[Geoserver-devel] Import Process
We were working with some WPS process chaining recently. While looking at the Import Process, we noticed that there was a TODO for a supporting store creation here: https://github.com/geoserver/geoserver/blob/master/src/extension/wps/wps-core/src/main/java/org/geoserver/wps/gs/ImportProcess.java#L142.
Anyhow, for our immediate need, we ended up wrapping and delegating to the GeoServer Import Process to cover the lack of store creation. I think satisfying the todo may require a few lines, and it likely really close to what we already did.
Any objections about a quick PR for that todo? Also, if there are any notes, feel free to pass those on.
Jim
PR always welcome, tricky part is of course the test case.
On 25 March 2015 at 15:22, Jim Hughes <jnh5y@anonymised.com> wrote:
Jim
Dive into the World of Parallel Programming The Go Parallel Website, sponsored
by Intel and developed in partnership with Slashdot Media, is your hub for all
things parallel software development, from weekly thought leadership blogs to
news, videos, case studies, tutorials and more. Take a look and join the
conversation now. http://goparallel.sourceforge.net/
Geoserver-devel mailing list
Jody Garnett
On Wed, Mar 25, 2015 at 11:22 PM, Jim Hughes <jnh5y@anonymised.com> wrote:
No objection, just wondering how you're going to structure the creation in
terms of input params,
you'll need to pass in a map of values (the connection parameters), do you
already know how it will
look java wise, and wps call wise?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hello,
I’m basing the ImportRaster WPS process on the existing GeoServer ImportProcess. My code simply creates an empty CoverageStore using a CatalogBuilder and then passes the parameters to ImportProcess to actually import the coverage.
It looks like ImportProcess always imports the coverage as a GeoTIFF.
I have the WPS working, and it’s sufficient for our needs. I think it will be fairly simple to get into GeoServer, I’m currently working on the test.
Thank you,
Michael Matthews
No objection, just wondering how you’re going to structure the creation in terms of input params,
you’ll need to pass in a map of values (the connection parameters), do you already know how it will
Ing. Andrea Aime
@geowolf
Technical Lead
Hello,
I’ve submitted a PR for GEOS-6970.
I’ve written two tests for creating a vector layer and a raster layer.
Most of the code for creating a raster layer already existed, it just used a default name for the store. My code just handles the case when a store name is provided but the store doesn’t exist.
The raster store defaults to a GeoTiff store.
Let me know if there’s anything that could use polishing.
Thank you,
Michael Matthews
Ing. Andrea Aime
@geowolf
Technical Lead
Some feedback provided on https://github.com/geoserver/geoserver/pull/1006
I had some questions which we may need Andrea to answer, other than that please update the header for the modified files.
On 7 April 2015 at 09:48, Michael Matthews <mmatthews@anonymised.com> wrote:
Hello,
Thank you,
Michael Matthews
BPM Camp - Free Virtual Workshop May 6th at 10am PDT/1PM EDT
Develop your own process in accordance with the BPMN 2 standard
Learn Process modeling best practices with Bonita BPM through live exercises
http://www.bonitasoft.com/be-part-of-it/events/bpm-camp-virtual- event?utm_
source=Sourceforge_BPM_Camp_5_6_15&utm_medium=email&utm_campaign=VA_SF
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
