back.
I am perfectly fine with you pushing (after adapting) some portions of
it into the GeoServer doc.
Simone Giannecchini
Visit http://goo.gl/it488V for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy’s New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Tue, Nov 24, 2015 at 1:48 AM, Torben Barsballe
<tbarsballe@…3839…> wrote:
On Mon, Nov 23, 2015 at 3:15 PM, Andrea Aime <andrea.aime@…1268…>
wrote:
On Mon, Nov 23, 2015 at 11:36 PM, Torben Barsballe
I have recently been testing out various ImageMosaic functionality, and
have ran into a fairly blatant error in the ImageMosaic tutorial in the
GeoServer documentation
(http://docs.geoserver.org/latest/en/user/tutorials/image_mosaic_plugin/imagemosaic.html):
In order to configure a new CoverageStore and a new Coverage with this
plugin, an index file needs to be generated first in order to associate each
granule to its bounding box. Currently we support only a Shapefile as a
proper index, although it would be possible to extend this and use other
means to persist the index.
(Emphasis mine)
Looking at the codebase however, I can see that there is support for
other indexing stores, including PostGIS and H2.
Correct. And Oracle too.
Documentation on how to set up such an imagemosaic can be found on the
GeoSolutions site at
http://geoserver.geo-solutions.it/multidim/en/imagemosaic/mosaic_datastore.html
Could someone who has worked on this functionality and/or this
documentation comment as to why this has not been included in the GeoServer
documentation, and is only documented on the GeoSolutions site?
I find it unbelievable that someone from a company that is shipping a
GeoServer with extra functionality, that is not contributed back to
GeoServer, thinks to have the
right to call out other developers out on outdated docs, but for
functionality that is actually contributed and improved over time for
everybody’s benefit.
I did not intend to call out GeoSolutions on not updating the docs, but
rather verify that I am not stepping on anyone’s toes by adapting this
existing content to the GeoServer docs (see below). Given how busy many of
the core GeoServer developers are, “The docs haven’t been looked at since
before this functionality was added” is a perfectly valid response. Sorry if
this was not clear from my original message.
Also, the views of Boundless do not necessarily reflect my own (and vice
versa).
But even without going there, just to show you a counter example, can you
tell me where in the GeoServer guide we can find the equivalent of this?
http://suite.opengeo.org/4.1/cartography/rt/barnes.html
To paraphrase, why is that documented only in the OpenGeo Suite site?
Perfectly fair criticism (although the geoserver docs do give a full sld
example of a HeatMap, with the adaptation of the Transform syntax to other
rendering transforms left as an excercise to the reader). As you noted,
everyone is busy and doesn’t seem to find time to update the community docs.
docs.geoserver.org has various bits of outdated and incomplete
documentation, if you find bits are lacking you’re more than welcomed
to improve them. Or to provide help in other ways, thus freeing other devs
time for writing more docs. Don’t know, answering mails on the
users list, fixing bugs found in the tracker, helping to keep the build
servers going, updating the CITE tests, and so on
If it is just a case of outdated docs I am happy to improve them. Given that
the content at
is the property of GeoSolutions, may I adapt the content there while
updating the GeoServer docs, or would you prefer that I merely link to that
content instead?
Torben
Go from Idea to Many App Stores Faster with Intel(R) XDK
Give your users amazing mobile app experiences with Intel(R) XDK.
Use one codebase in this all-in-one HTML5 development environment.
Design, debug & build mobile apps & 2D/3D high-impact games for multiple
OSs.
http://pubads.g.doubleclick.net/gampad/clk?id=254741551&iu=/4140
Geoserver-devel mailing list
On Fri, Nov 27, 2015 at 8:36 AM, Rahkonen Jukka (MML) <
jukka.rahkonen@anonymised.com> wrote:
Two comments:
- The attribution is given to GeoTools instead of GeoSolution,
You mean "The ImageMosaic plugin is provided by `GeoTools <
http://geotools.org/&gt;\`\_&quot; ?
If so, yes, it's appropriate, the plugin lives indeed in GeoTools. We
normally give credit to the company/organization providing
a module when they first donate it, but the mosaic module has been in
GeoTools for many years now (and yes, it's true
99.9% of the work on it over the years has been done by GeoSolutions).
- Is possible to use additional attributes in the index
Yes, it works that way, you can filter on any attribute you have in the
mosaic index using CQL_FILTER, see for
example testRasterFilterRed/testRasterFilterGreen here:
https://github.com/geoserver/geoserver/blob/master/src/wms/src/test/java/org/geoserver/wms/map/GetMapIntegrationTest.java#L103
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
Hi Rahkonen,
- Is possible to use additional attributes in the index file/table
geoserver/src/wms/src/test/java/org/geoserver/wms/map/GetMapIntegrationTest.java at main · geoserver/geoserver · GitHub
I have added a clarification that the filter is applied against the mosaic
index and can access any attributes exposed by the index.
However, given that CQL_FILTER is not specific to ImageMosaic, I feel like
this is probably not the most appropriate place for a full example; see
http://docs.geoserver.org/stable/en/user/tutorials/cql/cql_tutorial.html
and
http://docs.geoserver.org/stable/en/user/services/wms/vendor.html#cql-filter
I have updated the docs and linked the cql tutorial from the relevant
section of the ImageMosaic tutorial for this purpose:
Torben
