Hi Andrea, I implemented 2 of your last proposals.
1) Importing a tiled image including all pyramids is now possible.
Before you had to import each level for its own.
2) I reduced the generated ddl scritps to
createmeta.sql
dropmeta.sql
which are executed once.
add_<coveragename>.sql (including all create table, create index, register, and insert statements)
remove_<coveragename>.sql doing the opposite of add_<coverage_name>.sql
which are executed for each coverage.
Both improvments are documented in the geoserver tutorial and the geotools user guide.
Justin, you can start tagging 2.5.4.
Question: Is the build server running on a Unix or Windows system ?.
Since I do a lot of file handling and have no Windows environment at the moment, I cannot test and hope I will not break the build.
christian
createmeta.sql
dropmeta.sql
Nicely done
It's running on a Linux box, but I have a Windows machine at home
(but not here in NY). So I'll be able to check that out only
on Monday.
Hi Christian,
Thanks for the quick implementation of your changes. I will create the 2.5.4 tag soon.
-Justin
createmeta.sql
dropmeta.sql
christian
Open Source Business Conference (OSBC), March 24-25, 2009, San Francisco, CA
-OSBC tackles the biggest issue in open source: Open Sourcing the Enterprise
-Strategies to boost innovation and cut costs with open source participation
-Receive a $600 discount off the registration fee with the source code: SFAD
http://p.sf.net/sfu/XcvMzF8H
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
