I would like to improve the importer to make it support a very common
image publication workflow that it’s currently not supported, and discuss
the direction of changes to be performed.
The workflow is more or less as follows:
- The client indicates that one or more “golden” images need to be importer
into GeoServer for WMS/WCS usage. The original files are big, and must
not be touched, so ideally the client would just tell GeoServer where the
files are (disk shares) and GeoServer should copy them autonomously - Once the images are in GeoServer possession, the code should run
a gdal_translate the adjust the image structure (tiling, compression, bit depth,
you name it) and gdaladdo to add overviews. - The resulting files should be configured as new layers, or as a replacement
for existing target layers
All three points require some changes/improvements to the importer.
Point 1) could be solved by http upload, but given the size of the files, and given
they are already available in a network accessible share, it would be best
to have them be copied instead.
I guess this could be done by adding a copy : “true” directive in the import data?
E.g:
“data”: {
“type”: “directory”,
“location”: “/mnt/share/myImage.tif”,
“copy”: true
As an alternative, the copy step could be a ImportTransform, but the current
transforms have no way to alter the ImportData they receive.
We could either make ImportData subclasses mutable, but I’m worried they
are immutable for a reason (storage, replay), or allow pre-tranform to return
a different ImportData, e.g…
public interface PreTransform extends Transform {
ImportData apply(ImportTask task, ImportData data) throws Exception;
Wondering what people would like best here?
Going to point 2), the current RasterTransformChain/RasterTransform
interfaces are dead code, there are no implementations, so I guess
we have a blank sheet here.
I was thinking that the calls to gdaltranslate/gdaladdo would be pre-transform
types. Param wise, we can either try to setup a limite set of well know params,
or have the caller just give us the straight parameters they want us to use
(besides the file names, that is). I’m lending towards the latter, it’s more flexible
and allows to use the full set of abilities of the gdal installation on the server.
E…g, we cannot predict in advance if people just need to compress, which
compression params they want to use, if they need to reorder or shave off
bands, reduce the bit depth, expand from palette to rgb, and so on
The same goes for gdaladdo, the common params are … common, but
if you start dealing with overviews compression, you have extra params there
too.
At this point we could get to point 3), and here things get interesting.
If the target store does not exist, we can just configure a new one, done.
If anything, we’d have to decide where to put the files.
For a direct import, that’s easy, we could just have the copy mode upload
them in their final position.
But what if we need to update an existing layer instead? It means we have
to do the processing (which might take time) leaving the target files alone
(this would be an indirect import with “replace” mode in the task I guess?)
In any case, we probably need to ask the store where its files are, to perform
the replacement, something we do not have today.
I was thinking of allowing stores and readers to implement a FileSource interface,
that would have a single method:
List getFiles();
which would give us the location of the files used by the store, we would
then delete those, and copy over the new ones.
Since we are dealing with files that OGC requests might be using, and
since we try to have GeoServer work on Windows, the above might not be a straight
file operation, but more something like:
- Disable the resource/layer so that no new OGC requests can use it
- Try to perform the replacement (with retries, as on Windows the files might still
be locked by OGC requests that were already working on the files) - Re-enable the layer once done
I guess this would form the mean of the raster indirect import (for simple rasters
at least, structured grid coverage readers might have to follow a different path,
e.g., harvest the new granules in an existing mosaic).
Ok, that’s all I had in mind… opinions, feedback welcomed.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
