[Geoserver-devel] importer-bdb: anyone using it, or should it be pushed down to community?
in parallel to my other mail about importer-jdbc, I’m wondering, is anyone using or interested in maintaining
importer-bdb? My experience on the list would suggest a “no” answer to both questions, if that’s actually
the case, I’d suggest to push it down to community module status, what do you think?
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
+1, it won’t work on a clustered set up, and a jdbc one over an embedded database would serve the same purpose given the case?
Gabriel Roldán
+1 as well.
the less code to maintain the better...
Simone Giannecchini
Visit http://bit.ly/gs-services for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
mob: +39 333 8128928
On Tue, Oct 29, 2019 at 2:47 PM Gabriel Roldan <gabriel.roldan@anonymised.com> wrote:
+1, it won't work on a clustered set up, and a jdbc one over an embedded database would serve the same purpose given the case?
On Tue, 29 Oct 2019 at 08:47, Andrea Aime <andrea.aime@anonymised.com> wrote:
in parallel to my other mail about importer-jdbc, I'm wondering, is anyone using or interested in maintaining
importer-bdb? My experience on the list would suggest a "no" answer to both questions, if that's actually
the case, I'd suggest to push it down to community module status, what do you think?
Geoserver-devel mailing list
Gabriel Roldán
I actually found that… it does not work period… there is code saving FeatureType in the ImportTask metadata map,
and the map is marked as transient… but its contents are needed and the import fails with an NPE.
If removing the transient declaration from the map field, then the serialization fails because the map contains
non serializable items… the funny thing is that the code involved seems like it there on day one of Boundless donation,
The BDB import store also has an option to use xstream for serialization, the setting of which one to use
is hard coded, but flipping to it on also fails.
From which I’m guessing that the BDB store actually never worked, at least for vector imports… if anyone
wants to try, add a dependency to the rest module and then run the test subclass I’ve prepared, and look
at the fireworks.
Long story short… I guess it would be better to just remove the module…
(attachments)
BDBImportIntegrationTest.java (828 Bytes)
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Ah forgot, to run the test and make it use the BDB import store, the -Dorg.geoserver.importer.store=bdb
needs to be set
