[Geoserver-devel] Improvement for SQL Views (Virtual Tables)
Sorry for the cross porting but this touches the two projects …
I would like to extend the current support of SQL views (Virtual Tables) to
allow us to add a placeholder for the where clause where GeoServer will
add the needed filter.
This comes handy (better performance) when we have extra operations that
can be done on top of the rows filtered with the GeoServer filter first.
Consider the following use case: we have several meteorological stations
that have several measurements (wind speed, temperature, humidity,
etc …) and for each one we are only interested in the last measurement for
each available measurement type.
We can create a query that returns exactly what we want:
SELECT STATION_NAME,
MEASUREMENT,
MEASUREMENT_TYPE,
LOCATION
FROM
(SELECT st.common_name AS STATION_NAME,
ob.value AS MEASUREMENT,
pr.param_name AS MEASUREMENT_TYPE,
st.position AS LOCATION,
ROW_NUMBER() OVER(PARTITION BY st.id, pr.param_name
ORDER BY ob.time DESC) AS RANK
FROM meteo.meteo_stations st
LEFT JOIN meteo.meteo_observations ob ON st.id = ob.station_id
LEFT JOIN meteo.meteo_parameters pr ON ob.parameter_id = pr.id) AS stations
WHERE RANK = 1;
The issue is that this query will NOT be as efficient as it can be when used with GeoServer,
actually the performance will be quite bad. This happens because GeoServer will add
is WHERE clause around the query above, which means that the ranking will happen
for all the data set first and only after we will filter what we don’t need.
The following query that uses the :where_clause: placeholder will do the opposite, we will first
filter what we don’t want and then do the ranking:
MEASUREMENT,
MEASUREMENT_TYPE,
LOCATION
FROM
(SELECT STATION_NAME,
MEASUREMENT,
MEASUREMENT_TYPE,
LOCATION,
ROW_NUMBER() OVER(PARTITION BY STATION_ID, MEASUREMENT_TYPE
ORDER BY TIME DESC) AS RANK
FROM
(SELECT st.id AS STATION_ID,
ob.time AS TIME,
WHERE 1 = 1 :where_clause:) AS stations_filtered) AS stations
WHERE RANK = 1;
This will make the usage of some SQL analytic functions affordable (performance wise) with GeoServer.
The changes in the code are quite small (a few lines), and this is an additive change fully backward compatible.
Any objection ? comments ?
Nuno Oliveira
Nuno Oliveira
GeoServer Professional Services from the experts! Visit [http://goo.gl/it488V](http://goo.gl/it488V) for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
Via di Montramito 3/A
55054  Massarosa (LU)
fax:      +39 0584 1660272
[http://www.geo-solutions.it](http://www.geo-solutions.it)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility  for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
Sounds good to me
Ian
On 7 March 2018 at 14:59, Nuno Oliveira <nuno.oliveira@anonymised.com> wrote:
MEASUREMENT,
MEASUREMENT_TYPE,
LOCATION
FROM
WHERE RANK = 1;
MEASUREMENT,
MEASUREMENT_TYPE,
LOCATION
FROM
MEASUREMENT,
MEASUREMENT_TYPE,
LOCATION,
FROM
ob.time AS TIME,
WHERE RANK = 1;
Nuno Oliveira
Nuno Oliveira
@nmcoliveira
Software Engineer
GeoTools-Devel mailing list
GeoTools-Devel@anonymised.com66…sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geotools-devel
Ian Turton
Hi Nuno,
not against but I have a couple of worries.
  1. The where clause generated by GeoServer talks about attributes visible when the full query is run, depending on the query
    complexity one might decide to place the where somewhere that only has a subset of such attributes computed (e…g, case with inner queries).
