while looking into old bug reports I’ve found by accident that all the
importer resources are not thread safe, as they use a REST wiring
that is not unless the resource classes are declared as prototypes in Spring:
https://osgeo-org.atlassian.net/browse/GEOS-4179
The fix is easy, but I wanted to make sure no more of these problems pop up,
so I’ve modified BeanResourceFinder so that it rebels and throws an exception
in case a thread unsafe setup is detected:
https://github.com/geoserver/geoserver/pull/1345/files#diff-304e99c495bc31922c4ec37f6c718c65R85
This one one gets an exception with details of how to fix the issue while running tests, or if there
are none, at the first GeoServe startup.
Do you see issues porting this change backwards? Should I maybe remove the check for the backport
to 2.8.x and 2.7.x?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
