[Geoserver-devel] Implements ows troubles with Post Data
Hello,
I want to realize a own ows plugin. The KVP parsing by HTTP Get is no
problem.
But when I want to use XML Post I cant fetch the Post-Data.
I use request.getInputstream but it returns me no Information also i try it
with reset/mark but it gives a exception that it is not allowed.
I checked all methods from request Object but the Post-Data is lost.
But getContentLength() gives me the correct size of the HTTP-Request.
In my opinion the ows.Dispatcher work not correctly.
So what can i do?
Ps: Sorry for my bad english :wink:
View this message in context: http://osgeo-org.1560.n6.nabble.com/Implements-ows-troubles-with-Post-Data-tp4678415p4678415.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
The way ows services handle posted xml data is by registering an instance of org.geoserver.ows.XmlRequestReader in the spring context. That object must parse the xml into some object, which the dispatcher will then pass into the ows service request. Look at the wfs module for some examples.
Hope that helps.
-Justin
On Mon, Apr 2, 2012 at 3:54 AM, meierchen <marcel.teuber@anonymised.com> wrote:
Hello,
problem.
So what can i do?
Better than sec? Nothing is better than sec when it comes to
monitoring Big Data applications. Try Boundary one-second
resolution app monitoring today. Free.
http://p.sf.net/sfu/Boundary-dev2dev
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
Dear all,
I would try to develop a Geoserver DataStore plugin for a legacy database, which has no spatial extension, and for the beginning it would be ok, to have it read-only. I would need to limit some SQL queries with some clauses to not expose all features, but only those that fit some criteria.
And my actual question is, how do I finally compile and package the plugin? Do I need the whole Geoserver or Geotools source? Can I do that with maven, with simply working in the hierarchy like http://svn.osgeo.org/geotools/trunk/modules/unsupported/myModule (I would derive from a simple existing one) ?
Best,
Alex
Am 02.04.2012 21:54, schrieb meierchen:
Hello,
problem.
So what can i do?
Hi Alex,
You should only need the geotools sources. And you should be able to use straight maven. There is a good guide for this in the geotools documentation.
http://docs.geotools.org/stable/userguide/quickstart.html
Should be a good place to start.
-Justin
On Sat, Apr 7, 2012 at 6:31 PM, Alexander Kmoch <alexander.kmoch@anonymised.com> wrote:
Dear all,
criteria.
Best,
Alex
Hello,
problem.
So what can i do?
For Developers, A Lot Can Happen In A Second.
Boundary is the first to Know…and Tell You.
Monitor Your Applications in Ultra-Fine Resolution. Try it FREE!
http://p.sf.net/sfu/Boundary-d2dvs2
Justin Deoliveira
Hi Justin,
thanks, yay, so at least one time building whole geotools and download all the maven dependencies and then actually starting to develop on the plugin, right :slight_smile: ?
Thanks, I just was not sure, wether to really build all geotools at first.
Best,
Alex
Am 08.04.2012 13:00, schrieb Justin Deoliveira:
Hi Alex,
documentation.
-Justin
<mailto:alexander.kmoch@anonymised.com>> wrote:
    Dear all,
    criteria.
    Best,
    Alex
     > Hello,
     > I want to realize a own ows plugin. The KVP parsing by HTTP Get is no
     > problem.
     > But when I want to use XML Post I cant fetch the Post-Data.
     > I use request.getInputstream but it returns me no Information
    also i try it
     > with reset/mark but it gives a exception that it is not allowed.
     > I checked all methods from request Object but the Post-Data is lost.
     > But getContentLength() gives me the correct size of the HTTP-Request.
     > In my opinion the ows.Dispatcher work not correctly.
     > So what can i do?
     > Ps: Sorry for my bad english :wink:
     > View this message in context:
     > Sent from the GeoServer - Dev mailing list archive at Nabble.com.
     > Better than sec? Nothing is better than sec when it comes to
     > monitoring Big Data applications. Try Boundary one-second
     > resolution app monitoring today. Free.
     > http://p.sf.net/sfu/Boundary-dev2dev
     > Geoserver-devel mailing list
     > Geoserver-devel@lists.sourceforge.net
    <mailto:Geoserver-devel@lists.sourceforge.net>
     > https://lists.sourceforge.net/lists/listinfo/geoserver-devel
    Boundary is the first to Know...and Tell You.
