[Geoserver-devel] Implementing a WPS Process: documentation outdated?
Hi everybody,
while I was trying to generate a maven archetype for implementing a WPS-Process, the documentation at http://docs.geoserver.org/stable/en/developer/programming-guide/wps-services/implementing.html and especially the example seemed to me to be outdated. If I remember correctly, following the step-by-step example exactly word-by-word lead to a maven project that would not compile.
I have this working now, but wanted to double check whether it was me that did something wrong or whether the documentation needs to be updated.
I'd volunteer to correct the docs, if this OK for you.
For a reference, here is an example WPS-Process maven project: https://github.com/marcjansen/geoserver-wps-archetype/tree/master/example-hello-wps and then there is the beforementioned maven archetype (generated from the sample) https://github.com/marcjansen/geoserver-wps-archetype/tree/master/archetype
The code over there would be basically what I'd change the docs to read.
Best regards & thanks for any feedback,
Marc
On Fri, Nov 14, 2014 at 12:41 PM, Marc Jansen <jansen@anonymised.com> wrote:
Hi everybody,
Definitely the docs, they were never touched after the first draft.
In general the dev doc are not receiving much (if any) updates at all,
I believe we're too short staffed to maintain them.
the sample)
I'd update them to add a test to the wps test jar (which I made GeoServer
generate,
off the trunk code, just recently) in case people want to run integration
tests
like
https://github.com/geoserver/geoserver/blob/master/src/extension/wps/wps-core/src/test/java/org/geoserver/wps/ExecuteTest.java
using the same base class.
Another thing that could be handy, for people that cannot modify
the GeoServer own web-app pom, would be to add a test/provided
dependency on the web-app module, dependencies on jetty,
and copy the Start.java class from web-app, in order to run GeoServer
with that extra process without having to manually deploy the jar
to a instance already unpacked in Tomcat.
Just an idea
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
I would recommend the Geotools process tutorial
On Fri, Nov 14, 2014 at 12:41 PM, Marc Jansen <jansen@anonymised.com.> wrote:
Hi everybody,
I believe we’re too short staffed to maintain them.
I’d volunteer to correct the docs, if this OK for you.
the sample)
I’d update them to add a test to the wps test jar (which I made GeoServer generate,
off the trunk code, just recently) in case people want to run integration tests
like https://github.com/geoserver/geoserver/blob/master/src/extension/wps/wps-core/src/test/java/org/geoserver/wps/ExecuteTest.java
Just an idea
Ing. Andrea Aime
@geowolf
Technical Lead
Hey Jody and Andrea,
I'll see if I can come up with something. I hope to find time for this.
Thanks anyhow in assuring me that the problem wasn't on my side.
Best,
Marc
On Fri, Nov 14, 2014 at 4:59 AM Andrea Aime <andrea.aime@anonymised.com <mailto:andrea.aime@anonymised.com>> wrote:
    <jansen@anonymised.com <mailto:jansen@anonymised.com>> wrote:
        Hi everybody,
        implementing a
        remember
        word-by-word lead
        was me
        be updated.
        (generated from
        the sample)
    GeoServer generate,
    integration tests
    like
    Just an idea
