[Geoserver-devel] ImageMosaic stopped working in
When upgrading from nightly trunk 2009.10.29 to nightly 2.0.x 2009.12.15 my existing ImageMosaic layers (dirs with GeoTiffs) stopped working, nor am I able to create new ImageMosaic layers. I get multiple exceptions of which this is the main one IMO (strange that EsriAsciiGridRaster is called):
15 Dec 12:03:08 ERROR [class org.geotools.gce.imagemosaic.ImageMosaicUtils] - Unable to build mosaic
java.lang.NullPointerException
  at it.geosolutions.imageio.plugins.arcgrid.raster.StringToDouble.acquire(StringToDouble.java:293)
  at it.geosolutions.imageio.plugins.arcgrid.raster.EsriAsciiGridRaster.parseHeader(EsriAsciiGridRaster.java:144)
  at it.geosolutions.imageio.plugins.arcgrid.spi.AsciiGridsImageReaderSpi.canDecodeInput(AsciiGridsImageReaderSpi.java:219)
  at javax.imageio.ImageIO$CanDecodeInputFilter.filter(ImageIO.java:541)
  at javax.imageio.spi.FilterIterator.advance(ServiceRegistry.java:793)
  at javax.imageio.spi.FilterIterator.next(ServiceRegistry.java:811)
  at javax.imageio.ImageIO$ImageReaderIterator.next(ImageIO.java:502)
  at javax.imageio.ImageIO$ImageReaderIterator.next(ImageIO.java:487)
  at org.geotools.gce.imagemosaic.IndexBuilder$MosaicDirectoryWalker.handleFile(IndexBuilder.java:553)
  at org.apache.commons.io.DirectoryWalker.walk(DirectoryWalker.java:367)
  at org.apache.commons.io.DirectoryWalker.walk(DirectoryWalker.java:335)
  at org.geotools.gce.imagemosaic.IndexBuilder$MosaicDirectoryWalker.<init>(IndexBuilder.java:857)
  at org.geotools.gce.imagemosaic.IndexBuilder.run(IndexBuilder.java:1064)
  at org.geotools.gce.imagemosaic.ImageMosaicUtils.createMosaic(ImageMosaicUtils.java:246)
  at org.geotools.gce.imagemosaic.ImageMosaicUtils.checkSource(ImageMosaicUtils.java:352)
  at org.geotools.gce.imagemosaic.ImageMosaicReader.<init>(ImageMosaicReader.java:171)
  at org.geotools.gce.imagemosaic.ImageMosaicFormat.getReader(ImageMosaicFormat.java:267)
  at org.geotools.gce.imagemosaic.ImageMosaicFormat.getReader(ImageMosaicFormat.java:87)
  at org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:834)
  at org.geoserver.catalog.CatalogBuilder.buildCoverage(CatalogBuilder.java:572)
  at org.geoserver.web.data.layer.NewLayerPageProvider.getItems(NewLayerPageProvider.java:72)
  at org.geoserver.web.wicket.GeoServerDataProvider.getFilteredItems(GeoServerDataProvider.java:162)
  at org.geoserver.web.data.layer.NewLayerPageProvider.getFilteredItems(NewLayerPageProvider.java:108)
I also found this error in http://pastebin.com/d2d1ab6fd . Found on Mac OSX (.DS_STORE maybe?). Switching back to trunk 2009.10.29 makes ImageMosaic fully working again. Any idea or an existing ticket I may not be aware off ? best,
--Just van den Broecke
Dear Just,
do you have any chance to share part of your sample data to reproduce the issue?
The pastebin link found by you have been posted yesterday by a colleague of mine having that issue.
However, he told me that he had a dirty installation since he had duplicated imageio-ext jars in both geoserver/WEB-INF/lib as well as on its JAVA_HOME/jre/lib/ext. Cleaning the machine (by eliminating duplicated jars reachable by the classloader), he solved the issue.
Please, let me know.
Best Regards,
Daniele
On Tue, Dec 15, 2009 at 1:37 PM, Just van den Broecke <just@anonymised.com> wrote:
at
at
at
at
at
org.geotools.gce.imagemosaic.IndexBuilder$MosaicDirectoryWalker.(IndexBuilder.java:857)
at
at
at
org.geotools.gce.imagemosaic.ImageMosaicReader.(ImageMosaicReader.java:171)
at
at
at
at
at
at
at
–Just van den Broecke
Return on Information:
Google Enterprise Search pays you back
Get the facts.
http://p.sf.net/sfu/google-dev2dev
Geoserver-devel mailing list
Eng. Daniele Romagnoli
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 328 0559267
Dear Daniele,
Yes I can send you a link but probably this is not neccessary anymore. I think the entire issue boils down to the fact that ImageMosaic fails after redeploy in a running Tomcat instance. I tested with several versions (2.0.0a, 2.0.x-2009.12.15 and trunk-2009.12.15) but always ImageMosaic fails after a redeploy.
I am mostly using hot-deploy, building/deploying a geoserver .war in Tomcat Ant using a configured GS version. This always works fine for most GS/GT functions but appearantly not for ImageMosaic. Maybe a class-unloading issue. I don't know if it is a requirement that GS should be redeployable.
Thanks, and best regards,
--Just
Daniele Romagnoli wrote:
Dear Just,
Best Regards,
Daniele
On Tue, Dec 15, 2009 at 1:37 PM, Just van den Broecke <just@anonymised.com <mailto:just@anonymised.com>> wrote:
           at
           at
           at
           at
           at
           at
           at
           at
           at
           at
           at
           at
           at
           at
           at
           at
           at
           at
           at
           at
           at
           at
           at
    Get the facts.
    <mailto:Geoserver-devel@lists.sourceforge.net>
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Just
Just van den Broecke just@anonymised.com
Just Objects B.V. tel +31 65 4268627 Skype: justb4
The Netherlands http://www.justobjects.nl