    This will eventually break the query if the wrong attribute is filtered upon. I guess this migth be dealt with at the documentation level:
    “hey dude, we give you this opportunity, the mechanism works like this , you can shoot yourself in the foot with it, don’t blame us”
  2. The SQL View mechanism is generic, cross database… will whatever query location work along with paging and query hints across
    all databases? What I’m asking here is to consider all JDBCDataStore implementation, as this is not “Oracle sql views”, but “sql views” :-p
    Again, this might be documented, e.g., “Sorry XYZ users, :where_clause: is not for you”
Andera
On Wed, Mar 7, 2018 at 3:59 PM, Nuno Oliveira <nuno.oliveira@anonymised.com> wrote:
MEASUREMENT,
MEASUREMENT_TYPE,
LOCATION
FROM
WHERE RANK = 1;
MEASUREMENT,
MEASUREMENT_TYPE,
LOCATION
FROM
MEASUREMENT,
MEASUREMENT_TYPE,
LOCATION,
FROM
ob.time AS TIME,
WHERE RANK = 1;
Nuno Oliveira
Nuno Oliveira
@nmcoliveira
Software Engineer
Andrea Aime
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
Hi Andrea,
thanks for the feedback, please see my answers bellow :slight_smile:
As I said: The :where_clause: clause should always be applied at the point where we have already all the final attributes (attributes GeoServer is aware of). I understand your concern, a user may create the view and put the WHERE place holder in a nested deep query where only a portion of the attributes are available and then everything will be fine until a new request that uses a non available attribute is requested … Unfortunately there is nothing we can do to prevent that to happen except warn the user about the correct usage of the placeholder in the documentation. Analytics operations (DENSE_RANK, FIRST_VALUE, LAST_VALUE, RANK, ROW_NUMBER) are available in ANSI SQL (maybe I’m wrong). My example is a PostgreSQL query, I didn’t test it with Oracle but I have similar queries that work that way in Oracle too … Summarizing, this is an advanced feature that may come handy in some use cases (common enough to be handled by ANSI SQL) but if a user uses it wrong it can bite him hard :slight_smile:
On 03/07/2018 03:25 PM, Andrea Aime wrote:
Hi Nuno,
  1. The SQL View mechanism is generic, cross database… will whatever query location work along with paging and query hints across
Andera
On Wed, Mar 7, 2018 at 3:59 PM, Nuno Oliveira <nuno.oliveira@…1268…> wrote:
MEASUREMENT,
MEASUREMENT_TYPE,
LOCATION
FROM
WHERE RANK = 1;
MEASUREMENT,
MEASUREMENT_TYPE,
LOCATION
FROM
MEASUREMENT,
MEASUREMENT_TYPE,
LOCATION,
FROM
ob.time AS TIME,
WHERE RANK = 1;
Nuno Oliveira
Nuno Oliveira
@nmcoliveira
Software Engineer
GeoTools-Devel@…366…sourceforge.net
Andrea Aime
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it
Nuno Oliveira
@nmcoliveira
Software Engineer
On Wed, Mar 7, 2018 at 4:53 PM, Nuno Oliveira <
2) The SQL View mechanism is generic, cross database... will whatever
    all databases? What I'm asking here is to consider all JDBCDataStore
implementation, as this is not "Oracle sql views", but "sql views" :-p
    Again, this might be documented, e.g., "Sorry XYZ users,
:where_clause: is not for you"
ROW_NUMBER)
are available in ANSI SQL (maybe I'm wrong). My example is a PostgreSQL
query, I didn't
Oracle too ...
Unfortunately not, paging is done in the most atrocious ways across the
various database dialets, none of them
using a recognizable standard as far as I know
Ing. Andrea Aime
@geowolf
Technical Lead
Indeed Teradata and SQLServer dialects pagination handling are quite complex.
As far I can tell they should work fine.
Unfortunately not, paging is done in the most atrocious ways across the various database dialets, none of them
Nuno Oliveira
@nmcoliveira
Software Engineer
On Wed, Mar 7, 2018 at 5:50 PM, Nuno Oliveira <
complex.
Awesome. Then I have no objection, it's a good feature in the right hands.
Just remember to document clearly the gun and the foot :slight_smile:
Ing. Andrea Aime
@geowolf
Technical Lead
