Hi, Using the latest imagemosaic-jdbc plug-in, i had configured a new layer in Geoserver 2.0.1 and viewed in openlayers. The plug-in responds the map as expected. However, sometimes i see some white&black line in the image. Please see the attached image. I dont know what could be the reason becasue when i zoom-in those lines does not appear.Again when i zoom-out the same lines appear again. I thought its because of “outputtransparentcolor” so i changed transparent color with white and black but still i get the same image. Please i need help from anybody.
View this message in context: ImageMosaic-JDBC - white & black line appear in mosaic
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
Ciao Baski,
this looks like an issue with how you set up the translation in your
plugin. This happens when a small displacemenet between tiles exist
and therefore black lines appear between adiacent tiles.
I would check the chain of operations that you are doing to compute
the final translation.
Ciao,
Simone.
Ing. Simone Giannecchini
Founder - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
http://www.linkedin.com/in/simonegiannecchini
http://twitter.com/simogeo
On Wed, Mar 31, 2010 at 5:27 AM, Baski@anonymised.com <dbaskar@anonymised.com> wrote:
lines appear again. I thought its because of "outputtransparentcolor" so i
in mosaic
Download Intel® Parallel Studio Eval
Try the new software tools for yourself. Speed compiling, find bugs
proactively, and fine-tune applications for parallel performance.
See why Intel Parallel Studio got high marks during beta.
http://p.sf.net/sfu/intel-sw-dev
Geoserver-devel mailing list
As you said small displacement is there between the tiles. i solved the
problem now.
thanks simone
regards
baskar
View this message in context: http://old.nabble.com/ImageMosaic-JDBC---white---black-line-appear-in-mosaic-tp28066452p28174561.html
