during the last two days I’ve spend a good amount of time trying to get the importer build on Windows.
I’ve managed to fix some issues, but one remains that seems to be impregnable to my attempts at fixing it.
This is the failure, in summary:
Results :
Failed tests: testArchiveOnIndirectImport(org.geoserver.importer.ImporterDataTest)
And it’s due to this log statement:
Running org.geoserver.importer.ImporterDataTest
SimpleFeatureTypeImpl http://geotools.org:feature identified extends Feature(geometry:geometry,int:int,string:string,double:double)
java.io.IOException: unable to delete target\importer2070856181511784271data\archsites.shp
at org.geoserver.importer.Directory.cleanup(Directory.java:450)
at org.geoserver.importer.Directory.archive(Directory.java:434)
at org.geoserver.importer.Importer.run(Importer.java:711)
at org.geoserver.importer.Importer.run(Importer.java:663)
at org.geoserver.importer.Importer.run(Importer.java:659)
at org.geoserver.importer.ImporterDataTest.testArchiveOnIndirectImport(ImporterDataTest.java:480)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
Now… I saw that the code in the importer was pretty fragile, opening a feature reader and a writer
outside of a try/finally block, with no guarantee of them being always closed.
So I’ve modified that, and it did not help.
Then tried to replicate sort of what the importer is doing in a Shapefile test (and committed it), but it is not breaking
on Windows for me, which seems to suggest Shapefile itself is not leaving
@Test
public void testReadDelete() throws Exception {
File shpFile = copyShapefiles(STATE_POP);
ShapefileDataStore ds = new ShapefileDataStore(shpFile.toURI().toURL());
try (FeatureReader<SimpleFeatureType, SimpleFeature> reader = ds.getFeatureReader(new Query(ds.getTypeNames()[0]), Transaction.AUTO_COMMIT)) {
reader.getFeatureType();
while(reader.hasNext()) {
reader.next();
ds.dispose();
assertTrue(shpFile.delete());
assertTrue(sibling(shpFile, “shx”).delete());
assertTrue(sibling(shpFile, “dbf”).delete());
The issue seems to be related to garbage collection and/or timing, because I cannot reproduce
it while debugging, only while running (and even there, often, but not always).
One thing that I’ve noticed is that the common VFS code in VFSWorker seems
to memory map the shapefile in question (as reported by Sysinternals “Process monitor”),
and also noticed that we are using a old version of VFS (v1.0, whilst v2.0 has been released in 2011).
So maybe the issue could be here, but it’s just a blind guess.
Anyone has ideas? I’m tempted to just check if the OS is Windows, and if so, do not check
that the input directory has been deleted at line 481 of that test.
To the best of my knowledge, this is the last issue before we can get a working build of GeoServer
on Windows.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
