the rendering based GetFeatureInfo implementation I was talking about some days ago.
Advantages:
- it handles point symbols with an irregular shape, you get a hit only if you click on the actually
painted portion of the symbol (or close by), but not if you click in a empty part of it
Works nicely also for those that simulated offsets by adding extra space in the symbol image - if handles properly styles with different symbol sizes, you get a hit only if you click on the
painted symbol, instead of getting a hit considering the largest possible symbol in the style - conversely, if a size is fully dynamic (defined as 10 times the value of an attribute for example),
you get a hit if you actually click on a painted symbol, instead of having to go very close to
the center (the old code would give up and assume the search radius is the minimal one, 5px) - does not get issues with dash arrays or hatches, will give you a hit even if you’re clicking
in the white space (which required some extra effort given it’s paint based)
Disadvantage:
- it’s somewhat slower as it’s painting instead of just querying,
and significantly slower if you have sizes that are attribute dependent,
since it will scan the features first (without painting them, just evaluating expressions)
to know how large the search area must be, but this can be overcome by setting the buffer search area in the feature type.
But… I guess better slower than giving back a response that is completely inaccurate/wrong?
The code is on trunk and enabled by default, it can be turned off by setting the following system variable:
-Dorg.geoserver.wms.featureinfo.render.enabled=false
I’ll backport to 2.4.x once 2.4.3 is out, in such a way that none of the existing code is touched
(the refactor of GetFeatureInfo won’t be backported) and off by default in this case
Please try it out and let me know how it works for you, it will be in master nightly builds starting
tomorrow.
== GeoSolutions will be closed for seasonal holidays from 23/12/2013 to 06/01/2014 ==
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
