[Geoserver-devel] Implement custom function
Hello everyone,
I am trying to implement a new function on my geoserver but I keep failing. I succeed to implement WPS process but function…
I tried the tutorial on geotools (http://docs.geotools.org/latest/userguide/tutorial/function.html) but it won’t work. The problem is not the custom function itself but more a problem of referencing. How do I reference a new function to geoserver and use it in SLD ? Can you be a more bit precise than
  1. We can now register our factory.
    Create the file:
    • META_INF/services/org.geotools.filter.FunctionFactory
  2. Fill in the following contents (one implementation class per line):
    org.geotools.tutorial.function.ExampleFunctionFactory
and describe the steps I may have missed .
Thank you
Matthieu BONVENTI
Hi Matthieu,
you can have a look at this project https://github.com/geobeyond/fluxomajic/tree/master/src/main/resources/META-INF/services and after building place your library in the geoserver lib directory.
Hope it helps.
Francesco
Matthieu BONVENTI
Thank you, I found the solution my self, I d like to send a mail to people who wrote the function tutorial
The folder name is not META_INF but META-INF and I had to put it in a folder named “resources” that I created under src/main.
Now it works perfectly…maybe they should have said this in the tutorial…
Matthieu Bonventi
      1. 오후 3:15에 “Francesco Bartoli” <francesco.bartoli@anonymised.com>님이 작성:
Hi Matthieu,
Hope it helps.
Francesco
Ing. Francesco Bartoli
CTO & Owner
Geobeyond Srl
Via M. Augusta 68
02040 - Vacone (RI) - Italy
http://www.geobeyond.it
Mob: +39 333 2997173
Mail: francesco.bartoli@anonymised.com
Twitter: @geobeyond
SkypeId: francesco_bartoli
Il giorno 16/gen/2015, alle ore 12:51, Bonventi Matthieu <matthieu.bonventi@anonymised.com> ha scritto:
Hello everyone,
    Create the file:
Thank you
Matthieu BONVENTI
New Year. New Location. New Benefits. New Data Center in Ashburn, VA.
GigeNET is offering a free month of service with a new server in Ashburn.
Choose from 2 high performing configs, both with 100TB of bandwidth.
Higher redundancy.Lower latency.Increased capacity.Completely compliant.
http://p.sf.net/sfu/gigenet_______________________________________________
Geoserver-devel mailing list
On Fri, Jan 16, 2015 at 3:18 PM, Bonventi Matthieu <
folder named "resources" that I created under src/main.
Now it works perfectly...maybe they should have said this in the
tutorial...
The tutorial is in the source code, you can also make a pull a request and
contribute a fix :slight_smile:
https://github.com/geotools/geotools/blob/master/docs/user/tutorial/function.rst
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Thanks for catching the typo - fix applied:
https://github.com/geotools/geotools/commit/699fc4295a82906cc684d71d8eb39b3ec939c129
On 16 January 2015 at 06:18, Bonventi Matthieu <matthieu.bonventi@anonymised.com> wrote:
Matthieu Bonventi
Hi Matthieu,
Hope it helps.
Francesco
CTO & Owner
Geobeyond Srl
Via M. Augusta 68
Twitter: @geobeyond
Hello everyone,
    Create the file:
Thank you
Matthieu BONVENTI
Jody Garnett
Ah ok I didn’t notice . I was talking about the tutorial on geotools website. All seems to be ok now, I’m beginner I hope to learn a lot about geoserver/geotools in the near future
Matthieu Bonventi
That is the source code for the website, in about 30 mins the website will update with the fix.
On 16 January 2015 at 07:07, Bonventi Matthieu <matthieu.bonventi@anonymised.com> wrote:
Matthieu Bonventi
Jody Garnett
