[Geoserver-devel] Importer: single call async create and execute mode
even with the latest pull request about asynch init, the importer REST api is
still a bit cumbersome to use, in that at least two asynch calls (and the associated
state tracking) need to be made in order perform a successful import.
In this mail I’m proposing a new import mode in which a single call is made, where
the creation results in the process to be run immediately, as soon as the init phase
is complete.
Of course this assumes the input data is good and that the tasks are created succesfully,
which is often the case in fully automated setups.
The idea is that the initial POST creating the process can have not only an async=true
paramete, but also a execute=true one that will make the import start immediately.
Code wise, I was thinking of calling Importer.runAsynch(…), which in turn would check if
there is any task in the context, and if not, would transparently perform the init phase.
This would work best with the default transformations idea proposed in the last round of mails,
allowing the caller to attach predictable transformations to all generated tasks, without
having to go over them one by one.
What do you think? This should make the importer a bit easier to use outside of the interactive
use cases that it was initially designed for.
Meet us at the INSPIRE Conference in Lisbon 25-29 May 2015! Visit http://goo.gl/WHKDXT for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
I like the idea of an easier “one step” workflow, I find it a bit hard to reason about how the importer rest api is used currently (and have not provided you much feedback).
Does anyone else have thoughts on this one?
On 28 May 2015 at 05:50, Andrea Aime <andrea.aime@anonymised.com> wrote:
is complete.
Ing. Andrea Aime
@geowolf
Technical Lead
Geoserver-devel mailing list
Jody Garnett
here we go, pull request for this one:
https://github.com/geoserver/geoserver/pull/1121
On Thu, May 28, 2015 at 11:50 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
is complete.
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
I have done a review, and added my comments to the PR.
The code looks good, but there a few minor documentation and style issues.
Torben
On Mon, Jun 22, 2015 at 9:36 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Monitor 25 network devices or servers for free with OpManager!
OpManager is web-based network management software that monitors
network devices and physical & virtual servers, alerts via email & sms
for fault. Monitor 25 devices for free with no restriction. Download now
http://ad.doubleclick.net/ddm/clk/292181274;119417398;o
On Thu, May 28, 2015 at 11:50 AM, Andrea Aime <andrea.aime@anonymised.com8…> wrote:
is complete.
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