Justin Deoliveira
On Sun, Apr 8, 2012 at 2:02 AM, Alexander Kmoch <alexander.kmoch@anonymised.com> wrote:
Hi Justin,
This is how most core developers work yes. But again if you don’t want to build geotools locally you can just depend on them via maven. A workflow i recommend is this.
  1. Set up your project to depend on geotools via the geotools quickstart
  2. Do a full build of your template project, this will download all the geotools jars and its dependenices
  3. Develop
  4. Do “offline” builds to avoid continually download geotools snapshots (-o switch to maven)
Best,
Alex
Hi Alex,
documentation.
-Justin
<alexander.kmoch@anonymised.com930…
mailto:[alexander.kmoch@anonymised.com](mailto:alexander.kmoch@anonymised.com)> wrote:
Dear all,
criteria.
Best,
Alex
Hello,
problem.
also i try it
So what can i do?
mailto:[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@anonymised.com.sourceforge.net)
mailto:[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@anonymised.comeforge.net)
Justin Deoliveira
Justin Deoliveira
Hi Justin,
thanks, worked fine, did the complete build, had some issues with imageio and jai libs, but I skipped some tests and thats fine, as I am just going to fiddle with some simple vector features around :slight_smile:
Alex
Am 11/04/2012 7:45 a.m., schrieb Justin Deoliveira:
    Hi Justin,
This is how most core developers work yes. But again if you don't want
3. Develop
4. Do "offline" builds to avoid continually download geotools snapshots
    first.
    Best,
    Alex
     > Hi Alex,
     > You should only need the geotools sources. And you should be able
    to use
     > straight maven. There is a good guide for this in the geotools
     > documentation.
     > http://docs.geotools.org/stable/userguide/quickstart.html
     > Should be a good place to start.
     > -Justin
     > On Sat, Apr 7, 2012 at 6:31 PM, Alexander Kmoch
     > <alexander.kmoch@anonymised.com
     > <mailto:alexander.kmoch@anonymised.com
    <mailto:alexander.kmoch@anonymised.com>>> wrote:
     > Dear all,
     > I would try to develop a Geoserver DataStore plugin for a legacy
     > database, which has no spatial extension, and for the beginning
    it would
     > be ok, to have it read-only. I would need to limit some SQL
    queries with
     > some clauses to not expose all features, but only those that fit some
     > criteria.
     > And my actual question is, how do I finally compile and package the
     > plugin? Do I need the whole Geoserver or Geotools source? Can I
    do that
     > with maven, with simply working in the hierarchy like
     > http://svn.osgeo.org/geotools/trunk/modules/unsupported/myModule (I
     > would derive from a simple existing one) ?
     > Best,
     > Alex
     > Am 02.04.2012 21:54, schrieb meierchen:
     > > Hello,
     > > I want to realize a own ows plugin. The KVP parsing by HTTP Get
    is no
     > > problem.
     > > But when I want to use XML Post I cant fetch the Post-Data.
     > > I use request.getInputstream but it returns me no Information
     > also i try it
     > > with reset/mark but it gives a exception that it is not allowed.
     > > I checked all methods from request Object but the Post-Data is
    lost.
     > > But getContentLength() gives me the correct size of the
    HTTP-Request.
     > > In my opinion the ows.Dispatcher work not correctly.
     > > So what can i do?
     > > Ps: Sorry for my bad english :wink:
     > > View this message in context:
     > > Sent from the GeoServer - Dev mailing list archive at Nabble.com.
     > > Better than sec? Nothing is better than sec when it comes to
     > > monitoring Big Data applications. Try Boundary one-second
     > > resolution app monitoring today. Free.
     > > http://p.sf.net/sfu/Boundary-dev2dev
     > > _______________________________________________
     > > Geoserver-devel mailing list
     > > Geoserver-devel@lists.sourceforge.net
     > <mailto:Geoserver-devel@lists.sourceforge.net
    <mailto:Geoserver-devel@lists.sourceforge.net>>
     > > https://lists.sourceforge.net/lists/listinfo/geoserver-devel
     > For Developers, A Lot Can Happen In A Second.
     > Boundary is the first to Know...and Tell You.
     > Monitor Your Applications in Ultra-Fine Resolution. Try it FREE!
     > http://p.sf.net/sfu/Boundary-d2dvs2
     > Justin Deoliveira
     > OpenGeo - http://opengeo.org
     > Enterprise support for open source geospatial.
Justin Deoliveira
